May 25, 2022 at 10:54 pm
zbath0316
SubscriberIf I am interested in the Plastic part of the fracture mechanics of a J-INT (J Integral)? What kind of material properties would be needed for plastic fracture besides the Young's Modulus and Poisson's ratio? I believe these only define the elastic region of crack propagation and would like to know more about the plastic region as well. Is there a way to model both the elastic and plastic region of crack propagation in ANSYS?
May 31, 2022 at 12:59 pm
Ashish Khemka
Please see if the following link helps:
Elasto-Plastic Fracture Mechanics ÔÇö Ansys Learning Forum
Regards Ashish Khemka
How to access the ANSYS Online Help ÔÇö Ansys Learning Forum
December 6, 2022 at 10:10 am
bhagwantP
Ansys EmployeeHello inheriting,
Adding few more useful links for your reference in case you have access to all:
The J-integral concept for elastic-plastic material behavior - ScienceDirect
Elastic Plastic Fracture Mechanics - an overview | ScienceDirect Topics
The J Integral Approach in Elastic-Plastic Fatigue Crack Propagation | SpringerLink
5bdf4ebe1b3e4547e02836463511fa74_nlefm.pdf (mit.edu)
Material Forces: A Novel Approach to Fracture Mechanics in ANSYS (wildeanalysis.co.uk)
2.4. Material Force Calculation (ansys.com)
Thanks
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
3778
2587
1829
1242
598
