July 10, 2023 at 10:01 am
Nick Makaroglou
SubscriberHello all, as you can see in the provided photo, I am creating this object. The problem I have is with creating the fillets at points A and B. For B as you can see the fillet starts 15 degrees after the vertical b line. Normally for fillets you click the 2 lines you want to fillet and that's it, how will I make it so that the starting point of one line is smaller? If I understood it correctly. And for A which is with the 50 degrees, I don't even know how to explain it. As you can see I am stuck, I have created everything else no problem, the fillets are the problem. I am using design modeler 2023 R1. Any help will be greatly appreciated!
July 11, 2023 at 11:07 am
Aniket
Ansys EmployeeIt is not very clear from the image what your part looks like. Is it a keyway with a variable fillet radius? In DesignModeler one can use variable radius blend to achive different fillet radii:
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/wb_dm/dm_variableradius3dmod.html
-Aniket
July 11, 2023 at 11:55 am
Nick Makaroglou
SubscriberHello and thank you for answering! Yes it is a keyway but the variable fillet radius is wrong, because as I understand it, it changes the starting and ending radii uniformely. I dont need such a thing. For point B I need the arc to be smaller from one side, if I decrease the value of the radius it becomes smaller from both sides, i need the value to be the same but the arc being 15 degrees smaller from one side I have provided a screenshot which shows the 2 arcs I have created with Fillet and based on the diagram I need to decrease the starting point of the arc on those 2 points.
July 13, 2023 at 2:04 pm
Aniket
Ansys Employeeyou can cut the shaft in half and then apply a variable radius fillet to one side and a fixed radius fillet to the other? Also, try SpaceClaim as it gives more control for changing fillet radius at edge:
-Aniket
4502
2969
1449
1322
