Ansys Products
Ansys Products
Need help in projected area of pipe along the direction of flow
    • mmia1
      Hi
      I have generated pipe and elbow .k file using MATLAB. Have some confusion how to calculate the projected area of the element of pipe and elbow. For instance, if water is flowing in Z direction, elements of pipe1 and pipe 3 will not experience any pressure and force, while pipe 2, elbow 1 and elbow 2 will experience water pressure and corresponsidng forces. I was told that I have to calculate projected length and width and multiply to get projected area. This area will be such that when water is flowing in Z direction, corresponding area of pipe 1 and pipe 3 will be zero and there would be area for the remaining parts.
      My code was as follows:
      %% element area pipe 1
      for m = 1:size(element_num_shell_1_1,2) % size(element_num_shell_1_1,2) = 840, total number of elements of pipe 1
      if mod(m,n_ele_circum-1)~= 0 % n_ele_circum = number of elements around the circumference = 15
      P1 = node_coord_list(m,[2:4]); %
      Q1 = node_coord_list(m+1,[2:4]);
      R1 = node_coord_list(m+(n_ele_circum-1),[2:4]);
      else
      Q1 = node_coord_list(m-(n_ele_circum-2),[2:4]);
      end
      if flow_direction == 1 % flow_direction =1 means flow paralle to + Z axis
      l = abs(P1(1)-Q1(1)); % length
      w = abs(P1(2)-R1(2)); % width
      elseif flow_direction == 2 % flow_direction =2 means flow paralle to + X axis
      l = abs(P1(3)-Q1(3)); % length
      end
      Area_ele(m) = l*w;
      end
      Here, P1, Q1 and R1 are as follows:
      The problem is that, for pipe 1 and pipe 3, I got zero area, however, for pipe 2 and elbow also I got zero projected area. Can anyone help me in this regards? Thanks.
    • Federico Alzamora Previtali
      this seems like a Matlab question. Do you have a Fluids question?
