Need help to find tutorials for Fluent
    • Bijoy Prasad
      I try to find some tutorials in Fluent when a 3D body moving or advancing in calm water using multiphase flow and dynamic mesh. Please help me to find tutorials regarding this?
    • Raef.Kobeissi
      you need to use the 6 dof method and dynamic meshing: similar concept to this tutorial:
      https://youtu.be/40UR7pFfJGA
      Regards
    • Bijoy Prasad
      Hello Raef,
      This tutorial is different from my case. I am trying to simulate a hull model advancing in x-direction in calm water. I used tetrahedral grid only around the hull and hexahedral grid rest of the domain. So I used Smoothing, Layering and Remeshing method and same grid size in x-direction. I faced revered flow both in inlet and outlet boundary, could please check my project file and let me know what might be the problem.
      Bijoy Prasad
    • Bijoy Prasad
      Hello Raef,
      Did you get any chance to check my case file?
      Bijoy Prasad
Viewing 3 reply threads
