April 6, 2022 at 5:32 pm
karoo178
SubscriberHello,
My name is Khanh. I am trying to learn about different inlet and outlet boundary conditions in Ansys. However, I run into a problem with a made-up example where I tried to simulate a flow in a pipe with pressure inlet and outlet boundary conditions.
The pipe dimension was: radius = 10 mm, and length = 20 mm
The inlet pressure was 2 bar or 200,000 Pa and the outlet pressure was 1 atm or 101,325 Pa.
I set the operating pressure at 101,325 Pa, inlet gauge total pressure 98,675 Pa and outlet gauge pressure 0 Pa. I used air at 20 C as the fluid.
When I ran the simulation, the inlet pressure did not stay constant as I expected it should. Could anyone please help explain what is going on? I feel like I have misunderstood the physics very badly. Please help.
April 7, 2022 at 5:07 amKeyur Kanade
Ansys EmployeePlease use velocity inlet and pressure outlet boundary condition as it is most robust. Please go through help manual for more details
Regards Keyur
2630
2104
1327
1110
461
