October 31, 2018 at 12:44 pm
kalyan
SubscriberI'm using the ansys 19.1 academic version and i am getting a value for min orthogonal quality as 0.02 and aspect ratio as 25.01 when I tried to do the analysis.
I need to know what are the best values possible and attainable for the model in the attachment (i.e. the geometry) and also the way to improve the value of min orthogonal quality if required.
Please do help!!!
October 31, 2018 at 12:52 pm
Naresh Patre
Ansys EmployeeHello kalyan,
Can you upload a few snapshots of the mesh that you generated? It will help us to provide better suggestions.
October 31, 2018 at 2:31 pm
October 31, 2018 at 3:40 pm
Ansys EmployeeI suspect you're growing the mesh too quickly or don't have enough cells around the object in the middle. Check your minimum cell sizes and growth rate. Also please confirm you've got the meshing tool set to CFD.
October 31, 2018 at 5:24 pm
kalyan
SubscriberSir could you please elaborate as you said "Also please confirm you've got the meshing tool set to CFD. "
Sir im a beginner so please do elaborate it.
Thank you
Regards Kalyan -
November 1, 2018 at 3:57 am
Keyur Kanade
Ansys EmployeeHello,
Please have a look at following video.
Please try to get min orthogonal quality to 0.1 for fluids simulation.
Keyur
November 1, 2018 at 3:19 pm
kalyan
Subscribersir,
Is 0.1 a good value for the min orthogonal quality?
November 1, 2018 at 4:27 pm
Ansys EmployeeIt's acceptable, ideally it wants to be higher. Have you gone through the tutorials that come with the R19 documentation and that are posted elsewhere on the community?
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2726
2146
1357
1150
462
