June 24, 2023 at 5:08 am
Krishna Kumar
SubscriberI am using Ansys Maxwell for motor design, I have already applied sufficient torque but my Speed continuously increases and the torque is oscillating between positive and negative cycle
June 27, 2023 at 12:09 pm
HDLI
Ansys EmployeeHello Krishna,
Could you provide more information on it? Which motor type are you simulating?
Do you use RMxprt to generate Maxwell FEA model? Thanks.
HDLI
June 27, 2023 at 12:24 pm
Krishna Kumar
SubscriberI am using Ansys Maxwell directly to configure PMSM motor.
June 28, 2023 at 3:52 pm
HDLI
Ansys EmployeeCould you use RMxprt to create similar model to compare winding sequence and pattern, and us external circuit? The key is the excitation should follow rotor position to provide power because PM motor is synchronous machine. BLDC RMxprt model would generate Maxwell model with external circuit, that can perform this drive. Please check them.
HDLI
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7658
4476
2957
1433
1322
