May 24, 2022 at 4:23 am
May 25, 2022 at 1:26 pm
Chandra Sekaran
Ansys EmployeeIt is not clear what you are asking. The two plots above are the same. Do you want to do something like Ux(time=1) - Ux(time=2) or something else?
If you need something similar to a PATH then under Model --> insert --> construction geometry and create a construction surface. Then you can plot results on that surface similar to path.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3930
2649
1861
1272
610
