August 3, 2019 at 6:58 pm
Georgiro1
SubscriberSo I need to change certain dimensions I again I have a huge problem to change the dimensions. Basically I do not know how to do it at all, but have the changing dimensions with a star of the dimension, but it does not want to change it at all. Have a look at the SpaceClaim model 19.2 attached. And basically need to change e. g. dimension of the hole outwards into middle hole, which should be 32.5 mm e. g. and there is only 31.14 mm.
August 3, 2019 at 9:11 pm
SubscriberI don't see any 31.14 mm dimension in the attached file, I see 27.2 mm
August 4, 2019 at 6:03 am
Georgiro1
SubscriberSorry, this was wrong, so I will put there a new model, but again the same problem I had before and again...
August 4, 2019 at 6:10 am
Georgiro1
SubscriberSo now it should be there! Thanks for have a look. And here you can also see some of the dimensions I need to implement into the model...
August 4, 2019 at 11:02 am
August 4, 2019 at 12:50 pm
SubscriberI moved the hole face to 32 mm using the Move tool, exactly the way I showed in the silent video. Then I dimensioned it in on the Details tab.
You can see that the 31.14 dimension is to a sketch curve and not solid geometry.
August 4, 2019 at 1:01 pm
Georgiro1
SubscriberWell done, I just do not understand the problem I have, you say it, but I do not understand it, but you are saying have a look at silent video? Where to have a look at it? Thanks
August 4, 2019 at 1:02 pm
Georgiro1
SubscriberSo what shall I understand to a sketch curve and not solid geometry? Thanks
August 4, 2019 at 1:23 pm
Georgiro1
SubscriberAgain a good fun. And the fact is that today it went well. So because you told me the details, but if you tell me something about what you have said like of sketch curve and not solid geometry, it will make me understand the problem. But thanks a lot.
August 4, 2019 at 2:37 pm
Georgiro1
SubscriberBut obviously what is the most important to see is that I am not able to put there dimension - value. Strange problem, but the fact is that I am not able to change the plane from vertical to a different, that would be associated with the dimension plane!
August 4, 2019 at 3:19 pm
August 4, 2019 at 6:24 pm
SubscriberSilent video (added link above also).
What do you need at the end? A solid model or a dimensioned drawing?
I don't dimension anything unless I need to make it variable geometry for parametric analysis.
You drew a circle and it had a radius of 31.14 mm At the time you drew that circle, a box popped up with that dimension. That was your chance to type in 31.2
If I accidentally lose the box with the dimension in it, I delete the curve and draw it again. I don't add a dimension to try to drive the dimension to a different value.
Start over and type in 31.2 when the box is offered. Don't go forward with the wrong dimension.
August 5, 2019 at 5:46 am
Georgiro1
SubscriberI did it as I need it so now it is fine so thanks for your help! My general problem is to be able to find if I see the stars to change the dimension that it is not basically be changed - you cannot change it normally, so the point is how to find out to be changing the dimension in general. This looks as the most problematic way! Thanks for your ideas!
August 5, 2019 at 12:40 pm
Georgiro1
SubscriberSo e. g. I want to change the dimension of 31,14 to 31,2 mm and I have the stars to change the dimension, but it does not accept it at all. So would would you suggest to understand this problem and it is the most complicated problem at all.
Thanks
August 5, 2019 at 12:44 pm
SubscriberSome CAD systems keep a history of operations, so if you draw a sketch with a circle and radial line, then you make a hole in the solid at the intersection, the hole will move if you change the dimension of the circle. SpaceClaim doesn't do that.
You need the circle and radial line to make the hole, but after you have made the hole, hide the line and circle (the Curves folder) if you need it later.
If you need a spark to move the hole, select the hole face (not the circle or point) and use the Move tool as shown in the silent video and when the box pops up to enter the dimension, click on the P and you will get a Group name with that dimension that can move the hole.
August 5, 2019 at 12:50 pm
Georgiro1
SubscriberOk, but how this can be related to the bigger distance of 31,14 mm to 31,2 mm? I have no idea. Thanks.
August 5, 2019 at 12:56 pm
Georgiro1
SubscriberOr you tell me just delete the hole completely and do it again in the distance of 31,2 and not 31,14?
Thanks
August 5, 2019 at 1:23 pm
August 5, 2019 at 3:44 pm
SubscriberYes, delete the holes by selecting the four faces (chamfer and hole) and pressing the F key for Fill.
Delete the circle and lines.
Construct a circle at the correct diameter and two lines at 55 degrees.
Create a hole at each intersection point to a diameter of your specification.
August 5, 2019 at 5:27 pm
August 5, 2019 at 9:45 pm
SubscriberDelete all the lines and circles. Start a Sketch, and under Options, check the Create Layout Curves checkbox. Draw a line that is 32.5 mm long at an angle of 55 degrees, then go back to the Select tool.
Start another sketch, but this time, without the Create Layout Curves option checked. Draw a circle at the end of the line and type the diameter you need for the hole. Then go to 3D mode and use the Pull tool to make the hole.
August 6, 2019 at 10:52 am
Georgiro1
SubscriberSo it is a bit silly, but how can I draw a line with 55° only? I have no idea. Thanks
August 6, 2019 at 1:42 pm
August 6, 2019 at 1:49 pm
Georgiro1
SubscriberSo how to set this up. I do not know how to do it!
Thanks
August 6, 2019 at 1:56 pm
Georgiro1
SubscriberThis was very useful for me, now I will know what is necessary...thanks, I have just the value of 55°.
August 6, 2019 at 5:15 pm
August 6, 2019 at 6:19 pm
Georgiro1
SubscriberAnd now you can see these three holes, that one is white and the other two are a bit green as it can be seen and as well as I had to put the legth only of the depth of the material. And I had to create the depth of the hole on the basis of the length, otherwise it would not work at all. So I do not know what is this problem...
August 6, 2019 at 8:32 pm
SubscriberLook at the Outline, do you see any Surface line items? With the Select tool active, click the surface item in the outline and hit the delete key.
When you use the Pull tool, you can set to to Cut material in the options panel.
August 7, 2019 at 5:06 pm
Georgiro1
SubscriberSo I have been looking at the model, but I am not able to find the Surface line item? So I am adding here the model as well, so please have a look at this, I cannot see anything, but you will let me know what is the problem. Thanks The only difference is when I see the model, it is not so dark...And also there is another problem that there is another part, sou I would need to put it together as one part, so connect it to the main part...
August 7, 2019 at 8:11 pm
SubscriberThe Purple Icon with the three side of a cube are surfaces.
The Green Icon of a cube is a solid. You only have one solid, which is highlighted in orange.
If you sketch a set of curves that form a closed loop and click the pull tool, the curves will become a surface and you will pull that surface into a solid.
If you sketch a set of curves that do not form a closed loop and click the pull tool, you will pull surfaces from the curves and have no solid.
If you hide the solid, and go to the Repair tab, you can put in the missing faces to Solidify the surfaces you have.
Now you can use the Pull tool to pull the face that should be a hole through the part and make a hole. Note that you have to click Cut in the Options when you pull that face.
If you want to merge the original solid, make it visible again and use the Combine tool to Add one solid to the other.
August 8, 2019 at 11:23 am
Georgiro1
SubscriberSo my question is how do I have to create the solid of the part of the object, because you make it somehow, but I do not know how? And you have made it on the 2nd and 3rd image and also I do not know how to put together the two solid as one? Thanks for details
August 8, 2019 at 11:44 am
SubscriberRepair tab, Missing Faces tool.
August 8, 2019 at 12:10 pm
Georgiro1
SubscriberNo, I have to change my opinion, because now I have the 2 holes as 2 another objects, but I need to know how to delete them and make theam as holes and also how to connect the small layer and it is also clear that the whole object is not an object at all, but how to do it an object? That is also a question for me! Thanks
August 8, 2019 at 6:00 pm
August 9, 2019 at 1:13 pm
Georgiro1
SubscriberSo my stupid question is how you disabled the hole of the bolt? I cannot get it at all! And how to do if for the other cration of the hole - I also cannot get it from your view....It just makes a hole, but as a part of the volume, but it should do a hole and it does not do it at all. It is a bit confusing...
Thanks
August 9, 2019 at 1:36 pm
Georgiro1
SubscriberSo now I removed the two holes, but how to do it without the material, to have it as a hole? A bit impossible at all!
August 9, 2019 at 1:42 pm
Georgiro1
SubscriberAnd also the fact that you have there a feature of volume, but it is not in my file, it only have volume, but it shown surface feature, which is a bit strange and the hole of 6,2 mm is also only surface feature. So again I deleted the gaps and have there only the lines of the circles...
August 10, 2019 at 11:54 am
SubscriberIn the video above, I started with your file, the one you attached here. So watch the video a few times, noting every step along the way and you should be able to reproduce the end result.
August 10, 2019 at 2:45 pm
Georgiro1
SubscriberFine, I am not able to understand it at all. What shall I will doing I have no idea at all!!!
August 10, 2019 at 2:48 pm
Georgiro1
SubscriberSo now I can see that you click on the circle of the in the future possible hole you will do it and it will work, I have to try to do it. Thanks
August 10, 2019 at 2:54 pm
Georgiro1
SubscriberAnd unfrortunately, I am doing it again it is absolutely wrong, because the volueme is corrected in to hole, but it should be empty! And does not know what to do with it at all!
August 10, 2019 at 4:31 pm
Georgiro1
SubscriberAnd also I do not knwo how to create a basic solid of the structure at all?
August 14, 2019 at 12:42 pm
Ansys EmployeeAs you've moved onto Volume 3 I'll lock this one to prevent confusion.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2684
2120
1349
1136
461
