June 20, 2019 at 3:10 pm
cplace
SubscriberI know we can run IcePak on the HPC, but would like to run IcePak in parallel on a desktop to support research efforts. The researchers says we are not licensed for it, our Sales Rep stated we have all the licensing we need.
I would appreciate assistance with this ASAP.
Thank you!
Chris -
June 20, 2019 at 5:57 pm
ANSYS_MMadore
Ansys EmployeeHello Chris,
Are you looking for simply running Icepak on the local machine, utilizing additional cores? For example running on local workstation using 8 cores?
If so, you set this up by going to Solve -> Settings -> Parallel and setting Parallel and # of processors. This will run locally on that number of processors.
Thank you,
Matt -
June 24, 2019 at 7:57 pm
June 28, 2019 at 1:24 pm
ANSYS_MMadore
Ansys EmployeeChris,
I've sent you an email to continue with this.
Thanks,
Matt
January 31, 2020 at 11:56 am
alpha198
Subscriberi have the same issue ,,, can you share the dateails you sent to the guy ??
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1821
1236
594
