July 15, 2018 at 6:25 pm
Rohitporuri
SubscriberI have created a straight valve engine design. And while performing the cold flow simulation, getting the error of "negative cell volume detected - dynamic mesh error" at time step 8. Could you suggest any solution? I tried enhancing the mesh quality in ICEM, by making it finer and other, but no use. Please help me with this problem?
July 16, 2018 at 4:00 pm
Ansys EmployeeI can't help with specifics as it's beyond what I can answer as ANSYS staff on an open forum. However, it's very likely that you've moved some geometry too far in that time step and it's turned the cell inside out. Also check the set up for topology changes or significant changes in shape.
I'll also move to the Fluids section as it's more likely to get an answer.
July 21, 2018 at 8:59 pm
Rohitporuri
Subscriberi removed the topology condition, and manually setup the dynamic meshing.
but now i am getting the error, "floating point exception", divergence problem.
what to do right now?
please help
July 21, 2018 at 9:01 pm
Rohitporuri
Subscriberi tried this with different mesh qualities, but the same result
please help me
2524
2064
1279
1096
456
