Negative Cp in Peng_robinson Model
    • Marco Alborghetti
      Good morning,
      I'm trying to implement the Peng-Robinson model in a multiphase problem, in order to see the evaporation during a transient simulation. I've found all the parameters of the model inside the "MATERIAL-pengrob.ccl" file, when i go to set the data of cp by using a piecewiese polynomial, and than I initialize it, the software tell me that the cp is invalid (negative) for that temperature, anyone is able to help me?
      Kind regards,
      With polynomials it's easy for an overshoot in the curve to return a negative number. Plot the exact equation you plugged into the materials panel in Excel (or another package) and see what you get.
    • Marco Alborghetti
      Fluent provide me directly a plot of the resulting curve and it goes under 0
      I keep forgetting they added the graphs into the materials panel. So, you need another curve or expression/UDF to clip the values to be positive.
Viewing 3 reply threads
