Ansys Products
Ansys Products
Negative Modal Frequencies
    • drwilkes7
      Has anybody encountered the warning message below when conducting a damped modal analysis in ANSYS 2021 R2?
      The model consists of a rectangular plate suspended by body-ground longitudinal springs attached at the corners. The springs include longitudinal damping and the plate material also has material dependent-damping (damping ratio). Removing the longitudinal damping from the springs appears to alleviate the issue, while the material damping doesn't seem to change the result.
    • Chandra Sekaran
      please repost the warning message
      • drwilkes7
        Thank you very much Chandra Sekaran for replying. The warning message is below:
        Of course, changing the Frequency Display from 'Program Controlled' to 'All' will stop the actual warning message. My real interest is in what might cause non-conjugate pairs of complex frequencies to be calculated by the Full Damped Solver.
        Any help would be greatly appreciated.
  • The topic ‘Negative Modal Frequencies’ is closed to new replies.
