May 19, 2022 at 6:12 am
ur21581
SubscriberI don't know why we got a negative reflectance dip for the following setup:
May 20, 2022 at 4:50 amGuilin Sun
Ansys EmployeeAre you using log scale?
If not, it might mean you need to significantly increase the simulation time and reduce the ausothutoff min and make sure it is the autoshutoff that terminates the simulation. i.e., the simulation stopped before it reaches 100%. Please increase the simulation time 100times and check.
It might also mean that the PML reflection is strong. Check if the PML is thick enough, eg ,half wavelength, and far away from the device. this is necessary if there is SPP and the field tails are long.
Please try and let me know if it improves. Once it improves but still negative while majority positive, then continue what you have done.
May 21, 2022 at 9:11 amur21581
SubscriberThank you very much for your informative answer.
The error is because the PML wasn't thick enough.Viewing 2 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
3670
2552
1751
1226
582
