April 13, 2022 at 7:19 am
mm_candela
SubscriberApril 13, 2022 at 5:39 pmGuilin Sun
Ansys EmployeeThis is a frequently asked question, as Lumerical calculates the "transmission" by definition, and defines the positive value when the energy flow is along the positive axis direction, and the negative value when light travels along the negative axis direction for some purposes. The calculation is here: transmission - Script command the sign of "transmission" is the same as the Poynting vector, as the monitor "surface normal" is always positive.
As you know the power transmission is always positive. So in Visualizer please choose "-Re" instead of the default Re, and in scripting please add a negative sign in front of the "transmission" when the energy flow is towards negative axis direction. I do not suggest to use absolute operation as it may hide some potential is sues.
April 13, 2022 at 5:40 pmGuilin Sun
Ansys EmployeeBTW: Lumerical has a dedicated forum here: Photonics ÔÇö Ansys Learning Forum Please post your questions there later. Thank you!
April 14, 2022 at 7:44 pmmm_candela
SubscriberApril 16, 2022 at 9:17 pmGuilin Sun
Ansys EmployeeThe software its self uses "transmission" in general, it can be reflectance or transmittance. You can determine if it is R or T.
To achieve zero reflection at approximately 5.8 microns, you will need to optimize your device, which is another topic. Please refer
sweep : Parameter sweep utility - Lumerical Support
optimization: Optimization utility - Lumerical Support
Please write a new post at the Photonics Forum
if you have questions.
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- 软件打不开
- Ganhemt Project mistake can you help me
- how to export results from SPEOS to Mechanical
- Simple Optical simulation
- Negative Reflection Problem
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
- 超透镜聚焦效率
- HUD simulation Speos
5364
3363
2471
1310
1018
