April 21, 2023 at 7:15 am
Christian Erick Sutanto
SubscriberI am currently simulating the effects of SPP on Molybdenum based nanopyramids from 200 nm to 1000 nm. Question is, when I am inserting the data for the material of the Molybdenum, It appears to have a warning that states: "warning: at least one value of the real part of the refractive index in the sample data is negative. negative values have been switched to be positive. material data with negative refractive index is not supported by sample data materials.". Do I need to use another type of material or should I let it be? Or is there an alternative way to solve this? Any help is much appreciated, thank you in advance!
April 21, 2023 at 7:07 pm
Guilin Sun
Ansys EmployeeUnfortunately, you cannot directly assign index to be negative. Since negative refractive material is dispersive, you should use dispersive material model, and usually you need both permittivity and permeability negative simutaneously. Please refer to magnetic-electric model
https://optics.ansys.com/hc/en-us/articles/360034394734
and this example:
https://optics.ansys.com/hc/en-us/articles/360041616614-Bulk-metamaterials-based-on-magnetic-and-electric-Lorentz-models
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5162
3275
2453
