Negative temperature
    • momidor
      Good morning,
      I did a transient thermal simple case. Having input:
      • +22 C ambient,
      • +150 C, +60 and +10 C at three parts of steel
      • 3 W/mm3 of heat flow at small part of steel
      • radiation
      • convection
      I received silly, - 4094 C, negative temperature output as hereunder. Why ?
      Thanks in advance for tips.
    • peteroznewman
      I moved this to the Thermodynamics Category.
      Is this a multistep solution?
      Is there a step change in the loads on the model at the time when the negative spike occurs?
    • dinhan0394
      can you show the mesh (mesh model and mesh quality) and boundary conditions (values as constant or variable by time)?
    • momidor
      The source is a pick of heat is "Internal heat generation" 3 W/mm3 which is changing from one steel item to another one by one.
    • dinhan0394
      Where does your model have a negative temperature?
      Try increasing the mesh quality in the model (transitions between heat sources and surrounding bodies), using linear elements (element order = linear).
    • peteroznewman
      Use smaller elements in a region around the problem area.
    • momidor
      Thanks for help.
      I had a wrong thermal data of the steel. Also I changed to Study-State Thermal and now is ok.
      All the best
      Momidor
Viewing 6 reply threads
