September 18, 2022 at 7:26 pm
September 19, 2022 at 3:24 pm
Guilin Sun
Ansys EmployeeThis is numerical error due to discretization. You may increase the simulation span along the bending direction. You can also correct this negative loss by allowing mode propagating in the negative direction, eg, real(neff) is negative. In most cases it is ok to have the fake "gain" as you know it is due to error.
September 20, 2022 at 5:48 pm
Guilin Sun
Ansys EmployeeFor Lumerical products, please write post here Photonics (ansys.com) which is a dedicated forum for Lumerical products.
- 软件打不开
- Ganhemt Project mistake can you help me
- how to export results from SPEOS to Mechanical
- Simple Optical simulation
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- How to calculate the cross-polarization efficiency and phase in FDTD
- Negative Reflection Problem
- Inverse design of polymer y-branch – modify the example provided
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
2616
2096
1321
1108
461
