January 11, 2023 at 10:02 pm
Yixin Chen
SubscriberHi all,
I am using Lumerical FDTD 2022 R2.4 to run simulations with a nested sweep. However, I keep encountering "Nested sweep must have the same solver" error without any further message while constructing the sweeping files. Does anyone has any idea where the error comes from or how to solve it? Any input will be much appreciated.
January 12, 2023 at 6:23 pm
Guilin Sun
Ansys EmployeePlease send us an email with file attached, and indicate this post in the email. If you do not know the support email address please contact your local sales. It is better to direct to me.
- Error on Lumerical device
2564
2080
1299
1106
459
