January 6, 2020 at 9:44 am
January 6, 2020 at 10:06 pm
Brian Bueno
Ansys EmployeePaesc
Our development team is investigating whether or not cloud drives support the thumbnail previews. Initial testing shows similar behavior to what you have reported.
June 15, 2020 at 6:53 am
paul
SubscriberBrian Bueno
Any update on this? A customer still keeps getting issues with this.
We found out that some automatic windows updates are causing this. Deleting the updates makes this work, but the customer doesn't want to delete updates to keep using the SpaceClaim thumbnails everytime.
Example of windows updates that are causing the problem. (there are probably more, but this has to be tested)
KB4560959 and KB4556799
November 19, 2020 at 7:44 am
paul
SubscriberHello Brian Bueno ,
Is there already a solution regarding this issue? It's been already 10 months since this was taken to development.
November 19, 2020 at 9:51 am
Naresh Patre
Ansys EmployeePaesc Did you try out the suggestion posted at the end of this discussion thread?
January 6, 2020 at 10:22 pm
Brian Bueno
Ansys EmployeePaesc
This may resolve the problem:
https://windowsreport.com/onedrive-not-showing-photo-thumbnails/
July 14, 2020 at 12:38 pm
Naresh Patre
Ansys EmployeeHello Paesc
Did you try out the above solution suggested by Brian?
July 14, 2020 at 12:42 pm
paul
SubscriberNaresh Patre Hello,
This did not work unfortunately
July 17, 2020 at 7:48 am
paul
Any more ideas on how to make this work?
July 17, 2020 at 12:18 pm
Naresh Patre
Ansys EmployeePaesc I am checking with the development team and will let you know.
July 20, 2020 at 1:48 am
Naresh Patre
I got following reply from the developer:
This is a known (Microsoft) problem with OneDrive service.
If OneDrive is not installed/active, thumbnail preview works fine on network drives.
(the developer shared one image where the thumbnail preview is working for network drive, but the image can't be shared due to confidentiality)
I’ve seen reports that upgrading Windows to 1903 (or 1909) fixed this issue, cannot confirm though.
Also some customers say that stopping backing up target files (OneDrive settings) and then once they are copied to onedrive, removing local references fixed the issue for them.
August 13, 2020 at 2:09 pm
paul
SubscriberHello @Naresh Patre,
Updating windows with these updates still doesn't work.
August 17, 2020 at 8:38 am
Naresh Patre
Ansys EmployeePaesc
Naresh Patre said:
Also some customers say that stopping backing up target files (OneDrive settings) and then once they are copied to onedrive, removing local references fixed the issue for them.Can you try out this option which was also suggested earlier?
- Copy user settings to new release
- Electric Heating – Ansys AIM
- problem to access on the spaceclaim help
- Discovery Getting Crashed
- Dwg export error
- Critical error
- BUG to correct is important
- Error messages running solver
- Discovery Live freezes with multiple load cases while topology optimization
- Unexpected graphics error
3638
2502
1733
1226
578
