October 16, 2018 at 4:07 pm
vuiis-sysadmin
Subscribereliminating the ansoft.lic file and going to a combined ansyslmd.lic file makes it so that our users of the electromagnetics suite cannot work anymore. Fluent users continue to be able to open the app and work. Very bad time for this to take place for us as we have several HFSS users who are under a big conference deadline.
Running LM on Linux CentOS 7 with all updates, LM is 19.2.
October 16, 2018 at 4:48 pm
tsiriaks
Ansys EmployeeHi vuiis-sysadmin,
What is the error message the clients are seeing ?
I can't think of a situation when combined license would affect Ansoft users. Except, you were hosting Ansoft license with the legacy FlexLM for Ansoft License Manager. Using this legacy LM, the clients won't have to specify the FlexNet port number in their '.lic' files under (default) C:Program FilesAnsysEMadmin. It would look something like
SERVER
ANY
USE_SERVER
But once you host the license in ANSYS LM, client must specify the FlexNet port (default is 1055), something like
SERVER
ANY 1055
USE_SERVER
If you can attach the 'license.log' from the license server, that would be helpful too.
Thank you,
Win
October 16, 2018 at 5:13 pm
vuiis-sysadmin
SubscriberLicense Manager is from the 19.2 License Manager installer.
SERVER ansys 000c298fa315 1055
VENDOR ansyslmd 1056
USE_SERVER
error:
Failed to check out license 'hfss_desktop'.
Cannot connect to license server (FLEXlm Error -15)
Failed to check out license 'designer_desktop'.
Failed to check out license 'q3d_desktop'.
Failed to check out license 'maxwell_desktop'.
Failed to check out license 'simplorer_desktop'.
Failed to check out license 'electronics_desktop'.
From the same client machine Fluent opens just fine.
October 16, 2018 at 5:45 pm
tsiriaks
Now we are moving one step closer to my guess earlier.
On the client machine, check all '.lic' files under (default) C:Program FilesAnsysEMadmin and make sure it specifies port 1055
Also, check if that client machine is using any of the following environment variables
ANSOFTD_LICENSE_FILE
LM_LICENSE_FILE
If so, please post the value here.
Thank you,
Win
October 16, 2018 at 6:10 pm
vuiis-sysadmin
SubscriberOn Client:
SERVER ANSYS.VUIIS.ORG ANY 1055
USE_SERVER
No environment variables were created by me on the client. Whatever the installer does is what was done.
No environment variables named ANSOFTD_LICENSE_FILE or LM_LICENSE_FILE
Firewall ports on the license manager server that are open:
1055 tcp/udp
1056 tcp/udp
2325 tcp/udp
ansyslmd.lic file on LM server:
USE_SERVER
October 16, 2018 at 6:19 pm
JakeC
Ansys EmployeeHi,
Vendor line should look like:
VENDOR ansyslmd PORT=1056
Please try that.
Thank you,
Jake
October 16, 2018 at 6:32 pm
vuiis-sysadmin
SubscriberSure wish Ansys could stay consistent in port number and syntax.
VENDOR ansyslmd PORT=2700
VENDOR ansyslmd 2700
Looks like this year it is VENDOR ansyslmd PORT=1056
Thanks for your assistance.
October 17, 2018 at 1:53 pm
ANSYS_MMadore
Ansys EmployeeHello,
The choice of port for the vendor is actually made by the customer, it's not dictated by ANSYS. The syntax should always be PORT= when setting a static vendor port, which is and has always been the standard syntax used for flexlm based licensing.
Thank you,
Matt
October 17, 2018 at 2:17 pm
vuiis-sysadmin
SubscriberIs there a limit on what version of AnsysEM will work with the latest license?
I have a user with version 15 that is getting a -17 error when trying to run HFSS.
Bruce
October 17, 2018 at 2:25 pm
JakeC
Ansys EmployeeHi,
Yes, I believe 16.2 is the earliest version you can use.
Thank you,
Jake
- Workbench error
- Workbench not opening
- License Error
2524
2066
1279
1096
459
