September 24, 2023 at 6:14 pm
Josias Eilers
SubscriberI need b2h6 for a fluidsimulation, but it is not icluded in the fluent database. Does somebody have the needed properties for b2h6? Or can give me an advice where to find them?
September 25, 2023 at 6:47 am
SRP
Ansys EmployeeHi,
You can add material with its properties in the fluent through setup-material.
For more details please refer to user's guide: 8.1. Defining Materials (ansys.com)
Thank you.
September 25, 2023 at 9:28 am
Forum ModeratorAs for finding the material properties, you may find an internet search or trip to the chemistry department is required. If you're mixing it with air/oxident you may also want to read up on how it reacts as the default combustion/reaction models may not be entirely suitable.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
