August 28, 2023 at 5:55 pm
August 29, 2023 at 9:11 pm
mjmiddle
Ansys EmployeeYou have specified to remesh with a mesh quality metric allowing a maximum element angle of 90 degrees. The remesh resulted in a worst element angle of 158.4374 degrees which is not an improvement over the worst angle of 90.0778 before the remesh, so it rejected the remesh, and used the mesh before this.
The strategy is to remesh early and often, before the body gets too deformed, or else it may not remesh with an acceptable quality. So you may need to increase the rate at which is checks so that it checks earlier. Allowing a max angle of 90 seems a bit stringent considering the default to check is 155 degrees for volume elements. But if you increase the metric it's going to mesh later in the process. Maybe you need to view how distorted the mesh is right at that substep where it starts to remesh.
You need a body with enough bulk volume to use nonlinear adaptive region. Thin bodies may not allow enough room to refine mesh especially if connected to another body in a multibody part (mesh connected).
August 30, 2023 at 10:25 pm
Yunpeng Wu
Subscriber- When I tried to do a max angle of 155 degrees, the command didn't drive the remesh, even 100 degrees, the remesh can't happens, and the maxium to start the remesh is 90 degree.
- This structure is a plane, 100*100 elements, and each element is a 1*1 square, when I use the same material for all the elements, it can converge without remesh, but if I choose to use 2 different materials, the non-linear process can't converge.
Do you have any idea about why this problem happens?
The code is shown below:
FINISH
/CLEAR*do,fid,1,1
/PREP7
!=== Define material 1
ET,1,PLANE182MP,EX,1,2000
MP,PRXY,1,0.3!==== Define material 2
ET,2,PLANE182
MP,EX,2,1000
MP,PRXY,2,0.3/PREP7
NDELE,ALL
EDELE,ALL
DDELE,ALL,ALL
NUMCMP,ALL!NLADAPTIVE,ALL,ADD,MESH,SKEWNESS,0.9
*set,ntb
*set,etbfilename=strcat('nodes',chrval(fid))
fext='dat'/INQUIRE,rows1,LINES,%filename%,%fext%
*DIM,ntb,ARRAY,rows1,4
*VREAD,ntb,%filename%,%fext%,,JIK,4,rows1
(4F6.0) !* read 4 real numbers with maximum 6 digits, use 6 if number is 10000filename=strcat('elements',chrval(fid))
/INQUIRE,rows2,LINES,%filename%,%fext%
*DIM,etb,ARRAY,rows2,5
*VREAD,etb,%filename%,%fext%,,JIK,5,rows2
(5F6.0)*do,i,1,rows1
n,ntb(i,1),ntb(i,2),ntb(i,3),ntb(i,4)
*enddo
*do,i,1,rows2
e,etb(i,1),etb(i,2),etb(i,3),etb(i,4)
*enddo!=== Define element group 1
k=0
nElements=1
*do,i,1,rows2
nElements=nElements+1
*if,etb(i,5),eq,1,then
k=k+1
*endif
*enddo*status,k
*status,nElementsESEL,S,elem,,1,k
MPCHG,1,ALL
CM,MATRIX,ELEMESEL,S,ELEM,,k+1,nElements
MPCHG,2,ALL
CM,FILLER,ELEM/SOL
ANTYPE,0,NEW
NLGEOM,1
NSUBST,1000,2000,10
AUTOTS,-1.0ALLSEL,ALL
NSEL,S,LOC,X,0
D,ALL,UX,0NSEL,S,LOC,Y,0
D,ALL,UY,0NSEL,S,LOC,Y,100
CP,NEXT,UY,ALL
ALLSEL,ALLfilename=strcat('nlist',chrval(fid))
/INQUIRE,rows3,LINES,%filename%,%fext%
*DIM,ctb,ARRAY,rows3,3
*VREAD,ctb,%filename%,%fext%,,JIK,3,rows3
(3F6.0)!=== couple top and bottom nodes for UX
*do,i,1,rows3
CP,NEXT,UX,ctb(i,2),ctb(i,3)
*enddo
*do,i,1,1 !* loop over three displacements
/SOL
u=100*iNSEL,S,LOC,X,100
D,ALL,UX,u
ANTYPE,0
NLGEOM,1
!AUTOTS,ON
!DTIME,0.01,0.00001,0.1
!ARCLEN,ON
NSUBST,1000,2000,10NLADAPTIVE,ALL,ADD,MESH,SHAPE,155
NLMESH,BDRA,50!CUTCONTROL,DSPLIMIT,10e7
ALLSEL,ALL
SOLVE
FINISH/POST1
PLDISP,1NSEL,S,LOC,X,0
set,LAST
fsum
*get,fsum,FSUM,0,ITEM,Fx
force=fsumfilename=strcat('res',chrval(fid))
*if,i,eq,1,then
*cfopen,%filename%,txt,,
*else
*cfopen,%filename%,txt,,APPEND
*endif*vwrite,u,force
(G16.8,G16.8)
*cfclose
tempname=strcat(chrval(fid),'-')
tempname=strcat(tempname,chrval(i))
filename=strcat('nodal_stress_x',tempname)
*do,xid,1,rows1
*set,strx
*GET,strx, node,xid,s,X
*vwrite,strx
(G16.8)
*enddo
*cfclosefilename=strcat('nodal_stress_y',tempname)
*do,xid,1,rows1
*set,stry
*GET,stry, node,xid,s,Y
*vwrite,stry
(G16.8)
*enddo
*cfclosefilename=strcat('nodal_stress_xy',tempname)
*do,xid,1,rows1
*set,strxy
*GET,strxy, node,xid,s,XY
*vwrite,strxy
(G16.8)
*enddo
*cfclose
FINISH
*enddo
/CLEAR
*enddo !* end of outer loop
August 31, 2023 at 3:57 pm
Bill Bulat
Ansys EmployeeHi Yunpeng,
Your input does not run without "nodes1.dat" file. If it helps, I once created the 3D test case below that works (it solves in less than a minute). It does not use element mesh metrics as a criterion for remeshing. Instead, it uses element energy.
fini/cle/sys,del file*.png/vup,1,z/vie,1,3,2,1C***************************************************C*** PARAMETERSC***************************************************k_nlad=1l=0.100w=0.040t=0.010r=0.015x_cut=1.5*rE=2e11Sy=E/100E2=E/25nu=0.3theta_pilot=15*(acos(-1)/180)C***************************************************C*** MODELC***************************************************/prep7n,1,l/2 ! PILOT NODEbloc,-l/2,l/2,-w/2,w/2,-t/2,t/2 ! GEOMETRYcyli,,r,-t/2,t/2vsbv,1,2wpcs,-1,0wpro,,,90wpof,,,x_cutvsbw,allwpof,,,-2*x_cutvsbw,allvploet,1,185 ! ATTRIBUTES, MESHmp,ex,1,Etb,plastic,1,,,bisotbdata,,Sy,E2mp,nuxy,1,nuvswe,allC*******************************************************************C*** CREATE MPC CONTACT w/PILOT NODEC********************************************************************get,etmax,etype,,num,max*get,mpmax,mat,,num,max*get,rmax,real,,num,max*get,secmax,secp,,num,maxattrmax=max(etmax,max(mpmax,max(secmax,rmax)))C*******************************************************************C*** DEFINE CONTACT ATTRIBUTESC*******************************************************************et,attrmax+1,174 ! CONTACT ELEMENT TYPE (ON BEAM TIP)keyo,attrmax+1,4,1 ! FORCE DISTRIBUTEDkeyo,attrmax+1,2,2 ! MPCkeyo,attrmax+1,12,5 ! BONDEDet,attrmax+2,170 ! TARGET ELEMENT TYPE (PILOT NODE)keyo,attrmax+2,2,1 ! USER SPECIFIED PILOT NODE CONSTRAINTkeyo,attrmax+2,5,3 ! SHELL-SOLIDtshap,pilot ! TARGET SHAPE (PILOT NODE)C*******************************************************************C*** DEFINE REMOTE POINTC*******************************************************************real,attrmax+1type,attrmax+2 ! DEFINE TARGET PILOT ELEMENT (REMOTE POINT)nsel,s,node,,1cm,pilot_n,nodend1=1e,1C*******************************************************************C*** PROMPT USER TO SELECT AREA(S) TO BOND TO PILOT NODEC*******************************************************************nsel,s,loc,x,l/2nsel,u,node,,1cm,contact_n,nodeeslntype,attrmax+1 ! OVERLAY BEAM TIP WITH CONTACT ELEMENTSesurfC*******************************************************************C*** DETERMINE PINBALLC*******************************************************************cmse,s,contact_n*get,nnds,node,,countnd=0pinball=0*do,i,1,nndscmse,s,contact_nnd2=ndnext(nd)cmse,a,pilot_npinball=max(pinball,distnd(nd1,nd2))*enddor,attrmax+1,,,,,,2*pinball ! PINBALLallsC*******************************************************************C*** APPLIED DISPLACEMENTSC*******************************************************************d,1,roty,theta_pilotnsel,s,loc,x,-l/2d,all,allC*******************************************************************C*** SOLVEC*******************************************************************et,11,187 ! TETRAHEDRAL ELEMENT TYPE FOR NLAD-ETCHG*if,k_nlad,eq,1,thenesel,s,type,,1cm,nlad_e,elem*elseif,k_nlad,eq,2,thenesel,s,cent,x,-x_cut,x_cutcm,nlad_e,elem*endiffini/solunladaptive,nlad_e,add,energy,mean,10nladaptive,nlad_e,on,,,-2,,,11nlge,onallssaveeplo/sho,png $eplo $/sho,close $/wait,2solvefiniC*******************************************************************C*** POST PROCESSC*******************************************************************/post1/edge,1,1plns,eppl,x,2/sho,png $plns,eppl,x,2 $/sho,close $/wait,2--Bill-
August 31, 2023 at 6:14 pm
Yunpeng Wu
SubscriberHello Bill
I appreciate your help. I will try the energy method.
I'm wondering if can you download the Google Drive link for the "nodes1.dat", "element1.dat" and "nlist1.dat" for running the code.
Here is the link:
https://drive.google.com/drive/folders/1jy9AVwywknckaawVl_8z1B_ofg_1Lfk-?usp=sharing
August 31, 2023 at 6:30 pm
Yunpeng Wu
SubscriberThe energy method still can't converge.
If you are unable to download, here is a 50*50 case, you can copy and create the files and run.
Really thank you again for the help.
APDL code for 50*50
FINISH
/CLEAR*do,fid,1,1
/PREP7
ET,1,PLANE182MP,EX,1,6e11
ET,2,PLANE182
MP,EX,2,1000
MP,PRXY,2,0.3/PREP7
NDELE,ALL
EDELE,ALL
DDELE,ALL,ALL
*set,ntb
*enddo
*do,i,1,rows2
k=0
nElements=1
*do,i,1,rows2
k=k+1
*endif
*enddo*status,k
MPCHG,1,ALL
MPCHG,2,ALL
CM,FILLER,ELEM/SOL
ANTYPE,0,NEW
NLGEOM,1
NSUBST,1000,2000,10
NSEL,S,LOC,X,0
D,ALL,UY,0NSEL,S,LOC,Y,50
CP,NEXT,UY,ALL
*do,i,1,rows3
*enddo
/SOL
u=200*iNSEL,S,LOC,X,50
D,ALL,UX,u
ANTYPE,0
NLGEOM,1
!AUTOTS,ON
!ARCLEN,ON
NSUBST,1000,2000,10!NLADAPTIVE,ALL,ADD,MESH,SHAPE,155
!NLMESH,BDRA,50!CUTCONTROL,DSPLIMIT,10e7
/solu
ALLSEL,ALL
SOLVE
FINISH/POST1
set,LAST
fsum
*if,i,eq,1,then
*else
(G16.8,G16.8)
*cfclose
*do,xid,1,rows1
*set,strx
*vwrite,strx
(G16.8)
*enddo
*do,xid,1,rows1
*set,stry
*vwrite,stry
(G16.8)
*enddo
*do,xid,1,rows1
*set,strxy
*vwrite,strxy
(G16.8)
*enddo
*cfclose
FINISH
*enddo
!/CLEAR
*enddo !* end of outer loopHere is the "nodes1.dat":
1,0,0,0
2,1,0,0
3,2,0,0
4,3,0,0
5,4,0,0
6,5,0,0
7,6,0,0
8,7,0,0
9,8,0,0
10,9,0,0
11,10,0,0
12,11,0,0
13,12,0,0
14,13,0,0
15,14,0,0
16,15,0,0
17,16,0,0
18,17,0,0
19,18,0,0
20,19,0,0
21,20,0,0
22,21,0,0
23,22,0,0
24,23,0,0
25,24,0,0
26,25,0,0
27,26,0,0
28,27,0,0
29,28,0,0
30,29,0,0
31,30,0,0
32,31,0,0
33,32,0,0
34,33,0,0
35,34,0,0
36,35,0,0
37,36,0,0
38,37,0,0
39,38,0,0
40,39,0,0
41,40,0,0
42,41,0,0
43,42,0,0
44,43,0,0
45,44,0,0
46,45,0,0
47,46,0,0
48,47,0,0
49,48,0,0
50,49,0,0
51,50,0,0
52,0,1,0
53,1,1,0
54,2,1,0
55,3,1,0
56,4,1,0
57,5,1,0
58,6,1,0
59,7,1,0
60,8,1,0
61,9,1,0
62,10,1,0
63,11,1,0
64,12,1,0
65,13,1,0
66,14,1,0
67,15,1,0
68,16,1,0
69,17,1,0
70,18,1,0
71,19,1,0
72,20,1,0
73,21,1,0
74,22,1,0
75,23,1,0
76,24,1,0
77,25,1,0
78,26,1,0
79,27,1,0
80,28,1,0
81,29,1,0
82,30,1,0
83,31,1,0
84,32,1,0
85,33,1,0
86,34,1,0
87,35,1,0
88,36,1,0
89,37,1,0
90,38,1,0
91,39,1,0
92,40,1,0
93,41,1,0
94,42,1,0
95,43,1,0
96,44,1,0
97,45,1,0
98,46,1,0
99,47,1,0
100,48,1,0
101,49,1,0
102,50,1,0
103,0,2,0
104,1,2,0
105,2,2,0
106,3,2,0
107,4,2,0
108,5,2,0
109,6,2,0
110,7,2,0
111,8,2,0
112,9,2,0
113,10,2,0
114,11,2,0
115,12,2,0
116,13,2,0
117,14,2,0
118,15,2,0
119,16,2,0
120,17,2,0
121,18,2,0
122,19,2,0
123,20,2,0
124,21,2,0
125,22,2,0
126,23,2,0
127,24,2,0
128,25,2,0
129,26,2,0
130,27,2,0
131,28,2,0
132,29,2,0
133,30,2,0
134,31,2,0
135,32,2,0
136,33,2,0
137,34,2,0
138,35,2,0
139,36,2,0
140,37,2,0
141,38,2,0
142,39,2,0
143,40,2,0
144,41,2,0
145,42,2,0
146,43,2,0
147,44,2,0
148,45,2,0
149,46,2,0
150,47,2,0
151,48,2,0
152,49,2,0
153,50,2,0
154,0,3,0
155,1,3,0
156,2,3,0
157,3,3,0
158,4,3,0
159,5,3,0
160,6,3,0
161,7,3,0
162,8,3,0
163,9,3,0
164,10,3,0
165,11,3,0
166,12,3,0
167,13,3,0
168,14,3,0
169,15,3,0
170,16,3,0
171,17,3,0
172,18,3,0
173,19,3,0
174,20,3,0
175,21,3,0
176,22,3,0
177,23,3,0
178,24,3,0
179,25,3,0
180,26,3,0
181,27,3,0
182,28,3,0
183,29,3,0
184,30,3,0
185,31,3,0
186,32,3,0
187,33,3,0
188,34,3,0
189,35,3,0
190,36,3,0
191,37,3,0
192,38,3,0
193,39,3,0
194,40,3,0
195,41,3,0
196,42,3,0
197,43,3,0
198,44,3,0
199,45,3,0
200,46,3,0
201,47,3,0
202,48,3,0
203,49,3,0
204,50,3,0
205,0,4,0
206,1,4,0
207,2,4,0
208,3,4,0
209,4,4,0
210,5,4,0
211,6,4,0
212,7,4,0
213,8,4,0
214,9,4,0
215,10,4,0
216,11,4,0
217,12,4,0
218,13,4,0
219,14,4,0
220,15,4,0
221,16,4,0
222,17,4,0
223,18,4,0
224,19,4,0
225,20,4,0
226,21,4,0
227,22,4,0
228,23,4,0
229,24,4,0
230,25,4,0
231,26,4,0
232,27,4,0
233,28,4,0
234,29,4,0
235,30,4,0
236,31,4,0
237,32,4,0
238,33,4,0
239,34,4,0
240,35,4,0
241,36,4,0
242,37,4,0
243,38,4,0
244,39,4,0
245,40,4,0
246,41,4,0
247,42,4,0
248,43,4,0
249,44,4,0
250,45,4,0
251,46,4,0
252,47,4,0
253,48,4,0
254,49,4,0
255,50,4,0
256,0,5,0
257,1,5,0
258,2,5,0
259,3,5,0
260,4,5,0
261,5,5,0
262,6,5,0
263,7,5,0
264,8,5,0
265,9,5,0
266,10,5,0
267,11,5,0
268,12,5,0
269,13,5,0
270,14,5,0
271,15,5,0
272,16,5,0
273,17,5,0
274,18,5,0
275,19,5,0
276,20,5,0
277,21,5,0
278,22,5,0
279,23,5,0
280,24,5,0
281,25,5,0
282,26,5,0
283,27,5,0
284,28,5,0
285,29,5,0
286,30,5,0
287,31,5,0
288,32,5,0
289,33,5,0
290,34,5,0
291,35,5,0
292,36,5,0
293,37,5,0
294,38,5,0
295,39,5,0
296,40,5,0
297,41,5,0
298,42,5,0
299,43,5,0
300,44,5,0
301,45,5,0
302,46,5,0
303,47,5,0
304,48,5,0
305,49,5,0
306,50,5,0
307,0,6,0
308,1,6,0
309,2,6,0
310,3,6,0
311,4,6,0
312,5,6,0
313,6,6,0
314,7,6,0
315,8,6,0
316,9,6,0
317,10,6,0
318,11,6,0
319,12,6,0
320,13,6,0
321,14,6,0
322,15,6,0
323,16,6,0
324,17,6,0
325,18,6,0
326,19,6,0
327,20,6,0
328,21,6,0
329,22,6,0
330,23,6,0
331,24,6,0
332,25,6,0
333,26,6,0
334,27,6,0
335,28,6,0
336,29,6,0
337,30,6,0
338,31,6,0
339,32,6,0
340,33,6,0
341,34,6,0
342,35,6,0
343,36,6,0
344,37,6,0
345,38,6,0
346,39,6,0
347,40,6,0
348,41,6,0
349,42,6,0
350,43,6,0
351,44,6,0
352,45,6,0
353,46,6,0
354,47,6,0
355,48,6,0
356,49,6,0
357,50,6,0
358,0,7,0
359,1,7,0
360,2,7,0
361,3,7,0
362,4,7,0
363,5,7,0
364,6,7,0
365,7,7,0
366,8,7,0
367,9,7,0
368,10,7,0
369,11,7,0
370,12,7,0
371,13,7,0
372,14,7,0
373,15,7,0
374,16,7,0
375,17,7,0
376,18,7,0
377,19,7,0
378,20,7,0
379,21,7,0
380,22,7,0
381,23,7,0
382,24,7,0
383,25,7,0
384,26,7,0
385,27,7,0
386,28,7,0
387,29,7,0
388,30,7,0
389,31,7,0
390,32,7,0
391,33,7,0
392,34,7,0
393,35,7,0
394,36,7,0
395,37,7,0
396,38,7,0
397,39,7,0
398,40,7,0
399,41,7,0
400,42,7,0
401,43,7,0
402,44,7,0
403,45,7,0
404,46,7,0
405,47,7,0
406,48,7,0
407,49,7,0
408,50,7,0
409,0,8,0
410,1,8,0
411,2,8,0
412,3,8,0
413,4,8,0
414,5,8,0
415,6,8,0
416,7,8,0
417,8,8,0
418,9,8,0
419,10,8,0
420,11,8,0
421,12,8,0
422,13,8,0
423,14,8,0
424,15,8,0
425,16,8,0
426,17,8,0
427,18,8,0
428,19,8,0
429,20,8,0
430,21,8,0
431,22,8,0
432,23,8,0
433,24,8,0
434,25,8,0
435,26,8,0
436,27,8,0
437,28,8,0
438,29,8,0
439,30,8,0
440,31,8,0
441,32,8,0
442,33,8,0
443,34,8,0
444,35,8,0
445,36,8,0
446,37,8,0
447,38,8,0
448,39,8,0
449,40,8,0
450,41,8,0
451,42,8,0
452,43,8,0
453,44,8,0
454,45,8,0
455,46,8,0
456,47,8,0
457,48,8,0
458,49,8,0
459,50,8,0
460,0,9,0
461,1,9,0
462,2,9,0
463,3,9,0
464,4,9,0
465,5,9,0
466,6,9,0
467,7,9,0
468,8,9,0
469,9,9,0
470,10,9,0
471,11,9,0
472,12,9,0
473,13,9,0
474,14,9,0
475,15,9,0
476,16,9,0
477,17,9,0
478,18,9,0
479,19,9,0
480,20,9,0
481,21,9,0
482,22,9,0
483,23,9,0
484,24,9,0
485,25,9,0
486,26,9,0
487,27,9,0
488,28,9,0
489,29,9,0
490,30,9,0
491,31,9,0
492,32,9,0
493,33,9,0
494,34,9,0
495,35,9,0
496,36,9,0
497,37,9,0
498,38,9,0
499,39,9,0
500,40,9,0
501,41,9,0
502,42,9,0
503,43,9,0
504,44,9,0
505,45,9,0
506,46,9,0
507,47,9,0
508,48,9,0
509,49,9,0
510,50,9,0
511,0,10,0
512,1,10,0
513,2,10,0
514,3,10,0
515,4,10,0
516,5,10,0
517,6,10,0
518,7,10,0
519,8,10,0
520,9,10,0
521,10,10,0
522,11,10,0
523,12,10,0
524,13,10,0
525,14,10,0
526,15,10,0
527,16,10,0
528,17,10,0
529,18,10,0
530,19,10,0
531,20,10,0
532,21,10,0
533,22,10,0
534,23,10,0
535,24,10,0
536,25,10,0
537,26,10,0
538,27,10,0
539,28,10,0
540,29,10,0
541,30,10,0
542,31,10,0
543,32,10,0
544,33,10,0
545,34,10,0
546,35,10,0
547,36,10,0
548,37,10,0
549,38,10,0
550,39,10,0
551,40,10,0
552,41,10,0
553,42,10,0
554,43,10,0
555,44,10,0
556,45,10,0
557,46,10,0
558,47,10,0
559,48,10,0
560,49,10,0
561,50,10,0
562,0,11,0
563,1,11,0
564,2,11,0
565,3,11,0
566,4,11,0
567,5,11,0
568,6,11,0
569,7,11,0
570,8,11,0
571,9,11,0
572,10,11,0
573,11,11,0
574,12,11,0
575,13,11,0
576,14,11,0
577,15,11,0
578,16,11,0
579,17,11,0
580,18,11,0
581,19,11,0
582,20,11,0
583,21,11,0
584,22,11,0
585,23,11,0
586,24,11,0
587,25,11,0
588,26,11,0
589,27,11,0
590,28,11,0
591,29,11,0
592,30,11,0
593,31,11,0
594,32,11,0
595,33,11,0
596,34,11,0
597,35,11,0
598,36,11,0
599,37,11,0
600,38,11,0
601,39,11,0
602,40,11,0
603,41,11,0
604,42,11,0
605,43,11,0
606,44,11,0
607,45,11,0
608,46,11,0
609,47,11,0
610,48,11,0
611,49,11,0
612,50,11,0
613,0,12,0
614,1,12,0
615,2,12,0
616,3,12,0
617,4,12,0
618,5,12,0
619,6,12,0
620,7,12,0
621,8,12,0
622,9,12,0
623,10,12,0
624,11,12,0
625,12,12,0
626,13,12,0
627,14,12,0
628,15,12,0
629,16,12,0
630,17,12,0
631,18,12,0
632,19,12,0
633,20,12,0
634,21,12,0
635,22,12,0
636,23,12,0
637,24,12,0
638,25,12,0
639,26,12,0
640,27,12,0
641,28,12,0
642,29,12,0
643,30,12,0
644,31,12,0
645,32,12,0
646,33,12,0
647,34,12,0
648,35,12,0
649,36,12,0
650,37,12,0
651,38,12,0
652,39,12,0
653,40,12,0
654,41,12,0
655,42,12,0
656,43,12,0
657,44,12,0
658,45,12,0
659,46,12,0
660,47,12,0
661,48,12,0
662,49,12,0
663,50,12,0
664,0,13,0
665,1,13,0
666,2,13,0
667,3,13,0
668,4,13,0
669,5,13,0
670,6,13,0
671,7,13,0
672,8,13,0
673,9,13,0
674,10,13,0
675,11,13,0
676,12,13,0
677,13,13,0
678,14,13,0
679,15,13,0
680,16,13,0
681,17,13,0
682,18,13,0
683,19,13,0
684,20,13,0
685,21,13,0
686,22,13,0
687,23,13,0
688,24,13,0
689,25,13,0
690,26,13,0
691,27,13,0
692,28,13,0
693,29,13,0
694,30,13,0
695,31,13,0
696,32,13,0
697,33,13,0
698,34,13,0
699,35,13,0
700,36,13,0
701,37,13,0
702,38,13,0
703,39,13,0
704,40,13,0
705,41,13,0
706,42,13,0
707,43,13,0
708,44,13,0
709,45,13,0
710,46,13,0
711,47,13,0
712,48,13,0
713,49,13,0
714,50,13,0
715,0,14,0
716,1,14,0
717,2,14,0
718,3,14,0
719,4,14,0
720,5,14,0
721,6,14,0
722,7,14,0
723,8,14,0
724,9,14,0
725,10,14,0
726,11,14,0
727,12,14,0
728,13,14,0
729,14,14,0
730,15,14,0
731,16,14,0
732,17,14,0
733,18,14,0
734,19,14,0
735,20,14,0
736,21,14,0
737,22,14,0
738,23,14,0
739,24,14,0
740,25,14,0
741,26,14,0
742,27,14,0
743,28,14,0
744,29,14,0
745,30,14,0
746,31,14,0
747,32,14,0
748,33,14,0
749,34,14,0
750,35,14,0
751,36,14,0
752,37,14,0
753,38,14,0
754,39,14,0
755,40,14,0
756,41,14,0
757,42,14,0
758,43,14,0
759,44,14,0
760,45,14,0
761,46,14,0
762,47,14,0
763,48,14,0
764,49,14,0
765,50,14,0
766,0,15,0
767,1,15,0
768,2,15,0
769,3,15,0
770,4,15,0
771,5,15,0
772,6,15,0
773,7,15,0
774,8,15,0
775,9,15,0
776,10,15,0
777,11,15,0
778,12,15,0
779,13,15,0
780,14,15,0
781,15,15,0
782,16,15,0
783,17,15,0
784,18,15,0
785,19,15,0
786,20,15,0
787,21,15,0
788,22,15,0
789,23,15,0
790,24,15,0
791,25,15,0
792,26,15,0
793,27,15,0
794,28,15,0
795,29,15,0
796,30,15,0
797,31,15,0
798,32,15,0
799,33,15,0
800,34,15,0
801,35,15,0
802,36,15,0
803,37,15,0
804,38,15,0
805,39,15,0
806,40,15,0
807,41,15,0
808,42,15,0
809,43,15,0
810,44,15,0
811,45,15,0
812,46,15,0
813,47,15,0
814,48,15,0
815,49,15,0
816,50,15,0
817,0,16,0
818,1,16,0
819,2,16,0
820,3,16,0
821,4,16,0
822,5,16,0
823,6,16,0
824,7,16,0
825,8,16,0
826,9,16,0
827,10,16,0
828,11,16,0
829,12,16,0
830,13,16,0
831,14,16,0
832,15,16,0
833,16,16,0
834,17,16,0
835,18,16,0
836,19,16,0
837,20,16,0
838,21,16,0
839,22,16,0
840,23,16,0
841,24,16,0
842,25,16,0
843,26,16,0
844,27,16,0
845,28,16,0
846,29,16,0
847,30,16,0
848,31,16,0
849,32,16,0
850,33,16,0
851,34,16,0
852,35,16,0
853,36,16,0
854,37,16,0
855,38,16,0
856,39,16,0
857,40,16,0
858,41,16,0
859,42,16,0
860,43,16,0
861,44,16,0
862,45,16,0
863,46,16,0
864,47,16,0
865,48,16,0
866,49,16,0
867,50,16,0
868,0,17,0
869,1,17,0
870,2,17,0
871,3,17,0
872,4,17,0
873,5,17,0
874,6,17,0
875,7,17,0
876,8,17,0
877,9,17,0
878,10,17,0
879,11,17,0
880,12,17,0
881,13,17,0
882,14,17,0
883,15,17,0
884,16,17,0
885,17,17,0
886,18,17,0
887,19,17,0
888,20,17,0
889,21,17,0
890,22,17,0
891,23,17,0
892,24,17,0
893,25,17,0
894,26,17,0
895,27,17,0
896,28,17,0
897,29,17,0
898,30,17,0
899,31,17,0
900,32,17,0
901,33,17,0
902,34,17,0
903,35,17,0
904,36,17,0
905,37,17,0
906,38,17,0
907,39,17,0
908,40,17,0
909,41,17,0
910,42,17,0
911,43,17,0
912,44,17,0
913,45,17,0
914,46,17,0
915,47,17,0
916,48,17,0
917,49,17,0
918,50,17,0
919,0,18,0
920,1,18,0
921,2,18,0
922,3,18,0
923,4,18,0
924,5,18,0
925,6,18,0
926,7,18,0
927,8,18,0
928,9,18,0
929,10,18,0
930,11,18,0
931,12,18,0
932,13,18,0
933,14,18,0
934,15,18,0
935,16,18,0
936,17,18,0
937,18,18,0
938,19,18,0
939,20,18,0
940,21,18,0
941,22,18,0
942,23,18,0
943,24,18,0
944,25,18,0
945,26,18,0
946,27,18,0
947,28,18,0
948,29,18,0
949,30,18,0
950,31,18,0
951,32,18,0
952,33,18,0
953,34,18,0
954,35,18,0
955,36,18,0
956,37,18,0
957,38,18,0
958,39,18,0
959,40,18,0
960,41,18,0
961,42,18,0
962,43,18,0
963,44,18,0
964,45,18,0
965,46,18,0
966,47,18,0
967,48,18,0
968,49,18,0
969,50,18,0
970,0,19,0
971,1,19,0
972,2,19,0
973,3,19,0
974,4,19,0
975,5,19,0
976,6,19,0
977,7,19,0
978,8,19,0
979,9,19,0
980,10,19,0
981,11,19,0
982,12,19,0
983,13,19,0
984,14,19,0
985,15,19,0
986,16,19,0
987,17,19,0
988,18,19,0
989,19,19,0
990,20,19,0
991,21,19,0
992,22,19,0
993,23,19,0
994,24,19,0
995,25,19,0
996,26,19,0
997,27,19,0
998,28,19,0
999,29,19,0
1000,30,19,0
1001,31,19,0
1002,32,19,0
1003,33,19,0
1004,34,19,0
1005,35,19,0
1006,36,19,0
1007,37,19,0
1008,38,19,0
1009,39,19,0
1010,40,19,0
1011,41,19,0
1012,42,19,0
1013,43,19,0
1014,44,19,0
1015,45,19,0
1016,46,19,0
1017,47,19,0
1018,48,19,0
1019,49,19,0
1020,50,19,0
1021,0,20,0
1022,1,20,0
1023,2,20,0
1024,3,20,0
1025,4,20,0
1026,5,20,0
1027,6,20,0
1028,7,20,0
1029,8,20,0
1030,9,20,0
1031,10,20,0
1032,11,20,0
1033,12,20,0
1034,13,20,0
1035,14,20,0
1036,15,20,0
1037,16,20,0
1038,17,20,0
1039,18,20,0
1040,19,20,0
1041,20,20,0
1042,21,20,0
1043,22,20,0
1044,23,20,0
1045,24,20,0
1046,25,20,0
1047,26,20,0
1048,27,20,0
1049,28,20,0
1050,29,20,0
1051,30,20,0
1052,31,20,0
1053,32,20,0
1054,33,20,0
1055,34,20,0
1056,35,20,0
1057,36,20,0
1058,37,20,0
1059,38,20,0
1060,39,20,0
1061,40,20,0
1062,41,20,0
1063,42,20,0
1064,43,20,0
1065,44,20,0
1066,45,20,0
1067,46,20,0
1068,47,20,0
1069,48,20,0
1070,49,20,0
1071,50,20,0
1072,0,21,0
1073,1,21,0
1074,2,21,0
1075,3,21,0
1076,4,21,0
1077,5,21,0
1078,6,21,0
1079,7,21,0
1080,8,21,0
1081,9,21,0
1082,10,21,0
1083,11,21,0
1084,12,21,0
1085,13,21,0
1086,14,21,0
1087,15,21,0
1088,16,21,0
1089,17,21,0
1090,18,21,0
1091,19,21,0
1092,20,21,0
1093,21,21,0
1094,22,21,0
1095,23,21,0
1096,24,21,0
1097,25,21,0
1098,26,21,0
1099,27,21,0
1100,28,21,0
1101,29,21,0
1102,30,21,0
1103,31,21,0
1104,32,21,0
1105,33,21,0
1106,34,21,0
1107,35,21,0
1108,36,21,0
1109,37,21,0
1110,38,21,0
1111,39,21,0
1112,40,21,0
1113,41,21,0
1114,42,21,0
1115,43,21,0
1116,44,21,0
1117,45,21,0
1118,46,21,0
1119,47,21,0
1120,48,21,0
1121,49,21,0
1122,50,21,0
1123,0,22,0
1124,1,22,0
1125,2,22,0
1126,3,22,0
1127,4,22,0
1128,5,22,0
1129,6,22,0
1130,7,22,0
1131,8,22,0
1132,9,22,0
1133,10,22,0
1134,11,22,0
1135,12,22,0
1136,13,22,0
1137,14,22,0
1138,15,22,0
1139,16,22,0
1140,17,22,0
1141,18,22,0
1142,19,22,0
1143,20,22,0
1144,21,22,0
1145,22,22,0
1146,23,22,0
1147,24,22,0
1148,25,22,0
1149,26,22,0
1150,27,22,0
1151,28,22,0
1152,29,22,0
1153,30,22,0
1154,31,22,0
1155,32,22,0
1156,33,22,0
1157,34,22,0
1158,35,22,0
1159,36,22,0
1160,37,22,0
1161,38,22,0
1162,39,22,0
1163,40,22,0
1164,41,22,0
1165,42,22,0
1166,43,22,0
1167,44,22,0
1168,45,22,0
1169,46,22,0
1170,47,22,0
1171,48,22,0
1172,49,22,0
1173,50,22,0
1174,0,23,0
1175,1,23,0
1176,2,23,0
1177,3,23,0
1178,4,23,0
1179,5,23,0
1180,6,23,0
1181,7,23,0
1182,8,23,0
1183,9,23,0
1184,10,23,0
1185,11,23,0
1186,12,23,0
1187,13,23,0
1188,14,23,0
1189,15,23,0
1190,16,23,0
1191,17,23,0
1192,18,23,0
1193,19,23,0
1194,20,23,0
1195,21,23,0
1196,22,23,0
1197,23,23,0
1198,24,23,0
1199,25,23,0
1200,26,23,0
1201,27,23,0
1202,28,23,0
1203,29,23,0
1204,30,23,0
1205,31,23,0
1206,32,23,0
1207,33,23,0
1208,34,23,0
1209,35,23,0
1210,36,23,0
1211,37,23,0
1212,38,23,0
1213,39,23,0
1214,40,23,0
1215,41,23,0
1216,42,23,0
1217,43,23,0
1218,44,23,0
1219,45,23,0
1220,46,23,0
1221,47,23,0
1222,48,23,0
1223,49,23,0
1224,50,23,0
1225,0,24,0
1226,1,24,0
1227,2,24,0
1228,3,24,0
1229,4,24,0
1230,5,24,0
1231,6,24,0
1232,7,24,0
1233,8,24,0
1234,9,24,0
1235,10,24,0
1236,11,24,0
1237,12,24,0
1238,13,24,0
1239,14,24,0
1240,15,24,0
1241,16,24,0
1242,17,24,0
1243,18,24,0
1244,19,24,0
1245,20,24,0
1246,21,24,0
1247,22,24,0
1248,23,24,0
1249,24,24,0
1250,25,24,0
1251,26,24,0
1252,27,24,0
1253,28,24,0
1254,29,24,0
1255,30,24,0
1256,31,24,0
1257,32,24,0
1258,33,24,0
1259,34,24,0
1260,35,24,0
1261,36,24,0
1262,37,24,0
1263,38,24,0
1264,39,24,0
1265,40,24,0
1266,41,24,0
1267,42,24,0
1268,43,24,0
1269,44,24,0
1270,45,24,0
1271,46,24,0
1272,47,24,0
1273,48,24,0
1274,49,24,0
1275,50,24,0
1276,0,25,0
1277,1,25,0
1278,2,25,0
1279,3,25,0
1280,4,25,0
1281,5,25,0
1282,6,25,0
1283,7,25,0
1284,8,25,0
1285,9,25,0
1286,10,25,0
1287,11,25,0
1288,12,25,0
1289,13,25,0
1290,14,25,0
1291,15,25,0
1292,16,25,0
1293,17,25,0
1294,18,25,0
1295,19,25,0
1296,20,25,0
1297,21,25,0
1298,22,25,0
1299,23,25,0
1300,24,25,0
1301,25,25,0
1302,26,25,0
1303,27,25,0
1304,28,25,0
1305,29,25,0
1306,30,25,0
1307,31,25,0
1308,32,25,0
1309,33,25,0
1310,34,25,0
1311,35,25,0
1312,36,25,0
1313,37,25,0
1314,38,25,0
1315,39,25,0
1316,40,25,0
1317,41,25,0
1318,42,25,0
1319,43,25,0
1320,44,25,0
1321,45,25,0
1322,46,25,0
1323,47,25,0
1324,48,25,0
1325,49,25,0
1326,50,25,0
1327,0,26,0
1328,1,26,0
1329,2,26,0
1330,3,26,0
1331,4,26,0
1332,5,26,0
1333,6,26,0
1334,7,26,0
1335,8,26,0
1336,9,26,0
1337,10,26,0
1338,11,26,0
1339,12,26,0
1340,13,26,0
1341,14,26,0
1342,15,26,0
1343,16,26,0
1344,17,26,0
1345,18,26,0
1346,19,26,0
1347,20,26,0
1348,21,26,0
1349,22,26,0
1350,23,26,0
1351,24,26,0
1352,25,26,0
1353,26,26,0
1354,27,26,0
1355,28,26,0
1356,29,26,0
1357,30,26,0
1358,31,26,0
1359,32,26,0
1360,33,26,0
1361,34,26,0
1362,35,26,0
1363,36,26,0
1364,37,26,0
1365,38,26,0
1366,39,26,0
1367,40,26,0
1368,41,26,0
1369,42,26,0
1370,43,26,0
1371,44,26,0
1372,45,26,0
1373,46,26,0
1374,47,26,0
1375,48,26,0
1376,49,26,0
1377,50,26,0
1378,0,27,0
1379,1,27,0
1380,2,27,0
1381,3,27,0
1382,4,27,0
1383,5,27,0
1384,6,27,0
1385,7,27,0
1386,8,27,0
1387,9,27,0
1388,10,27,0
1389,11,27,0
1390,12,27,0
1391,13,27,0
1392,14,27,0
1393,15,27,0
1394,16,27,0
1395,17,27,0
1396,18,27,0
1397,19,27,0
1398,20,27,0
1399,21,27,0
1400,22,27,0
1401,23,27,0
1402,24,27,0
1403,25,27,0
1404,26,27,0
1405,27,27,0
1406,28,27,0
1407,29,27,0
1408,30,27,0
1409,31,27,0
1410,32,27,0
1411,33,27,0
1412,34,27,0
1413,35,27,0
1414,36,27,0
1415,37,27,0
1416,38,27,0
1417,39,27,0
1418,40,27,0
1419,41,27,0
1420,42,27,0
1421,43,27,0
1422,44,27,0
1423,45,27,0
1424,46,27,0
1425,47,27,0
1426,48,27,0
1427,49,27,0
1428,50,27,0
1429,0,28,0
1430,1,28,0
1431,2,28,0
1432,3,28,0
1433,4,28,0
1434,5,28,0
1435,6,28,0
1436,7,28,0
1437,8,28,0
1438,9,28,0
1439,10,28,0
1440,11,28,0
1441,12,28,0
1442,13,28,0
1443,14,28,0
1444,15,28,0
1445,16,28,0
1446,17,28,0
1447,18,28,0
1448,19,28,0
1449,20,28,0
1450,21,28,0
1451,22,28,0
1452,23,28,0
1453,24,28,0
1454,25,28,0
1455,26,28,0
1456,27,28,0
1457,28,28,0
1458,29,28,0
1459,30,28,0
1460,31,28,0
1461,32,28,0
1462,33,28,0
1463,34,28,0
1464,35,28,0
1465,36,28,0
1466,37,28,0
1467,38,28,0
1468,39,28,0
1469,40,28,0
1470,41,28,0
1471,42,28,0
1472,43,28,0
1473,44,28,0
1474,45,28,0
1475,46,28,0
1476,47,28,0
1477,48,28,0
1478,49,28,0
1479,50,28,0
1480,0,29,0
1481,1,29,0
1482,2,29,0
1483,3,29,0
1484,4,29,0
1485,5,29,0
1486,6,29,0
1487,7,29,0
1488,8,29,0
1489,9,29,0
1490,10,29,0
1491,11,29,0
1492,12,29,0
1493,13,29,0
1494,14,29,0
1495,15,29,0
1496,16,29,0
1497,17,29,0
1498,18,29,0
1499,19,29,0
1500,20,29,0
1501,21,29,0
1502,22,29,0
1503,23,29,0
1504,24,29,0
1505,25,29,0
1506,26,29,0
1507,27,29,0
1508,28,29,0
1509,29,29,0
1510,30,29,0
1511,31,29,0
1512,32,29,0
1513,33,29,0
1514,34,29,0
1515,35,29,0
1516,36,29,0
1517,37,29,0
1518,38,29,0
1519,39,29,0
1520,40,29,0
1521,41,29,0
1522,42,29,0
1523,43,29,0
1524,44,29,0
1525,45,29,0
1526,46,29,0
1527,47,29,0
1528,48,29,0
1529,49,29,0
1530,50,29,0
1531,0,30,0
1532,1,30,0
1533,2,30,0
1534,3,30,0
1535,4,30,0
1536,5,30,0
1537,6,30,0
1538,7,30,0
1539,8,30,0
1540,9,30,0
1541,10,30,0
1542,11,30,0
1543,12,30,0
1544,13,30,0
1545,14,30,0
1546,15,30,0
1547,16,30,0
1548,17,30,0
1549,18,30,0
1550,19,30,0
1551,20,30,0
1552,21,30,0
1553,22,30,0
1554,23,30,0
1555,24,30,0
1556,25,30,0
1557,26,30,0
1558,27,30,0
1559,28,30,0
1560,29,30,0
1561,30,30,0
1562,31,30,0
1563,32,30,0
1564,33,30,0
1565,34,30,0
1566,35,30,0
1567,36,30,0
1568,37,30,0
1569,38,30,0
1570,39,30,0
1571,40,30,0
1572,41,30,0
1573,42,30,0
1574,43,30,0
1575,44,30,0
1576,45,30,0
1577,46,30,0
1578,47,30,0
1579,48,30,0
1580,49,30,0
1581,50,30,0
1582,0,31,0
1583,1,31,0
1584,2,31,0
1585,3,31,0
1586,4,31,0
1587,5,31,0
1588,6,31,0
1589,7,31,0
1590,8,31,0
1591,9,31,0
1592,10,31,0
1593,11,31,0
1594,12,31,0
1595,13,31,0
1596,14,31,0
1597,15,31,0
1598,16,31,0
1599,17,31,0
1600,18,31,0
1601,19,31,0
1602,20,31,0
1603,21,31,0
1604,22,31,0
1605,23,31,0
1606,24,31,0
1607,25,31,0
1608,26,31,0
1609,27,31,0
1610,28,31,0
1611,29,31,0
1612,30,31,0
1613,31,31,0
1614,32,31,0
1615,33,31,0
1616,34,31,0
1617,35,31,0
1618,36,31,0
1619,37,31,0
1620,38,31,0
1621,39,31,0
1622,40,31,0
1623,41,31,0
1624,42,31,0
1625,43,31,0
1626,44,31,0
1627,45,31,0
1628,46,31,0
1629,47,31,0
1630,48,31,0
1631,49,31,0
1632,50,31,0
1633,0,32,0
1634,1,32,0
1635,2,32,0
1636,3,32,0
1637,4,32,0
1638,5,32,0
1639,6,32,0
1640,7,32,0
1641,8,32,0
1642,9,32,0
1643,10,32,0
1644,11,32,0
1645,12,32,0
1646,13,32,0
1647,14,32,0
1648,15,32,0
1649,16,32,0
1650,17,32,0
1651,18,32,0
1652,19,32,0
1653,20,32,0
1654,21,32,0
1655,22,32,0
1656,23,32,0
1657,24,32,0
1658,25,32,0
1659,26,32,0
1660,27,32,0
1661,28,32,0
1662,29,32,0
1663,30,32,0
1664,31,32,0
1665,32,32,0
1666,33,32,0
1667,34,32,0
1668,35,32,0
1669,36,32,0
1670,37,32,0
1671,38,32,0
1672,39,32,0
1673,40,32,0
1674,41,32,0
1675,42,32,0
1676,43,32,0
1677,44,32,0
1678,45,32,0
1679,46,32,0
1680,47,32,0
1681,48,32,0
1682,49,32,0
1683,50,32,0
1684,0,33,0
1685,1,33,0
1686,2,33,0
1687,3,33,0
1688,4,33,0
1689,5,33,0
1690,6,33,0
1691,7,33,0
1692,8,33,0
1693,9,33,0
1694,10,33,0
1695,11,33,0
1696,12,33,0
1697,13,33,0
1698,14,33,0
1699,15,33,0
1700,16,33,0
1701,17,33,0
1702,18,33,0
1703,19,33,0
1704,20,33,0
1705,21,33,0
1706,22,33,0
1707,23,33,0
1708,24,33,0
1709,25,33,0
1710,26,33,0
1711,27,33,0
1712,28,33,0
1713,29,33,0
1714,30,33,0
1715,31,33,0
1716,32,33,0
1717,33,33,0
1718,34,33,0
1719,35,33,0
1720,36,33,0
1721,37,33,0
1722,38,33,0
1723,39,33,0
1724,40,33,0
1725,41,33,0
1726,42,33,0
1727,43,33,0
1728,44,33,0
1729,45,33,0
1730,46,33,0
1731,47,33,0
1732,48,33,0
1733,49,33,0
1734,50,33,0
1735,0,34,0
1736,1,34,0
1737,2,34,0
1738,3,34,0
1739,4,34,0
1740,5,34,0
1741,6,34,0
1742,7,34,0
1743,8,34,0
1744,9,34,0
1745,10,34,0
1746,11,34,0
1747,12,34,0
1748,13,34,0
1749,14,34,0
1750,15,34,0
1751,16,34,0
1752,17,34,0
1753,18,34,0
1754,19,34,0
1755,20,34,0
1756,21,34,0
1757,22,34,0
1758,23,34,0
1759,24,34,0
1760,25,34,0
1761,26,34,0
1762,27,34,0
1763,28,34,0
1764,29,34,0
1765,30,34,0
1766,31,34,0
1767,32,34,0
1768,33,34,0
1769,34,34,0
1770,35,34,0
1771,36,34,0
1772,37,34,0
1773,38,34,0
1774,39,34,0
1775,40,34,0
1776,41,34,0
1777,42,34,0
1778,43,34,0
1779,44,34,0
1780,45,34,0
1781,46,34,0
1782,47,34,0
1783,48,34,0
1784,49,34,0
1785,50,34,0
1786,0,35,0
1787,1,35,0
1788,2,35,0
1789,3,35,0
1790,4,35,0
1791,5,35,0
1792,6,35,0
1793,7,35,0
1794,8,35,0
1795,9,35,0
1796,10,35,0
1797,11,35,0
1798,12,35,0
1799,13,35,0
1800,14,35,0
1801,15,35,0
1802,16,35,0
1803,17,35,0
1804,18,35,0
1805,19,35,0
1806,20,35,0
1807,21,35,0
1808,22,35,0
1809,23,35,0
1810,24,35,0
1811,25,35,0
1812,26,35,0
1813,27,35,0
1814,28,35,0
1815,29,35,0
1816,30,35,0
1817,31,35,0
1818,32,35,0
1819,33,35,0
1820,34,35,0
1821,35,35,0
1822,36,35,0
1823,37,35,0
1824,38,35,0
1825,39,35,0
1826,40,35,0
1827,41,35,0
1828,42,35,0
1829,43,35,0
1830,44,35,0
1831,45,35,0
1832,46,35,0
1833,47,35,0
1834,48,35,0
1835,49,35,0
1836,50,35,0
1837,0,36,0
1838,1,36,0
1839,2,36,0
1840,3,36,0
1841,4,36,0
1842,5,36,0
1843,6,36,0
1844,7,36,0
1845,8,36,0
1846,9,36,0
1847,10,36,0
1848,11,36,0
1849,12,36,0
1850,13,36,0
1851,14,36,0
1852,15,36,0
1853,16,36,0
1854,17,36,0
1855,18,36,0
1856,19,36,0
1857,20,36,0
1858,21,36,0
1859,22,36,0
1860,23,36,0
1861,24,36,0
1862,25,36,0
1863,26,36,0
1864,27,36,0
1865,28,36,0
1866,29,36,0
1867,30,36,0
1868,31,36,0
1869,32,36,0
1870,33,36,0
1871,34,36,0
1872,35,36,0
1873,36,36,0
1874,37,36,0
1875,38,36,0
1876,39,36,0
1877,40,36,0
1878,41,36,0
1879,42,36,0
1880,43,36,0
1881,44,36,0
1882,45,36,0
1883,46,36,0
1884,47,36,0
1885,48,36,0
1886,49,36,0
1887,50,36,0
1888,0,37,0
1889,1,37,0
1890,2,37,0
1891,3,37,0
1892,4,37,0
1893,5,37,0
1894,6,37,0
1895,7,37,0
1896,8,37,0
1897,9,37,0
1898,10,37,0
1899,11,37,0
1900,12,37,0
1901,13,37,0
1902,14,37,0
1903,15,37,0
1904,16,37,0
1905,17,37,0
1906,18,37,0
1907,19,37,0
1908,20,37,0
1909,21,37,0
1910,22,37,0
1911,23,37,0
1912,24,37,0
1913,25,37,0
1914,26,37,0
1915,27,37,0
1916,28,37,0
1917,29,37,0
1918,30,37,0
1919,31,37,0
1920,32,37,0
1921,33,37,0
1922,34,37,0
1923,35,37,0
1924,36,37,0
1925,37,37,0
1926,38,37,0
1927,39,37,0
1928,40,37,0
1929,41,37,0
1930,42,37,0
1931,43,37,0
1932,44,37,0
1933,45,37,0
1934,46,37,0
1935,47,37,0
1936,48,37,0
1937,49,37,0
1938,50,37,0
1939,0,38,0
1940,1,38,0
1941,2,38,0
1942,3,38,0
1943,4,38,0
1944,5,38,0
1945,6,38,0
1946,7,38,0
1947,8,38,0
1948,9,38,0
1949,10,38,0
1950,11,38,0
1951,12,38,0
1952,13,38,0
1953,14,38,0
1954,15,38,0
1955,16,38,0
1956,17,38,0
1957,18,38,0
1958,19,38,0
1959,20,38,0
1960,21,38,0
1961,22,38,0
1962,23,38,0
1963,24,38,0
1964,25,38,0
1965,26,38,0
1966,27,38,0
1967,28,38,0
1968,29,38,0
1969,30,38,0
1970,31,38,0
1971,32,38,0
1972,33,38,0
1973,34,38,0
1974,35,38,0
1975,36,38,0
1976,37,38,0
1977,38,38,0
1978,39,38,0
1979,40,38,0
1980,41,38,0
1981,42,38,0
1982,43,38,0
1983,44,38,0
1984,45,38,0
1985,46,38,0
1986,47,38,0
1987,48,38,0
1988,49,38,0
1989,50,38,0
1990,0,39,0
1991,1,39,0
1992,2,39,0
1993,3,39,0
1994,4,39,0
1995,5,39,0
1996,6,39,0
1997,7,39,0
1998,8,39,0
1999,9,39,0
2000,10,39,0
2001,11,39,0
2002,12,39,0
2003,13,39,0
2004,14,39,0
2005,15,39,0
2006,16,39,0
2007,17,39,0
2008,18,39,0
2009,19,39,0
2010,20,39,0
2011,21,39,0
2012,22,39,0
2013,23,39,0
2014,24,39,0
2015,25,39,0
2016,26,39,0
2017,27,39,0
2018,28,39,0
2019,29,39,0
2020,30,39,0
2021,31,39,0
2022,32,39,0
2023,33,39,0
2024,34,39,0
2025,35,39,0
2026,36,39,0
2027,37,39,0
2028,38,39,0
2029,39,39,0
2030,40,39,0
2031,41,39,0
2032,42,39,0
2033,43,39,0
2034,44,39,0
2035,45,39,0
2036,46,39,0
2037,47,39,0
2038,48,39,0
2039,49,39,0
2040,50,39,0
2041,0,40,0
2042,1,40,0
2043,2,40,0
2044,3,40,0
2045,4,40,0
2046,5,40,0
2047,6,40,0
2048,7,40,0
2049,8,40,0
2050,9,40,0
2051,10,40,0
2052,11,40,0
2053,12,40,0
2054,13,40,0
2055,14,40,0
2056,15,40,0
2057,16,40,0
2058,17,40,0
2059,18,40,0
2060,19,40,0
2061,20,40,0
2062,21,40,0
2063,22,40,0
2064,23,40,0
2065,24,40,0
2066,25,40,0
2067,26,40,0
2068,27,40,0
2069,28,40,0
2070,29,40,0
2071,30,40,0
2072,31,40,0
2073,32,40,0
2074,33,40,0
2075,34,40,0
2076,35,40,0
2077,36,40,0
2078,37,40,0
2079,38,40,0
2080,39,40,0
2081,40,40,0
2082,41,40,0
2083,42,40,0
2084,43,40,0
2085,44,40,0
2086,45,40,0
2087,46,40,0
2088,47,40,0
2089,48,40,0
2090,49,40,0
2091,50,40,0
2092,0,41,0
2093,1,41,0
2094,2,41,0
2095,3,41,0
2096,4,41,0
2097,5,41,0
2098,6,41,0
2099,7,41,0
2100,8,41,0
2101,9,41,0
2102,10,41,0
2103,11,41,0
2104,12,41,0
2105,13,41,0
2106,14,41,0
2107,15,41,0
2108,16,41,0
2109,17,41,0
2110,18,41,0
2111,19,41,0
2112,20,41,0
2113,21,41,0
2114,22,41,0
2115,23,41,0
2116,24,41,0
2117,25,41,0
2118,26,41,0
2119,27,41,0
2120,28,41,0
2121,29,41,0
2122,30,41,0
2123,31,41,0
2124,32,41,0
2125,33,41,0
2126,34,41,0
2127,35,41,0
2128,36,41,0
2129,37,41,0
2130,38,41,0
2131,39,41,0
2132,40,41,0
2133,41,41,0
2134,42,41,0
2135,43,41,0
2136,44,41,0
2137,45,41,0
2138,46,41,0
2139,47,41,0
2140,48,41,0
2141,49,41,0
2142,50,41,0
2143,0,42,0
2144,1,42,0
2145,2,42,0
2146,3,42,0
2147,4,42,0
2148,5,42,0
2149,6,42,0
2150,7,42,0
2151,8,42,0
2152,9,42,0
2153,10,42,0
2154,11,42,0
2155,12,42,0
2156,13,42,0
2157,14,42,0
2158,15,42,0
2159,16,42,0
2160,17,42,0
2161,18,42,0
2162,19,42,0
2163,20,42,0
2164,21,42,0
2165,22,42,0
2166,23,42,0
2167,24,42,0
2168,25,42,0
2169,26,42,0
2170,27,42,0
2171,28,42,0
2172,29,42,0
2173,30,42,0
2174,31,42,0
2175,32,42,0
2176,33,42,0
2177,34,42,0
2178,35,42,0
2179,36,42,0
2180,37,42,0
2181,38,42,0
2182,39,42,0
2183,40,42,0
2184,41,42,0
2185,42,42,0
2186,43,42,0
2187,44,42,0
2188,45,42,0
2189,46,42,0
2190,47,42,0
2191,48,42,0
2192,49,42,0
2193,50,42,0
2194,0,43,0
2195,1,43,0
2196,2,43,0
2197,3,43,0
2198,4,43,0
2199,5,43,0
2200,6,43,0
2201,7,43,0
2202,8,43,0
2203,9,43,0
2204,10,43,0
2205,11,43,0
2206,12,43,0
2207,13,43,0
2208,14,43,0
2209,15,43,0
2210,16,43,0
2211,17,43,0
2212,18,43,0
2213,19,43,0
2214,20,43,0
2215,21,43,0
2216,22,43,0
2217,23,43,0
2218,24,43,0
2219,25,43,0
2220,26,43,0
2221,27,43,0
2222,28,43,0
2223,29,43,0
2224,30,43,0
2225,31,43,0
2226,32,43,0
2227,33,43,0
2228,34,43,0
2229,35,43,0
2230,36,43,0
2231,37,43,0
2232,38,43,0
2233,39,43,0
2234,40,43,0
2235,41,43,0
2236,42,43,0
2237,43,43,0
2238,44,43,0
2239,45,43,0
2240,46,43,0
2241,47,43,0
2242,48,43,0
2243,49,43,0
2244,50,43,0
2245,0,44,0
2246,1,44,0
2247,2,44,0
2248,3,44,0
2249,4,44,0
2250,5,44,0
2251,6,44,0
2252,7,44,0
2253,8,44,0
2254,9,44,0
2255,10,44,0
2256,11,44,0
2257,12,44,0
2258,13,44,0
2259,14,44,0
2260,15,44,0
2261,16,44,0
2262,17,44,0
2263,18,44,0
2264,19,44,0
2265,20,44,0
2266,21,44,0
2267,22,44,0
2268,23,44,0
2269,24,44,0
2270,25,44,0
2271,26,44,0
2272,27,44,0
2273,28,44,0
2274,29,44,0
2275,30,44,0
2276,31,44,0
2277,32,44,0
2278,33,44,0
2279,34,44,0
2280,35,44,0
2281,36,44,0
2282,37,44,0
2283,38,44,0
2284,39,44,0
2285,40,44,0
2286,41,44,0
2287,42,44,0
2288,43,44,0
2289,44,44,0
2290,45,44,0
2291,46,44,0
2292,47,44,0
2293,48,44,0
2294,49,44,0
2295,50,44,0
2296,0,45,0
2297,1,45,0
2298,2,45,0
2299,3,45,0
2300,4,45,0
2301,5,45,0
2302,6,45,0
2303,7,45,0
2304,8,45,0
2305,9,45,0
2306,10,45,0
2307,11,45,0
2308,12,45,0
2309,13,45,0
2310,14,45,0
2311,15,45,0
2312,16,45,0
2313,17,45,0
2314,18,45,0
2315,19,45,0
2316,20,45,0
2317,21,45,0
2318,22,45,0
2319,23,45,0
2320,24,45,0
2321,25,45,0
2322,26,45,0
2323,27,45,0
2324,28,45,0
2325,29,45,0
2326,30,45,0
2327,31,45,0
2328,32,45,0
2329,33,45,0
2330,34,45,0
2331,35,45,0
2332,36,45,0
2333,37,45,0
2334,38,45,0
2335,39,45,0
2336,40,45,0
2337,41,45,0
2338,42,45,0
2339,43,45,0
2340,44,45,0
2341,45,45,0
2342,46,45,0
2343,47,45,0
2344,48,45,0
2345,49,45,0
2346,50,45,0
2347,0,46,0
2348,1,46,0
2349,2,46,0
2350,3,46,0
2351,4,46,0
2352,5,46,0
2353,6,46,0
2354,7,46,0
2355,8,46,0
2356,9,46,0
2357,10,46,0
2358,11,46,0
2359,12,46,0
2360,13,46,0
2361,14,46,0
2362,15,46,0
2363,16,46,0
2364,17,46,0
2365,18,46,0
2366,19,46,0
2367,20,46,0
2368,21,46,0
2369,22,46,0
2370,23,46,0
2371,24,46,0
2372,25,46,0
2373,26,46,0
2374,27,46,0
2375,28,46,0
2376,29,46,0
2377,30,46,0
2378,31,46,0
2379,32,46,0
2380,33,46,0
2381,34,46,0
2382,35,46,0
2383,36,46,0
2384,37,46,0
2385,38,46,0
2386,39,46,0
2387,40,46,0
2388,41,46,0
2389,42,46,0
2390,43,46,0
2391,44,46,0
2392,45,46,0
2393,46,46,0
2394,47,46,0
2395,48,46,0
2396,49,46,0
2397,50,46,0
2398,0,47,0
2399,1,47,0
2400,2,47,0
2401,3,47,0
2402,4,47,0
2403,5,47,0
2404,6,47,0
2405,7,47,0
2406,8,47,0
2407,9,47,0
2408,10,47,0
2409,11,47,0
2410,12,47,0
2411,13,47,0
2412,14,47,0
2413,15,47,0
2414,16,47,0
2415,17,47,0
2416,18,47,0
2417,19,47,0
2418,20,47,0
2419,21,47,0
2420,22,47,0
2421,23,47,0
2422,24,47,0
2423,25,47,0
2424,26,47,0
2425,27,47,0
2426,28,47,0
2427,29,47,0
2428,30,47,0
2429,31,47,0
2430,32,47,0
2431,33,47,0
2432,34,47,0
2433,35,47,0
2434,36,47,0
2435,37,47,0
2436,38,47,0
2437,39,47,0
2438,40,47,0
2439,41,47,0
2440,42,47,0
2441,43,47,0
2442,44,47,0
2443,45,47,0
2444,46,47,0
2445,47,47,0
2446,48,47,0
2447,49,47,0
2448,50,47,0
2449,0,48,0
2450,1,48,0
2451,2,48,0
2452,3,48,0
2453,4,48,0
2454,5,48,0
2455,6,48,0
2456,7,48,0
2457,8,48,0
2458,9,48,0
2459,10,48,0
2460,11,48,0
2461,12,48,0
2462,13,48,0
2463,14,48,0
2464,15,48,0
2465,16,48,0
2466,17,48,0
2467,18,48,0
2468,19,48,0
2469,20,48,0
2470,21,48,0
2471,22,48,0
2472,23,48,0
2473,24,48,0
2474,25,48,0
2475,26,48,0
2476,27,48,0
2477,28,48,0
2478,29,48,0
2479,30,48,0
2480,31,48,0
2481,32,48,0
2482,33,48,0
2483,34,48,0
2484,35,48,0
2485,36,48,0
2486,37,48,0
2487,38,48,0
2488,39,48,0
2489,40,48,0
2490,41,48,0
2491,42,48,0
2492,43,48,0
2493,44,48,0
2494,45,48,0
2495,46,48,0
2496,47,48,0
2497,48,48,0
2498,49,48,0
2499,50,48,0
2500,0,49,0
2501,1,49,0
2502,2,49,0
2503,3,49,0
2504,4,49,0
2505,5,49,0
2506,6,49,0
2507,7,49,0
2508,8,49,0
2509,9,49,0
2510,10,49,0
2511,11,49,0
2512,12,49,0
2513,13,49,0
2514,14,49,0
2515,15,49,0
2516,16,49,0
2517,17,49,0
2518,18,49,0
2519,19,49,0
2520,20,49,0
2521,21,49,0
2522,22,49,0
2523,23,49,0
2524,24,49,0
2525,25,49,0
2526,26,49,0
2527,27,49,0
2528,28,49,0
2529,29,49,0
2530,30,49,0
2531,31,49,0
2532,32,49,0
2533,33,49,0
2534,34,49,0
2535,35,49,0
2536,36,49,0
2537,37,49,0
2538,38,49,0
2539,39,49,0
2540,40,49,0
2541,41,49,0
2542,42,49,0
2543,43,49,0
2544,44,49,0
2545,45,49,0
2546,46,49,0
2547,47,49,0
2548,48,49,0
2549,49,49,0
2550,50,49,0
2551,0,50,0
2552,1,50,0
2553,2,50,0
2554,3,50,0
2555,4,50,0
2556,5,50,0
2557,6,50,0
2558,7,50,0
2559,8,50,0
2560,9,50,0
2561,10,50,0
2562,11,50,0
2563,12,50,0
2564,13,50,0
2565,14,50,0
2566,15,50,0
2567,16,50,0
2568,17,50,0
2569,18,50,0
2570,19,50,0
2571,20,50,0
2572,21,50,0
2573,22,50,0
2574,23,50,0
2575,24,50,0
2576,25,50,0
2577,26,50,0
2578,27,50,0
2579,28,50,0
2580,29,50,0
2581,30,50,0
2582,31,50,0
2583,32,50,0
2584,33,50,0
2585,34,50,0
2586,35,50,0
2587,36,50,0
2588,37,50,0
2589,38,50,0
2590,39,50,0
2591,40,50,0
2592,41,50,0
2593,42,50,0
2594,43,50,0
2595,44,50,0
2596,45,50,0
2597,46,50,0
2598,47,50,0
2599,48,50,0
2600,49,50,0
2601,50,50,0Here is the "elements1.dat":
1,2,53,52,1
52,53,104,103,1
103,104,155,154,1
115,116,167,166,1
116,117,168,167,1
117,118,169,168,1
118,119,170,169,1
119,120,171,170,1
166,167,218,217,1
167,168,219,218,1
168,169,220,219,1
169,170,221,220,1
194,195,246,245,1
195,196,247,246,1
196,197,248,247,1
245,246,297,296,1
246,247,298,297,1
247,248,299,298,1
248,249,300,299,1
249,250,301,300,1
296,297,348,347,1
297,298,349,348,1
344,345,396,395,1
345,346,397,396,1
346,347,398,397,1
347,348,399,398,1
693,694,745,744,1
694,695,746,745,1
695,696,747,746,1
696,697,748,747,1
697,698,749,748,1
744,745,796,795,1
745,746,797,796,1
746,747,798,797,1
772,773,824,823,1
773,774,825,824,1
823,824,875,874,1
824,825,876,875,1
873,874,925,924,1
874,875,926,925,1
875,876,927,926,1
884,885,936,935,1
924,925,976,975,1
935,936,987,986,1
998,999,1050,1049,1
1021,1022,1073,1072,1
1031,1032,1083,1082,1
1072,1073,1124,1123,1
1082,1083,1134,1133,1
1095,1096,1147,1146,1
1133,1134,1185,1184,1
1184,1185,1236,1235,1
1235,1236,1287,1286,1
1236,1237,1288,1287,1
1288,1289,1340,1339,1
1329,1330,1381,1380,1
1339,1340,1391,1390,1
1346,1347,1398,1397,1
1347,1348,1399,1398,1
1368,1369,1420,1419,1
1397,1398,1449,1448,1
1402,1403,1454,1453,1
1448,1449,1500,1499,1
1481,1482,1533,1532,1
1511,1512,1563,1562,1
1512,1513,1564,1563,1
1531,1532,1583,1582,1
1532,1533,1584,1583,1
1562,1563,1614,1613,1
1582,1583,1634,1633,1
1583,1584,1635,1634,1
1633,1634,1685,1684,1
1634,1635,1686,1685,1
1737,1738,1789,1788,1
1738,1739,1790,1789,1
1739,1740,1791,1790,1
1740,1741,1792,1791,1
1741,1742,1793,1792,1
1818,1819,1870,1869,1
1895,1896,1947,1946,1
1928,1929,1980,1979,1
1929,1930,1981,1980,1
1946,1947,1998,1997,1
1982,1983,2034,2033,1
1983,1984,2035,2034,1
1996,1997,2048,2047,1
1997,1998,2049,2048,1
2024,2025,2076,2075,1
2033,2034,2085,2084,1
2034,2035,2086,2085,1
2075,2076,2127,2126,1
2182,2183,2234,2233,1
2197,2198,2249,2248,1
2198,2199,2250,2249,1
2232,2233,2284,2283,1
2233,2234,2285,2284,1
2366,2367,2418,2417,1
2367,2368,2419,2418,1
2496,2497,2548,2547,1
2497,2498,2549,2548,1
2498,2499,2550,2549,1
2547,2548,2599,2598,1
2548,2549,2600,2599,1
2549,2550,2601,2600,1
2,3,54,53,0
3,4,55,54,0
4,5,56,55,0
5,6,57,56,0
6,7,58,57,0
7,8,59,58,0
8,9,60,59,0
9,10,61,60,0
10,11,62,61,0
11,12,63,62,0
12,13,64,63,0
13,14,65,64,0
14,15,66,65,0
15,16,67,66,0
16,17,68,67,0
17,18,69,68,0
18,19,70,69,0
19,20,71,70,0
20,21,72,71,0
21,22,73,72,0
22,23,74,73,0
23,24,75,74,0
24,25,76,75,0
25,26,77,76,0
26,27,78,77,0
27,28,79,78,0
28,29,80,79,0
29,30,81,80,0
30,31,82,81,0
31,32,83,82,0
32,33,84,83,0
33,34,85,84,0
34,35,86,85,0
35,36,87,86,0
36,37,88,87,0
37,38,89,88,0
38,39,90,89,0
39,40,91,90,0
40,41,92,91,0
41,42,93,92,0
42,43,94,93,0
43,44,95,94,0
44,45,96,95,0
45,46,97,96,0
46,47,98,97,0
47,48,99,98,0
48,49,100,99,0
49,50,101,100,0
50,51,102,101,0
53,54,105,104,0
54,55,106,105,0
55,56,107,106,0
56,57,108,107,0
57,58,109,108,0
58,59,110,109,0
59,60,111,110,0
60,61,112,111,0
61,62,113,112,0
62,63,114,113,0
63,64,115,114,0
64,65,116,115,0
65,66,117,116,0
66,67,118,117,0
67,68,119,118,0
68,69,120,119,0
69,70,121,120,0
70,71,122,121,0
71,72,123,122,0
72,73,124,123,0
73,74,125,124,0
74,75,126,125,0
75,76,127,126,0
76,77,128,127,0
77,78,129,128,0
78,79,130,129,0
79,80,131,130,0
80,81,132,131,0
81,82,133,132,0
82,83,134,133,0
83,84,135,134,0
84,85,136,135,0
85,86,137,136,0
86,87,138,137,0
87,88,139,138,0
88,89,140,139,0
89,90,141,140,0
90,91,142,141,0
91,92,143,142,0
92,93,144,143,0
93,94,145,144,0
94,95,146,145,0
95,96,147,146,0
96,97,148,147,0
97,98,149,148,0
98,99,150,149,0
99,100,151,150,0
100,101,152,151,0
101,102,153,152,0
104,105,156,155,0
105,106,157,156,0
106,107,158,157,0
107,108,159,158,0
108,109,160,159,0
109,110,161,160,0
110,111,162,161,0
111,112,163,162,0
112,113,164,163,0
113,114,165,164,0
114,115,166,165,0
120,121,172,171,0
121,122,173,172,0
122,123,174,173,0
123,124,175,174,0
124,125,176,175,0
125,126,177,176,0
126,127,178,177,0
127,128,179,178,0
128,129,180,179,0
129,130,181,180,0
130,131,182,181,0
131,132,183,182,0
132,133,184,183,0
133,134,185,184,0
134,135,186,185,0
135,136,187,186,0
136,137,188,187,0
137,138,189,188,0
138,139,190,189,0
139,140,191,190,0
140,141,192,191,0
141,142,193,192,0
142,143,194,193,0
143,144,195,194,0
144,145,196,195,0
145,146,197,196,0
146,147,198,197,0
147,148,199,198,0
148,149,200,199,0
149,150,201,200,0
150,151,202,201,0
151,152,203,202,0
152,153,204,203,0
154,155,206,205,0
155,156,207,206,0
156,157,208,207,0
157,158,209,208,0
158,159,210,209,0
159,160,211,210,0
160,161,212,211,0
161,162,213,212,0
162,163,214,213,0
163,164,215,214,0
164,165,216,215,0
165,166,217,216,0
170,171,222,221,0
171,172,223,222,0
172,173,224,223,0
173,174,225,224,0
174,175,226,225,0
175,176,227,226,0
176,177,228,227,0
177,178,229,228,0
178,179,230,229,0
179,180,231,230,0
180,181,232,231,0
181,182,233,232,0
182,183,234,233,0
183,184,235,234,0
184,185,236,235,0
185,186,237,236,0
186,187,238,237,0
187,188,239,238,0
188,189,240,239,0
189,190,241,240,0
190,191,242,241,0
191,192,243,242,0
192,193,244,243,0
193,194,245,244,0
197,198,249,248,0
198,199,250,249,0
199,200,251,250,0
200,201,252,251,0
201,202,253,252,0
202,203,254,253,0
203,204,255,254,0
205,206,257,256,0
206,207,258,257,0
207,208,259,258,0
208,209,260,259,0
209,210,261,260,0
210,211,262,261,0
211,212,263,262,0
212,213,264,263,0
213,214,265,264,0
214,215,266,265,0
215,216,267,266,0
216,217,268,267,0
217,218,269,268,0
218,219,270,269,0
219,220,271,270,0
220,221,272,271,0
221,222,273,272,0
222,223,274,273,0
223,224,275,274,0
224,225,276,275,0
225,226,277,276,0
226,227,278,277,0
227,228,279,278,0
228,229,280,279,0
229,230,281,280,0
230,231,282,281,0
231,232,283,282,0
232,233,284,283,0
233,234,285,284,0
234,235,286,285,0
235,236,287,286,0
236,237,288,287,0
237,238,289,288,0
238,239,290,289,0
239,240,291,290,0
240,241,292,291,0
241,242,293,292,0
242,243,294,293,0
243,244,295,294,0
244,245,296,295,0
250,251,302,301,0
251,252,303,302,0
252,253,304,303,0
253,254,305,304,0
254,255,306,305,0
256,257,308,307,0
257,258,309,308,0
258,259,310,309,0
259,260,311,310,0
260,261,312,311,0
261,262,313,312,0
262,263,314,313,0
263,264,315,314,0
264,265,316,315,0
265,266,317,316,0
266,267,318,317,0
267,268,319,318,0
268,269,320,319,0
269,270,321,320,0
270,271,322,321,0
271,272,323,322,0
272,273,324,323,0
273,274,325,324,0
274,275,326,325,0
275,276,327,326,0
276,277,328,327,0
277,278,329,328,0
278,279,330,329,0
279,280,331,330,0
280,281,332,331,0
281,282,333,332,0
282,283,334,333,0
283,284,335,334,0
284,285,336,335,0
285,286,337,336,0
286,287,338,337,0
287,288,339,338,0
288,289,340,339,0
289,290,341,340,0
290,291,342,341,0
291,292,343,342,0
292,293,344,343,0
293,294,345,344,0
294,295,346,345,0
295,296,347,346,0
298,299,350,349,0
299,300,351,350,0
300,301,352,351,0
301,302,353,352,0
302,303,354,353,0
303,304,355,354,0
304,305,356,355,0
305,306,357,356,0
307,308,359,358,0
308,309,360,359,0
309,310,361,360,0
310,311,362,361,0
311,312,363,362,0
312,313,364,363,0
313,314,365,364,0
314,315,366,365,0
315,316,367,366,0
316,317,368,367,0
317,318,369,368,0
318,319,370,369,0
319,320,371,370,0
320,321,372,371,0
321,322,373,372,0
322,323,374,373,0
323,324,375,374,0
324,325,376,375,0
325,326,377,376,0
326,327,378,377,0
327,328,379,378,0
328,329,380,379,0
329,330,381,380,0
330,331,382,381,0
331,332,383,382,0
332,333,384,383,0
333,334,385,384,0
334,335,386,385,0
335,336,387,386,0
336,337,388,387,0
337,338,389,388,0
338,339,390,389,0
339,340,391,390,0
340,341,392,391,0
341,342,393,392,0
342,343,394,393,0
343,344,395,394,0
348,349,400,399,0
349,350,401,400,0
350,351,402,401,0
351,352,403,402,0
352,353,404,403,0
353,354,405,404,0
354,355,406,405,0
355,356,407,406,0
356,357,408,407,0
358,359,410,409,0
359,360,411,410,0
360,361,412,411,0
361,362,413,412,0
362,363,414,413,0
363,364,415,414,0
364,365,416,415,0
365,366,417,416,0
366,367,418,417,0
367,368,419,418,0
368,369,420,419,0
369,370,421,420,0
370,371,422,421,0
371,372,423,422,0
372,373,424,423,0
373,374,425,424,0
374,375,426,425,0
375,376,427,426,0
376,377,428,427,0
377,378,429,428,0
378,379,430,429,0
379,380,431,430,0
380,381,432,431,0
381,382,433,432,0
382,383,434,433,0
383,384,435,434,0
384,385,436,435,0
385,386,437,436,0
386,387,438,437,0
387,388,439,438,0
388,389,440,439,0
389,390,441,440,0
390,391,442,441,0
391,392,443,442,0
392,393,444,443,0
393,394,445,444,0
394,395,446,445,0
395,396,447,446,0
396,397,448,447,0
397,398,449,448,0
398,399,450,449,0
399,400,451,450,0
400,401,452,451,0
401,402,453,452,0
402,403,454,453,0
403,404,455,454,0
404,405,456,455,0
405,406,457,456,0
406,407,458,457,0
407,408,459,458,0
409,410,461,460,0
410,411,462,461,0
411,412,463,462,0
412,413,464,463,0
413,414,465,464,0
414,415,466,465,0
415,416,467,466,0
416,417,468,467,0
417,418,469,468,0
418,419,470,469,0
419,420,471,470,0
420,421,472,471,0
421,422,473,472,0
422,423,474,473,0
423,424,475,474,0
424,425,476,475,0
425,426,477,476,0
426,427,478,477,0
427,428,479,478,0
428,429,480,479,0
429,430,481,480,0
430,431,482,481,0
431,432,483,482,0
432,433,484,483,0
433,434,485,484,0
434,435,486,485,0
435,436,487,486,0
436,437,488,487,0
437,438,489,488,0
438,439,490,489,0
439,440,491,490,0
440,441,492,491,0
441,442,493,492,0
442,443,494,493,0
443,444,495,494,0
444,445,496,495,0
445,446,497,496,0
446,447,498,497,0
447,448,499,498,0
448,449,500,499,0
449,450,501,500,0
450,451,502,501,0
451,452,503,502,0
452,453,504,503,0
453,454,505,504,0
454,455,506,505,0
455,456,507,506,0
456,457,508,507,0
457,458,509,508,0
458,459,510,509,0
460,461,512,511,0
461,462,513,512,0
462,463,514,513,0
463,464,515,514,0
464,465,516,515,0
465,466,517,516,0
466,467,518,517,0
467,468,519,518,0
468,469,520,519,0
469,470,521,520,0
470,471,522,521,0
471,472,523,522,0
472,473,524,523,0
473,474,525,524,0
474,475,526,525,0
475,476,527,526,0
476,477,528,527,0
477,478,529,528,0
478,479,530,529,0
479,480,531,530,0
480,481,532,531,0
481,482,533,532,0
482,483,534,533,0
483,484,535,534,0
484,485,536,535,0
485,486,537,536,0
486,487,538,537,0
487,488,539,538,0
488,489,540,539,0
489,490,541,540,0
490,491,542,541,0
491,492,543,542,0
492,493,544,543,0
493,494,545,544,0
494,495,546,545,0
495,496,547,546,0
496,497,548,547,0
497,498,549,548,0
498,499,550,549,0
499,500,551,550,0
500,501,552,551,0
501,502,553,552,0
502,503,554,553,0
503,504,555,554,0
504,505,556,555,0
505,506,557,556,0
506,507,558,557,0
507,508,559,558,0
508,509,560,559,0
509,510,561,560,0
511,512,563,562,0
512,513,564,563,0
513,514,565,564,0
514,515,566,565,0
515,516,567,566,0
516,517,568,567,0
517,518,569,568,0
518,519,570,569,0
519,520,571,570,0
520,521,572,571,0
521,522,573,572,0
522,523,574,573,0
523,524,575,574,0
524,525,576,575,0
525,526,577,576,0
526,527,578,577,0
527,528,579,578,0
528,529,580,579,0
529,530,581,580,0
530,531,582,581,0
531,532,583,582,0
532,533,584,583,0
533,534,585,584,0
534,535,586,585,0
535,536,587,586,0
536,537,588,587,0
537,538,589,588,0
538,539,590,589,0
539,540,591,590,0
540,541,592,591,0
541,542,593,592,0
542,543,594,593,0
543,544,595,594,0
544,545,596,595,0
545,546,597,596,0
546,547,598,597,0
547,548,599,598,0
548,549,600,599,0
549,550,601,600,0
550,551,602,601,0
551,552,603,602,0
552,553,604,603,0
553,554,605,604,0
554,555,606,605,0
555,556,607,606,0
556,557,608,607,0
557,558,609,608,0
558,559,610,609,0
559,560,611,610,0
560,561,612,611,0
562,563,614,613,0
563,564,615,614,0
564,565,616,615,0
565,566,617,616,0
566,567,618,617,0
567,568,619,618,0
568,569,620,619,0
569,570,621,620,0
570,571,622,621,0
571,572,623,622,0
572,573,624,623,0
573,574,625,624,0
574,575,626,625,0
575,576,627,626,0
576,577,628,627,0
577,578,629,628,0
578,579,630,629,0
579,580,631,630,0
580,581,632,631,0
581,582,633,632,0
582,583,634,633,0
583,584,635,634,0
584,585,636,635,0
585,586,637,636,0
586,587,638,637,0
587,588,639,638,0
588,589,640,639,0
589,590,641,640,0
590,591,642,641,0
591,592,643,642,0
592,593,644,643,0
593,594,645,644,0
594,595,646,645,0
595,596,647,646,0
596,597,648,647,0
597,598,649,648,0
598,599,650,649,0
599,600,651,650,0
600,601,652,651,0
601,602,653,652,0
602,603,654,653,0
603,604,655,654,0
604,605,656,655,0
605,606,657,656,0
606,607,658,657,0
607,608,659,658,0
608,609,660,659,0
609,610,661,660,0
610,611,662,661,0
611,612,663,662,0
613,614,665,664,0
614,615,666,665,0
615,616,667,666,0
616,617,668,667,0
617,618,669,668,0
618,619,670,669,0
619,620,671,670,0
620,621,672,671,0
621,622,673,672,0
622,623,674,673,0
623,624,675,674,0
624,625,676,675,0
625,626,677,676,0
626,627,678,677,0
627,628,679,678,0
628,629,680,679,0
629,630,681,680,0
630,631,682,681,0
631,632,683,682,0
632,633,684,683,0
633,634,685,684,0
634,635,686,685,0
635,636,687,686,0
636,637,688,687,0
637,638,689,688,0
638,639,690,689,0
639,640,691,690,0
640,641,692,691,0
641,642,693,692,0
642,643,694,693,0
643,644,695,694,0
644,645,696,695,0
645,646,697,696,0
646,647,698,697,0
647,648,699,698,0
648,649,700,699,0
649,650,701,700,0
650,651,702,701,0
651,652,703,702,0
652,653,704,703,0
653,654,705,704,0
654,655,706,705,0
655,656,707,706,0
656,657,708,707,0
657,658,709,708,0
658,659,710,709,0
659,660,711,710,0
660,661,712,711,0
661,662,713,712,0
662,663,714,713,0
664,665,716,715,0
665,666,717,716,0
666,667,718,717,0
667,668,719,718,0
668,669,720,719,0
669,670,721,720,0
670,671,722,721,0
671,672,723,722,0
672,673,724,723,0
673,674,725,724,0
674,675,726,725,0
675,676,727,726,0
676,677,728,727,0
677,678,729,728,0
678,679,730,729,0
679,680,731,730,0
680,681,732,731,0
681,682,733,732,0
682,683,734,733,0
683,684,735,734,0
684,685,736,735,0
685,686,737,736,0
686,687,738,737,0
687,688,739,738,0
688,689,740,739,0
689,690,741,740,0
690,691,742,741,0
691,692,743,742,0
692,693,744,743,0
698,699,750,749,0
699,700,751,750,0
700,701,752,751,0
701,702,753,752,0
702,703,754,753,0
703,704,755,754,0
704,705,756,755,0
705,706,757,756,0
706,707,758,757,0
707,708,759,758,0
708,709,760,759,0
709,710,761,760,0
710,711,762,761,0
711,712,763,762,0
712,713,764,763,0
713,714,765,764,0
715,716,767,766,0
716,717,768,767,0
717,718,769,768,0
718,719,770,769,0
719,720,771,770,0
720,721,772,771,0
721,722,773,772,0
722,723,774,773,0
723,724,775,774,0
724,725,776,775,0
725,726,777,776,0
726,727,778,777,0
727,728,779,778,0
728,729,780,779,0
729,730,781,780,0
730,731,782,781,0
731,732,783,782,0
732,733,784,783,0
733,734,785,784,0
734,735,786,785,0
735,736,787,786,0
736,737,788,787,0
737,738,789,788,0
738,739,790,789,0
739,740,791,790,0
740,741,792,791,0
741,742,793,792,0
742,743,794,793,0
743,744,795,794,0
747,748,799,798,0
748,749,800,799,0
749,750,801,800,0
750,751,802,801,0
751,752,803,802,0
752,753,804,803,0
753,754,805,804,0
754,755,806,805,0
755,756,807,806,0
756,757,808,807,0
757,758,809,808,0
758,759,810,809,0
759,760,811,810,0
760,761,812,811,0
761,762,813,812,0
762,763,814,813,0
763,764,815,814,0
764,765,816,815,0
766,767,818,817,0
767,768,819,818,0
768,769,820,819,0
769,770,821,820,0
770,771,822,821,0
771,772,823,822,0
774,775,826,825,0
775,776,827,826,0
776,777,828,827,0
777,778,829,828,0
778,779,830,829,0
779,780,831,830,0
780,781,832,831,0
781,782,833,832,0
782,783,834,833,0
783,784,835,834,0
784,785,836,835,0
785,786,837,836,0
786,787,838,837,0
787,788,839,838,0
788,789,840,839,0
789,790,841,840,0
790,791,842,841,0
791,792,843,842,0
792,793,844,843,0
793,794,845,844,0
794,795,846,845,0
795,796,847,846,0
796,797,848,847,0
797,798,849,848,0
798,799,850,849,0
799,800,851,850,0
800,801,852,851,0
801,802,853,852,0
802,803,854,853,0
803,804,855,854,0
804,805,856,855,0
805,806,857,856,0
806,807,858,857,0
807,808,859,858,0
808,809,860,859,0
809,810,861,860,0
810,811,862,861,0
811,812,863,862,0
812,813,864,863,0
813,814,865,864,0
814,815,866,865,0
815,816,867,866,0
817,818,869,868,0
818,819,870,869,0
819,820,871,870,0
820,821,872,871,0
821,822,873,872,0
822,823,874,873,0
825,826,877,876,0
826,827,878,877,0
827,828,879,878,0
828,829,880,879,0
829,830,881,880,0
830,831,882,881,0
831,832,883,882,0
832,833,884,883,0
833,834,885,884,0
834,835,886,885,0
835,836,887,886,0
836,837,888,887,0
837,838,889,888,0
838,839,890,889,0
839,840,891,890,0
840,841,892,891,0
841,842,893,892,0
842,843,894,893,0
843,844,895,894,0
844,845,896,895,0
845,846,897,896,0
846,847,898,897,0
847,848,899,898,0
848,849,900,899,0
849,850,901,900,0
850,851,902,901,0
851,852,903,902,0
852,853,904,903,0
853,854,905,904,0
854,855,906,905,0
855,856,907,906,0
856,857,908,907,0
857,858,909,908,0
858,859,910,909,0
859,860,911,910,0
860,861,912,911,0
861,862,913,912,0
862,863,914,913,0
863,864,915,914,0
864,865,916,915,0
865,866,917,916,0
866,867,918,917,0
868,869,920,919,0
869,870,921,920,0
870,871,922,921,0
871,872,923,922,0
872,873,924,923,0
876,877,928,927,0
877,878,929,928,0
878,879,930,929,0
879,880,931,930,0
880,881,932,931,0
881,882,933,932,0
882,883,934,933,0
883,884,935,934,0
885,886,937,936,0
886,887,938,937,0
887,888,939,938,0
888,889,940,939,0
889,890,941,940,0
890,891,942,941,0
891,892,943,942,0
892,893,944,943,0
893,894,945,944,0
894,895,946,945,0
895,896,947,946,0
896,897,948,947,0
897,898,949,948,0
898,899,950,949,0
899,900,951,950,0
900,901,952,951,0
901,902,953,952,0
902,903,954,953,0
903,904,955,954,0
904,905,956,955,0
905,906,957,956,0
906,907,958,957,0
907,908,959,958,0
908,909,960,959,0
909,910,961,960,0
910,911,962,961,0
911,912,963,962,0
912,913,964,963,0
913,914,965,964,0
914,915,966,965,0
915,916,967,966,0
916,917,968,967,0
917,918,969,968,0
919,920,971,970,0
920,921,972,971,0
921,922,973,972,0
922,923,974,973,0
923,924,975,974,0
925,926,977,976,0
926,927,978,977,0
927,928,979,978,0
928,929,980,979,0
929,930,981,980,0
930,931,982,981,0
931,932,983,982,0
932,933,984,983,0
933,934,985,984,0
934,935,986,985,0
936,937,988,987,0
937,938,989,988,0
938,939,990,989,0
939,940,991,990,0
940,941,992,991,0
941,942,993,992,0
942,943,994,993,0
943,944,995,994,0
944,945,996,995,0
945,946,997,996,0
946,947,998,997,0
947,948,999,998,0
948,949,1000,999,0
949,950,1001,1000,0
950,951,1002,1001,0
951,952,1003,1002,0
952,953,1004,1003,0
953,954,1005,1004,0
954,955,1006,1005,0
955,956,1007,1006,0
956,957,1008,1007,0
957,958,1009,1008,0
958,959,1010,1009,0
959,960,1011,1010,0
960,961,1012,1011,0
961,962,1013,1012,0
962,963,1014,1013,0
963,964,1015,1014,0
964,965,1016,1015,0
965,966,1017,1016,0
966,967,1018,1017,0
967,968,1019,1018,0
968,969,1020,1019,0
970,971,1022,1021,0
971,972,1023,1022,0
972,973,1024,1023,0
973,974,1025,1024,0
974,975,1026,1025,0
975,976,1027,1026,0
976,977,1028,1027,0
977,978,1029,1028,0
978,979,1030,1029,0
979,980,1031,1030,0
980,981,1032,1031,0
981,982,1033,1032,0
982,983,1034,1033,0
983,984,1035,1034,0
984,985,1036,1035,0
985,986,1037,1036,0
986,987,1038,1037,0
987,988,1039,1038,0
988,989,1040,1039,0
989,990,1041,1040,0
990,991,1042,1041,0
991,992,1043,1042,0
992,993,1044,1043,0
993,994,1045,1044,0
994,995,1046,1045,0
995,996,1047,1046,0
996,997,1048,1047,0
997,998,1049,1048,0
999,1000,1051,1050,0
1000,1001,1052,1051,0
1001,1002,1053,1052,0
1002,1003,1054,1053,0
1003,1004,1055,1054,0
1004,1005,1056,1055,0
1005,1006,1057,1056,0
1006,1007,1058,1057,0
1007,1008,1059,1058,0
1008,1009,1060,1059,0
1009,1010,1061,1060,0
1010,1011,1062,1061,0
1011,1012,1063,1062,0
1012,1013,1064,1063,0
1013,1014,1065,1064,0
1014,1015,1066,1065,0
1015,1016,1067,1066,0
1016,1017,1068,1067,0
1017,1018,1069,1068,0
1018,1019,1070,1069,0
1019,1020,1071,1070,0
1022,1023,1074,1073,0
1023,1024,1075,1074,0
1024,1025,1076,1075,0
1025,1026,1077,1076,0
1026,1027,1078,1077,0
1027,1028,1079,1078,0
1028,1029,1080,1079,0
1029,1030,1081,1080,0
1030,1031,1082,1081,0
1032,1033,1084,1083,0
1033,1034,1085,1084,0
1034,1035,1086,1085,0
1035,1036,1087,1086,0
1036,1037,1088,1087,0
1037,1038,1089,1088,0
1038,1039,1090,1089,0
1039,1040,1091,1090,0
1040,1041,1092,1091,0
1041,1042,1093,1092,0
1042,1043,1094,1093,0
1043,1044,1095,1094,0
1044,1045,1096,1095,0
1045,1046,1097,1096,0
1046,1047,1098,1097,0
1047,1048,1099,1098,0
1048,1049,1100,1099,0
1049,1050,1101,1100,0
1050,1051,1102,1101,0
1051,1052,1103,1102,0
1052,1053,1104,1103,0
1053,1054,1105,1104,0
1054,1055,1106,1105,0
1055,1056,1107,1106,0
1056,1057,1108,1107,0
1057,1058,1109,1108,0
1058,1059,1110,1109,0
1059,1060,1111,1110,0
1060,1061,1112,1111,0
1061,1062,1113,1112,0
1062,1063,1114,1113,0
1063,1064,1115,1114,0
1064,1065,1116,1115,0
1065,1066,1117,1116,0
1066,1067,1118,1117,0
1067,1068,1119,1118,0
1068,1069,1120,1119,0
1069,1070,1121,1120,0
1070,1071,1122,1121,0
1073,1074,1125,1124,0
1074,1075,1126,1125,0
1075,1076,1127,1126,0
1076,1077,1128,1127,0
1077,1078,1129,1128,0
1078,1079,1130,1129,0
1079,1080,1131,1130,0
1080,1081,1132,1131,0
1081,1082,1133,1132,0
1083,1084,1135,1134,0
1084,1085,1136,1135,0
1085,1086,1137,1136,0
1086,1087,1138,1137,0
1087,1088,1139,1138,0
1088,1089,1140,1139,0
1089,1090,1141,1140,0
1090,1091,1142,1141,0
1091,1092,1143,1142,0
1092,1093,1144,1143,0
1093,1094,1145,1144,0
1094,1095,1146,1145,0
1096,1097,1148,1147,0
1097,1098,1149,1148,0
1098,1099,1150,1149,0
1099,1100,1151,1150,0
1100,1101,1152,1151,0
1101,1102,1153,1152,0
1102,1103,1154,1153,0
1103,1104,1155,1154,0
1104,1105,1156,1155,0
1105,1106,1157,1156,0
1106,1107,1158,1157,0
1107,1108,1159,1158,0
1108,1109,1160,1159,0
1109,1110,1161,1160,0
1110,1111,1162,1161,0
1111,1112,1163,1162,0
1112,1113,1164,1163,0
1113,1114,1165,1164,0
1114,1115,1166,1165,0
1115,1116,1167,1166,0
1116,1117,1168,1167,0
1117,1118,1169,1168,0
1118,1119,1170,1169,0
1119,1120,1171,1170,0
1120,1121,1172,1171,0
1121,1122,1173,1172,0
1123,1124,1175,1174,0
1124,1125,1176,1175,0
1125,1126,1177,1176,0
1126,1127,1178,1177,0
1127,1128,1179,1178,0
1128,1129,1180,1179,0
1129,1130,1181,1180,0
1130,1131,1182,1181,0
1131,1132,1183,1182,0
1132,1133,1184,1183,0
1134,1135,1186,1185,0
1135,1136,1187,1186,0
1136,1137,1188,1187,0
1137,1138,1189,1188,0
1138,1139,1190,1189,0
1139,1140,1191,1190,0
1140,1141,1192,1191,0
1141,1142,1193,1192,0
1142,1143,1194,1193,0
1143,1144,1195,1194,0
1144,1145,1196,1195,0
1145,1146,1197,1196,0
1146,1147,1198,1197,0
1147,1148,1199,1198,0
1148,1149,1200,1199,0
1149,1150,1201,1200,0
1150,1151,1202,1201,0
1151,1152,1203,1202,0
1152,1153,1204,1203,0
1153,1154,1205,1204,0
1154,1155,1206,1205,0
1155,1156,1207,1206,0
1156,1157,1208,1207,0
1157,1158,1209,1208,0
1158,1159,1210,1209,0
1159,1160,1211,1210,0
1160,1161,1212,1211,0
1161,1162,1213,1212,0
1162,1163,1214,1213,0
1163,1164,1215,1214,0
1164,1165,1216,1215,0
1165,1166,1217,1216,0
1166,1167,1218,1217,0
1167,1168,1219,1218,0
1168,1169,1220,1219,0
1169,1170,1221,1220,0
1170,1171,1222,1221,0
1171,1172,1223,1222,0
1172,1173,1224,1223,0
1174,1175,1226,1225,0
1175,1176,1227,1226,0
1176,1177,1228,1227,0
1177,1178,1229,1228,0
1178,1179,1230,1229,0
1179,1180,1231,1230,0
1180,1181,1232,1231,0
1181,1182,1233,1232,0
1182,1183,1234,1233,0
1183,1184,1235,1234,0
1185,1186,1237,1236,0
1186,1187,1238,1237,0
1187,1188,1239,1238,0
1188,1189,1240,1239,0
1189,1190,1241,1240,0
1190,1191,1242,1241,0
1191,1192,1243,1242,0
1192,1193,1244,1243,0
1193,1194,1245,1244,0
1194,1195,1246,1245,0
1195,1196,1247,1246,0
1196,1197,1248,1247,0
1197,1198,1249,1248,0
1198,1199,1250,1249,0
1199,1200,1251,1250,0
1200,1201,1252,1251,0
1201,1202,1253,1252,0
1202,1203,1254,1253,0
1203,1204,1255,1254,0
1204,1205,1256,1255,0
1205,1206,1257,1256,0
1206,1207,1258,1257,0
1207,1208,1259,1258,0
1208,1209,1260,1259,0
1209,1210,1261,1260,0
1210,1211,1262,1261,0
1211,1212,1263,1262,0
1212,1213,1264,1263,0
1213,1214,1265,1264,0
1214,1215,1266,1265,0
1215,1216,1267,1266,0
1216,1217,1268,1267,0
1217,1218,1269,1268,0
1218,1219,1270,1269,0
1219,1220,1271,1270,0
1220,1221,1272,1271,0
1221,1222,1273,1272,0
1222,1223,1274,1273,0
1223,1224,1275,1274,0
1225,1226,1277,1276,0
1226,1227,1278,1277,0
1227,1228,1279,1278,0
1228,1229,1280,1279,0
1229,1230,1281,1280,0
1230,1231,1282,1281,0
1231,1232,1283,1282,0
1232,1233,1284,1283,0
1233,1234,1285,1284,0
1234,1235,1286,1285,0
1237,1238,1289,1288,0
1238,1239,1290,1289,0
1239,1240,1291,1290,0
1240,1241,1292,1291,0
1241,1242,1293,1292,0
1242,1243,1294,1293,0
1243,1244,1295,1294,0
1244,1245,1296,1295,0
1245,1246,1297,1296,0
1246,1247,1298,1297,0
1247,1248,1299,1298,0
1248,1249,1300,1299,0
1249,1250,1301,1300,0
1250,1251,1302,1301,0
1251,1252,1303,1302,0
1252,1253,1304,1303,0
1253,1254,1305,1304,0
1254,1255,1306,1305,0
1255,1256,1307,1306,0
1256,1257,1308,1307,0
1257,1258,1309,1308,0
1258,1259,1310,1309,0
1259,1260,1311,1310,0
1260,1261,1312,1311,0
1261,1262,1313,1312,0
1262,1263,1314,1313,0
1263,1264,1315,1314,0
1264,1265,1316,1315,0
1265,1266,1317,1316,0
1266,1267,1318,1317,0
1267,1268,1319,1318,0
1268,1269,1320,1319,0
1269,1270,1321,1320,0
1270,1271,1322,1321,0
1271,1272,1323,1322,0
1272,1273,1324,1323,0
1273,1274,1325,1324,0
1274,1275,1326,1325,0
1276,1277,1328,1327,0
1277,1278,1329,1328,0
1278,1279,1330,1329,0
1279,1280,1331,1330,0
1280,1281,1332,1331,0
1281,1282,1333,1332,0
1282,1283,1334,1333,0
1283,1284,1335,1334,0
1284,1285,1336,1335,0
1285,1286,1337,1336,0
1286,1287,1338,1337,0
1287,1288,1339,1338,0
1289,1290,1341,1340,0
1290,1291,1342,1341,0
1291,1292,1343,1342,0
1292,1293,1344,1343,0
1293,1294,1345,1344,0
1294,1295,1346,1345,0
1295,1296,1347,1346,0
1296,1297,1348,1347,0
1297,1298,1349,1348,0
1298,1299,1350,1349,0
1299,1300,1351,1350,0
1300,1301,1352,1351,0
1301,1302,1353,1352,0
1302,1303,1354,1353,0
1303,1304,1355,1354,0
1304,1305,1356,1355,0
1305,1306,1357,1356,0
1306,1307,1358,1357,0
1307,1308,1359,1358,0
1308,1309,1360,1359,0
1309,1310,1361,1360,0
1310,1311,1362,1361,0
1311,1312,1363,1362,0
1312,1313,1364,1363,0
1313,1314,1365,1364,0
1314,1315,1366,1365,0
1315,1316,1367,1366,0
1316,1317,1368,1367,0
1317,1318,1369,1368,0
1318,1319,1370,1369,0
1319,1320,1371,1370,0
1320,1321,1372,1371,0
1321,1322,1373,1372,0
1322,1323,1374,1373,0
1323,1324,1375,1374,0
1324,1325,1376,1375,0
1325,1326,1377,1376,0
1327,1328,1379,1378,0
1328,1329,1380,1379,0
1330,1331,1382,1381,0
1331,1332,1383,1382,0
1332,1333,1384,1383,0
1333,1334,1385,1384,0
1334,1335,1386,1385,0
1335,1336,1387,1386,0
1336,1337,1388,1387,0
1337,1338,1389,1388,0
1338,1339,1390,1389,0
1340,1341,1392,1391,0
1341,1342,1393,1392,0
1342,1343,1394,1393,0
1343,1344,1395,1394,0
1344,1345,1396,1395,0
1345,1346,1397,1396,0
1348,1349,1400,1399,0
1349,1350,1401,1400,0
1350,1351,1402,1401,0
1351,1352,1403,1402,0
1352,1353,1404,1403,0
1353,1354,1405,1404,0
1354,1355,1406,1405,0
1355,1356,1407,1406,0
1356,1357,1408,1407,0
1357,1358,1409,1408,0
1358,1359,1410,1409,0
1359,1360,1411,1410,0
1360,1361,1412,1411,0
1361,1362,1413,1412,0
1362,1363,1414,1413,0
1363,1364,1415,1414,0
1364,1365,1416,1415,0
1365,1366,1417,1416,0
1366,1367,1418,1417,0
1367,1368,1419,1418,0
1369,1370,1421,1420,0
1370,1371,1422,1421,0
1371,1372,1423,1422,0
1372,1373,1424,1423,0
1373,1374,1425,1424,0
1374,1375,1426,1425,0
1375,1376,1427,1426,0
1376,1377,1428,1427,0
1378,1379,1430,1429,0
1379,1380,1431,1430,0
1380,1381,1432,1431,0
1381,1382,1433,1432,0
1382,1383,1434,1433,0
1383,1384,1435,1434,0
1384,1385,1436,1435,0
1385,1386,1437,1436,0
1386,1387,1438,1437,0
1387,1388,1439,1438,0
1388,1389,1440,1439,0
1389,1390,1441,1440,0
1390,1391,1442,1441,0
1391,1392,1443,1442,0
1392,1393,1444,1443,0
1393,1394,1445,1444,0
1394,1395,1446,1445,0
1395,1396,1447,1446,0
1396,1397,1448,1447,0
1398,1399,1450,1449,0
1399,1400,1451,1450,0
1400,1401,1452,1451,0
1401,1402,1453,1452,0
1403,1404,1455,1454,0
1404,1405,1456,1455,0
1405,1406,1457,1456,0
1406,1407,1458,1457,0
1407,1408,1459,1458,0
1408,1409,1460,1459,0
1409,1410,1461,1460,0
1410,1411,1462,1461,0
1411,1412,1463,1462,0
1412,1413,1464,1463,0
1413,1414,1465,1464,0
1414,1415,1466,1465,0
1415,1416,1467,1466,0
1416,1417,1468,1467,0
1417,1418,1469,1468,0
1418,1419,1470,1469,0
1419,1420,1471,1470,0
1420,1421,1472,1471,0
1421,1422,1473,1472,0
1422,1423,1474,1473,0
1423,1424,1475,1474,0
1424,1425,1476,1475,0
1425,1426,1477,1476,0
1426,1427,1478,1477,0
1427,1428,1479,1478,0
1429,1430,1481,1480,0
1430,1431,1482,1481,0
1431,1432,1483,1482,0
1432,1433,1484,1483,0
1433,1434,1485,1484,0
1434,1435,1486,1485,0
1435,1436,1487,1486,0
1436,1437,1488,1487,0
1437,1438,1489,1488,0
1438,1439,1490,1489,0
1439,1440,1491,1490,0
1440,1441,1492,1491,0
1441,1442,1493,1492,0
1442,1443,1494,1493,0
1443,1444,1495,1494,0
1444,1445,1496,1495,0
1445,1446,1497,1496,0
1446,1447,1498,1497,0
1447,1448,1499,1498,0
1449,1450,1501,1500,0
1450,1451,1502,1501,0
1451,1452,1503,1502,0
1452,1453,1504,1503,0
1453,1454,1505,1504,0
1454,1455,1506,1505,0
1455,1456,1507,1506,0
1456,1457,1508,1507,0
1457,1458,1509,1508,0
1458,1459,1510,1509,0
1459,1460,1511,1510,0
1460,1461,1512,1511,0
1461,1462,1513,1512,0
1462,1463,1514,1513,0
1463,1464,1515,1514,0
1464,1465,1516,1515,0
1465,1466,1517,1516,0
1466,1467,1518,1517,0
1467,1468,1519,1518,0
1468,1469,1520,1519,0
1469,1470,1521,1520,0
1470,1471,1522,1521,0
1471,1472,1523,1522,0
1472,1473,1524,1523,0
1473,1474,1525,1524,0
1474,1475,1526,1525,0
1475,1476,1527,1526,0
1476,1477,1528,1527,0
1477,1478,1529,1528,0
1478,1479,1530,1529,0
1480,1481,1532,1531,0
1482,1483,1534,1533,0
1483,1484,1535,1534,0
1484,1485,1536,1535,0
1485,1486,1537,1536,0
1486,1487,1538,1537,0
1487,1488,1539,1538,0
1488,1489,1540,1539,0
1489,1490,1541,1540,0
1490,1491,1542,1541,0
1491,1492,1543,1542,0
1492,1493,1544,1543,0
1493,1494,1545,1544,0
1494,1495,1546,1545,0
1495,1496,1547,1546,0
1496,1497,1548,1547,0
1497,1498,1549,1548,0
1498,1499,1550,1549,0
1499,1500,1551,1550,0
1500,1501,1552,1551,0
1501,1502,1553,1552,0
1502,1503,1554,1553,0
1503,1504,1555,1554,0
1504,1505,1556,1555,0
1505,1506,1557,1556,0
1506,1507,1558,1557,0
1507,1508,1559,1558,0
1508,1509,1560,1559,0
1509,1510,1561,1560,0
1510,1511,1562,1561,0
1513,1514,1565,1564,0
1514,1515,1566,1565,0
1515,1516,1567,1566,0
1516,1517,1568,1567,0
1517,1518,1569,1568,0
1518,1519,1570,1569,0
1519,1520,1571,1570,0
1520,1521,1572,1571,0
1521,1522,1573,1572,0
1522,1523,1574,1573,0
1523,1524,1575,1574,0
1524,1525,1576,1575,0
1525,1526,1577,1576,0
1526,1527,1578,1577,0
1527,1528,1579,1578,0
1528,1529,1580,1579,0
1529,1530,1581,1580,0
1533,1534,1585,1584,0
1534,1535,1586,1585,0
1535,1536,1587,1586,0
1536,1537,1588,1587,0
1537,1538,1589,1588,0
1538,1539,1590,1589,0
1539,1540,1591,1590,0
1540,1541,1592,1591,0
1541,1542,1593,1592,0
1542,1543,1594,1593,0
1543,1544,1595,1594,0
1544,1545,1596,1595,0
1545,1546,1597,1596,0
1546,1547,1598,1597,0
1547,1548,1599,1598,0
1548,1549,1600,1599,0
1549,1550,1601,1600,0
1550,1551,1602,1601,0
1551,1552,1603,1602,0
1552,1553,1604,1603,0
1553,1554,1605,1604,0
1554,1555,1606,1605,0
1555,1556,1607,1606,0
1556,1557,1608,1607,0
1557,1558,1609,1608,0
1558,1559,1610,1609,0
1559,1560,1611,1610,0
1560,1561,1612,1611,0
1561,1562,1613,1612,0
1563,1564,1615,1614,0
1564,1565,1616,1615,0
1565,1566,1617,1616,0
1566,1567,1618,1617,0
1567,1568,1619,1618,0
1568,1569,1620,1619,0
1569,1570,1621,1620,0
1570,1571,1622,1621,0
1571,1572,1623,1622,0
1572,1573,1624,1623,0
1573,1574,1625,1624,0
1574,1575,1626,1625,0
1575,1576,1627,1626,0
1576,1577,1628,1627,0
1577,1578,1629,1628,0
1578,1579,1630,1629,0
1579,1580,1631,1630,0
1580,1581,1632,1631,0
1584,1585,1636,1635,0
1585,1586,1637,1636,0
1586,1587,1638,1637,0
1587,1588,1639,1638,0
1588,1589,1640,1639,0
1589,1590,1641,1640,0
1590,1591,1642,1641,0
1591,1592,1643,1642,0
1592,1593,1644,1643,0
1593,1594,1645,1644,0
1594,1595,1646,1645,0
1595,1596,1647,1646,0
1596,1597,1648,1647,0
1597,1598,1649,1648,0
1598,1599,1650,1649,0
1599,1600,1651,1650,0
1600,1601,1652,1651,0
1601,1602,1653,1652,0
1602,1603,1654,1653,0
1603,1604,1655,1654,0
1604,1605,1656,1655,0
1605,1606,1657,1656,0
1606,1607,1658,1657,0
1607,1608,1659,1658,0
1608,1609,1660,1659,0
1609,1610,1661,1660,0
1610,1611,1662,1661,0
1611,1612,1663,1662,0
1612,1613,1664,1663,0
1613,1614,1665,1664,0
1614,1615,1666,1665,0
1615,1616,1667,1666,0
1616,1617,1668,1667,0
1617,1618,1669,1668,0
1618,1619,1670,1669,0
1619,1620,1671,1670,0
1620,1621,1672,1671,0
1621,1622,1673,1672,0
1622,1623,1674,1673,0
1623,1624,1675,1674,0
1624,1625,1676,1675,0
1625,1626,1677,1676,0
1626,1627,1678,1677,0
1627,1628,1679,1678,0
1628,1629,1680,1679,0
1629,1630,1681,1680,0
1630,1631,1682,1681,0
1631,1632,1683,1682,0
1635,1636,1687,1686,0
1636,1637,1688,1687,0
1637,1638,1689,1688,0
1638,1639,1690,1689,0
1639,1640,1691,1690,0
1640,1641,1692,1691,0
1641,1642,1693,1692,0
1642,1643,1694,1693,0
1643,1644,1695,1694,0
1644,1645,1696,1695,0
1645,1646,1697,1696,0
1646,1647,1698,1697,0
1647,1648,1699,1698,0
1648,1649,1700,1699,0
1649,1650,1701,1700,0
1650,1651,1702,1701,0
1651,1652,1703,1702,0
1652,1653,1704,1703,0
1653,1654,1705,1704,0
1654,1655,1706,1705,0
1655,1656,1707,1706,0
1656,1657,1708,1707,0
1657,1658,1709,1708,0
1658,1659,1710,1709,0
1659,1660,1711,1710,0
1660,1661,1712,1711,0
1661,1662,1713,1712,0
1662,1663,1714,1713,0
1663,1664,1715,1714,0
1664,1665,1716,1715,0
1665,1666,1717,1716,0
1666,1667,1718,1717,0
1667,1668,1719,1718,0
1668,1669,1720,1719,0
1669,1670,1721,1720,0
1670,1671,1722,1721,0
1671,1672,1723,1722,0
1672,1673,1724,1723,0
1673,1674,1725,1724,0
1674,1675,1726,1725,0
1675,1676,1727,1726,0
1676,1677,1728,1727,0
1677,1678,1729,1728,0
1678,1679,1730,1729,0
1679,1680,1731,1730,0
1680,1681,1732,1731,0
1681,1682,1733,1732,0
1682,1683,1734,1733,0
1684,1685,1736,1735,0
1685,1686,1737,1736,0
1686,1687,1738,1737,0
1687,1688,1739,1738,0
1688,1689,1740,1739,0
1689,1690,1741,1740,0
1690,1691,1742,1741,0
1691,1692,1743,1742,0
1692,1693,1744,1743,0
1693,1694,1745,1744,0
1694,1695,1746,1745,0
1695,1696,1747,1746,0
1696,1697,1748,1747,0
1697,1698,1749,1748,0
1698,1699,1750,1749,0
1699,1700,1751,1750,0
1700,1701,1752,1751,0
1701,1702,1753,1752,0
1702,1703,1754,1753,0
1703,1704,1755,1754,0
1704,1705,1756,1755,0
1705,1706,1757,1756,0
1706,1707,1758,1757,0
1707,1708,1759,1758,0
1708,1709,1760,1759,0
1709,1710,1761,1760,0
1710,1711,1762,1761,0
1711,1712,1763,1762,0
1712,1713,1764,1763,0
1713,1714,1765,1764,0
1714,1715,1766,1765,0
1715,1716,1767,1766,0
1716,1717,1768,1767,0
1717,1718,1769,1768,0
1718,1719,1770,1769,0
1719,1720,1771,1770,0
1720,1721,1772,1771,0
1721,1722,1773,1772,0
1722,1723,1774,1773,0
1723,1724,1775,1774,0
1724,1725,1776,1775,0
1725,1726,1777,1776,0
1726,1727,1778,1777,0
1727,1728,1779,1778,0
1728,1729,1780,1779,0
1729,1730,1781,1780,0
1730,1731,1782,1781,0
1731,1732,1783,1782,0
1732,1733,1784,1783,0
1733,1734,1785,1784,0
1735,1736,1787,1786,0
1736,1737,1788,1787,0
1742,1743,1794,1793,0
1743,1744,1795,1794,0
1744,1745,1796,1795,0
1745,1746,1797,1796,0
1746,1747,1798,1797,0
1747,1748,1799,1798,0
1748,1749,1800,1799,0
1749,1750,1801,1800,0
1750,1751,1802,1801,0
1751,1752,1803,1802,0
1752,1753,1804,1803,0
1753,1754,1805,1804,0
1754,1755,1806,1805,0
1755,1756,1807,1806,0
1756,1757,1808,1807,0
1757,1758,1809,1808,0
1758,1759,1810,1809,0
1759,1760,1811,1810,0
1760,1761,1812,1811,0
1761,1762,1813,1812,0
1762,1763,1814,1813,0
1763,1764,1815,1814,0
1764,1765,1816,1815,0
1765,1766,1817,1816,0
1766,1767,1818,1817,0
1767,1768,1819,1818,0
1768,1769,1820,1819,0
1769,1770,1821,1820,0
1770,1771,1822,1821,0
1771,1772,1823,1822,0
1772,1773,1824,1823,0
1773,1774,1825,1824,0
1774,1775,1826,1825,0
1775,1776,1827,1826,0
1776,1777,1828,1827,0
1777,1778,1829,1828,0
1778,1779,1830,1829,0
1779,1780,1831,1830,0
1780,1781,1832,1831,0
1781,1782,1833,1832,0
1782,1783,1834,1833,0
1783,1784,1835,1834,0
1784,1785,1836,1835,0
1786,1787,1838,1837,0
1787,1788,1839,1838,0
1788,1789,1840,1839,0
1789,1790,1841,1840,0
1790,1791,1842,1841,0
1791,1792,1843,1842,0
1792,1793,1844,1843,0
1793,1794,1845,1844,0
1794,1795,1846,1845,0
1795,1796,1847,1846,0
1796,1797,1848,1847,0
1797,1798,1849,1848,0
1798,1799,1850,1849,0
1799,1800,1851,1850,0
1800,1801,1852,1851,0
1801,1802,1853,1852,0
1802,1803,1854,1853,0
1803,1804,1855,1854,0
1804,1805,1856,1855,0
1805,1806,1857,1856,0
1806,1807,1858,1857,0
1807,1808,1859,1858,0
1808,1809,1860,1859,0
1809,1810,1861,1860,0
1810,1811,1862,1861,0
1811,1812,1863,1862,0
1812,1813,1864,1863,0
1813,1814,1865,1864,0
1814,1815,1866,1865,0
1815,1816,1867,1866,0
1816,1817,1868,1867,0
1817,1818,1869,1868,0
1819,1820,1871,1870,0
1820,1821,1872,1871,0
1821,1822,1873,1872,0
1822,1823,1874,1873,0
1823,1824,1875,1874,0
1824,1825,1876,1875,0
1825,1826,1877,1876,0
1826,1827,1878,1877,0
1827,1828,1879,1878,0
1828,1829,1880,1879,0
1829,1830,1881,1880,0
1830,1831,1882,1881,0
1831,1832,1883,1882,0
1832,1833,1884,1883,0
1833,1834,1885,1884,0
1834,1835,1886,1885,0
1835,1836,1887,1886,0
1837,1838,1889,1888,0
1838,1839,1890,1889,0
1839,1840,1891,1890,0
1840,1841,1892,1891,0
1841,1842,1893,1892,0
1842,1843,1894,1893,0
1843,1844,1895,1894,0
1844,1845,1896,1895,0
1845,1846,1897,1896,0
1846,1847,1898,1897,0
1847,1848,1899,1898,0
1848,1849,1900,1899,0
1849,1850,1901,1900,0
1850,1851,1902,1901,0
1851,1852,1903,1902,0
1852,1853,1904,1903,0
1853,1854,1905,1904,0
1854,1855,1906,1905,0
1855,1856,1907,1906,0
1856,1857,1908,1907,0
1857,1858,1909,1908,0
1858,1859,1910,1909,0
1859,1860,1911,1910,0
1860,1861,1912,1911,0
1861,1862,1913,1912,0
1862,1863,1914,1913,0
1863,1864,1915,1914,0
1864,1865,1916,1915,0
1865,1866,1917,1916,0
1866,1867,1918,1917,0
1867,1868,1919,1918,0
1868,1869,1920,1919,0
1869,1870,1921,1920,0
1870,1871,1922,1921,0
1871,1872,1923,1922,0
1872,1873,1924,1923,0
1873,1874,1925,1924,0
1874,1875,1926,1925,0
1875,1876,1927,1926,0
1876,1877,1928,1927,0
1877,1878,1929,1928,0
1878,1879,1930,1929,0
1879,1880,1931,1930,0
1880,1881,1932,1931,0
1881,1882,1933,1932,0
1882,1883,1934,1933,0
1883,1884,1935,1934,0
1884,1885,1936,1935,0
1885,1886,1937,1936,0
1886,1887,1938,1937,0
1888,1889,1940,1939,0
1889,1890,1941,1940,0
1890,1891,1942,1941,0
1891,1892,1943,1942,0
1892,1893,1944,1943,0
1893,1894,1945,1944,0
1894,1895,1946,1945,0
1896,1897,1948,1947,0
1897,1898,1949,1948,0
1898,1899,1950,1949,0
1899,1900,1951,1950,0
1900,1901,1952,1951,0
1901,1902,1953,1952,0
1902,1903,1954,1953,0
1903,1904,1955,1954,0
1904,1905,1956,1955,0
1905,1906,1957,1956,0
1906,1907,1958,1957,0
1907,1908,1959,1958,0
1908,1909,1960,1959,0
1909,1910,1961,1960,0
1910,1911,1962,1961,0
1911,1912,1963,1962,0
1912,1913,1964,1963,0
1913,1914,1965,1964,0
1914,1915,1966,1965,0
1915,1916,1967,1966,0
1916,1917,1968,1967,0
1917,1918,1969,1968,0
1918,1919,1970,1969,0
1919,1920,1971,1970,0
1920,1921,1972,1971,0
1921,1922,1973,1972,0
1922,1923,1974,1973,0
1923,1924,1975,1974,0
1924,1925,1976,1975,0
1925,1926,1977,1976,0
1926,1927,1978,1977,0
1927,1928,1979,1978,0
1930,1931,1982,1981,0
1931,1932,1983,1982,0
1932,1933,1984,1983,0
1933,1934,1985,1984,0
1934,1935,1986,1985,0
1935,1936,1987,1986,0
1936,1937,1988,1987,0
1937,1938,1989,1988,0
1939,1940,1991,1990,0
1940,1941,1992,1991,0
1941,1942,1993,1992,0
1942,1943,1994,1993,0
1943,1944,1995,1994,0
1944,1945,1996,1995,0
1945,1946,1997,1996,0
1947,1948,1999,1998,0
1948,1949,2000,1999,0
1949,1950,2001,2000,0
1950,1951,2002,2001,0
1951,1952,2003,2002,0
1952,1953,2004,2003,0
1953,1954,2005,2004,0
1954,1955,2006,2005,0
1955,1956,2007,2006,0
1956,1957,2008,2007,0
1957,1958,2009,2008,0
1958,1959,2010,2009,0
1959,1960,2011,2010,0
1960,1961,2012,2011,0
1961,1962,2013,2012,0
1962,1963,2014,2013,0
1963,1964,2015,2014,0
1964,1965,2016,2015,0
1965,1966,2017,2016,0
1966,1967,2018,2017,0
1967,1968,2019,2018,0
1968,1969,2020,2019,0
1969,1970,2021,2020,0
1970,1971,2022,2021,0
1971,1972,2023,2022,0
1972,1973,2024,2023,0
1973,1974,2025,2024,0
1974,1975,2026,2025,0
1975,1976,2027,2026,0
1976,1977,2028,2027,0
1977,1978,2029,2028,0
1978,1979,2030,2029,0
1979,1980,2031,2030,0
1980,1981,2032,2031,0
1981,1982,2033,2032,0
1984,1985,2036,2035,0
1985,1986,2037,2036,0
1986,1987,2038,2037,0
1987,1988,2039,2038,0
1988,1989,2040,2039,0
1990,1991,2042,2041,0
1991,1992,2043,2042,0
1992,1993,2044,2043,0
1993,1994,2045,2044,0
1994,1995,2046,2045,0
1995,1996,2047,2046,0
1998,1999,2050,2049,0
1999,2000,2051,2050,0
2000,2001,2052,2051,0
2001,2002,2053,2052,0
2002,2003,2054,2053,0
2003,2004,2055,2054,0
2004,2005,2056,2055,0
2005,2006,2057,2056,0
2006,2007,2058,2057,0
2007,2008,2059,2058,0
2008,2009,2060,2059,0
2009,2010,2061,2060,0
2010,2011,2062,2061,0
2011,2012,2063,2062,0
2012,2013,2064,2063,0
2013,2014,2065,2064,0
2014,2015,2066,2065,0
2015,2016,2067,2066,0
2016,2017,2068,2067,0
2017,2018,2069,2068,0
2018,2019,2070,2069,0
2019,2020,2071,2070,0
2020,2021,2072,2071,0
2021,2022,2073,2072,0
2022,2023,2074,2073,0
2023,2024,2075,2074,0
2025,2026,2077,2076,0
2026,2027,2078,2077,0
2027,2028,2079,2078,0
2028,2029,2080,2079,0
2029,2030,2081,2080,0
2030,2031,2082,2081,0
2031,2032,2083,2082,0
2032,2033,2084,2083,0
2035,2036,2087,2086,0
2036,2037,2088,2087,0
2037,2038,2089,2088,0
2038,2039,2090,2089,0
2039,2040,2091,2090,0
2041,2042,2093,2092,0
2042,2043,2094,2093,0
2043,2044,2095,2094,0
2044,2045,2096,2095,0
2045,2046,2097,2096,0
2046,2047,2098,2097,0
2047,2048,2099,2098,0
2048,2049,2100,2099,0
2049,2050,2101,2100,0
2050,2051,2102,2101,0
2051,2052,2103,2102,0
2052,2053,2104,2103,0
2053,2054,2105,2104,0
2054,2055,2106,2105,0
2055,2056,2107,2106,0
2056,2057,2108,2107,0
2057,2058,2109,2108,0
2058,2059,2110,2109,0
2059,2060,2111,2110,0
2060,2061,2112,2111,0
2061,2062,2113,2112,0
2062,2063,2114,2113,0
2063,2064,2115,2114,0
2064,2065,2116,2115,0
2065,2066,2117,2116,0
2066,2067,2118,2117,0
2067,2068,2119,2118,0
2068,2069,2120,2119,0
2069,2070,2121,2120,0
2070,2071,2122,2121,0
2071,2072,2123,2122,0
2072,2073,2124,2123,0
2073,2074,2125,2124,0
2074,2075,2126,2125,0
2076,2077,2128,2127,0
2077,2078,2129,2128,0
2078,2079,2130,2129,0
2079,2080,2131,2130,0
2080,2081,2132,2131,0
2081,2082,2133,2132,0
2082,2083,2134,2133,0
2083,2084,2135,2134,0
2084,2085,2136,2135,0
2085,2086,2137,2136,0
2086,2087,2138,2137,0
2087,2088,2139,2138,0
2088,2089,2140,2139,0
2089,2090,2141,2140,0
2090,2091,2142,2141,0
2092,2093,2144,2143,0
2093,2094,2145,2144,0
2094,2095,2146,2145,0
2095,2096,2147,2146,0
2096,2097,2148,2147,0
2097,2098,2149,2148,0
2098,2099,2150,2149,0
2099,2100,2151,2150,0
2100,2101,2152,2151,0
2101,2102,2153,2152,0
2102,2103,2154,2153,0
2103,2104,2155,2154,0
2104,2105,2156,2155,0
2105,2106,2157,2156,0
2106,2107,2158,2157,0
2107,2108,2159,2158,0
2108,2109,2160,2159,0
2109,2110,2161,2160,0
2110,2111,2162,2161,0
2111,2112,2163,2162,0
2112,2113,2164,2163,0
2113,2114,2165,2164,0
2114,2115,2166,2165,0
2115,2116,2167,2166,0
2116,2117,2168,2167,0
2117,2118,2169,2168,0
2118,2119,2170,2169,0
2119,2120,2171,2170,0
2120,2121,2172,2171,0
2121,2122,2173,2172,0
2122,2123,2174,2173,0
2123,2124,2175,2174,0
2124,2125,2176,2175,0
2125,2126,2177,2176,0
2126,2127,2178,2177,0
2127,2128,2179,2178,0
2128,2129,2180,2179,0
2129,2130,2181,2180,0
2130,2131,2182,2181,0
2131,2132,2183,2182,0
2132,2133,2184,2183,0
2133,2134,2185,2184,0
2134,2135,2186,2185,0
2135,2136,2187,2186,0
2136,2137,2188,2187,0
2137,2138,2189,2188,0
2138,2139,2190,2189,0
2139,2140,2191,2190,0
2140,2141,2192,2191,0
2141,2142,2193,2192,0
2143,2144,2195,2194,0
2144,2145,2196,2195,0
2145,2146,2197,2196,0
2146,2147,2198,2197,0
2147,2148,2199,2198,0
2148,2149,2200,2199,0
2149,2150,2201,2200,0
2150,2151,2202,2201,0
2151,2152,2203,2202,0
2152,2153,2204,2203,0
2153,2154,2205,2204,0
2154,2155,2206,2205,0
2155,2156,2207,2206,0
2156,2157,2208,2207,0
2157,2158,2209,2208,0
2158,2159,2210,2209,0
2159,2160,2211,2210,0
2160,2161,2212,2211,0
2161,2162,2213,2212,0
2162,2163,2214,2213,0
2163,2164,2215,2214,0
2164,2165,2216,2215,0
2165,2166,2217,2216,0
2166,2167,2218,2217,0
2167,2168,2219,2218,0
2168,2169,2220,2219,0
2169,2170,2221,2220,0
2170,2171,2222,2221,0
2171,2172,2223,2222,0
2172,2173,2224,2223,0
2173,2174,2225,2224,0
2174,2175,2226,2225,0
2175,2176,2227,2226,0
2176,2177,2228,2227,0
2177,2178,2229,2228,0
2178,2179,2230,2229,0
2179,2180,2231,2230,0
2180,2181,2232,2231,0
2181,2182,2233,2232,0
2183,2184,2235,2234,0
2184,2185,2236,2235,0
2185,2186,2237,2236,0
2186,2187,2238,2237,0
2187,2188,2239,2238,0
2188,2189,2240,2239,0
2189,2190,2241,2240,0
2190,2191,2242,2241,0
2191,2192,2243,2242,0
2192,2193,2244,2243,0
2194,2195,2246,2245,0
2195,2196,2247,2246,0
2196,2197,2248,2247,0
2199,2200,2251,2250,0
2200,2201,2252,2251,0
2201,2202,2253,2252,0
2202,2203,2254,2253,0
2203,2204,2255,2254,0
2204,2205,2256,2255,0
2205,2206,2257,2256,0
2206,2207,2258,2257,0
2207,2208,2259,2258,0
2208,2209,2260,2259,0
2209,2210,2261,2260,0
2210,2211,2262,2261,0
2211,2212,2263,2262,0
2212,2213,2264,2263,0
2213,2214,2265,2264,0
2214,2215,2266,2265,0
2215,2216,2267,2266,0
2216,2217,2268,2267,0
2217,2218,2269,2268,0
2218,2219,2270,2269,0
2219,2220,2271,2270,0
2220,2221,2272,2271,0
2221,2222,2273,2272,0
2222,2223,2274,2273,0
2223,2224,2275,2274,0
2224,2225,2276,2275,0
2225,2226,2277,2276,0
2226,2227,2278,2277,0
2227,2228,2279,2278,0
2228,2229,2280,2279,0
2229,2230,2281,2280,0
2230,2231,2282,2281,0
2231,2232,2283,2282,0
2234,2235,2286,2285,0
2235,2236,2287,2286,0
2236,2237,2288,2287,0
2237,2238,2289,2288,0
2238,2239,2290,2289,0
2239,2240,2291,2290,0
2240,2241,2292,2291,0
2241,2242,2293,2292,0
2242,2243,2294,2293,0
2243,2244,2295,2294,0
2245,2246,2297,2296,0
2246,2247,2298,2297,0
2247,2248,2299,2298,0
2248,2249,2300,2299,0
2249,2250,2301,2300,0
2250,2251,2302,2301,0
2251,2252,2303,2302,0
2252,2253,2304,2303,0
2253,2254,2305,2304,0
2254,2255,2306,2305,0
2255,2256,2307,2306,0
2256,2257,2308,2307,0
2257,2258,2309,2308,0
2258,2259,2310,2309,0
2259,2260,2311,2310,0
2260,2261,2312,2311,0
2261,2262,2313,2312,0
2262,2263,2314,2313,0
2263,2264,2315,2314,0
2264,2265,2316,2315,0
2265,2266,2317,2316,0
2266,2267,2318,2317,0
2267,2268,2319,2318,0
2268,2269,2320,2319,0
2269,2270,2321,2320,0
2270,2271,2322,2321,0
2271,2272,2323,2322,0
2272,2273,2324,2323,0
2273,2274,2325,2324,0
2274,2275,2326,2325,0
2275,2276,2327,2326,0
2276,2277,2328,2327,0
2277,2278,2329,2328,0
2278,2279,2330,2329,0
2279,2280,2331,2330,0
2280,2281,2332,2331,0
2281,2282,2333,2332,0
2282,2283,2334,2333,0
2283,2284,2335,2334,0
2284,2285,2336,2335,0
2285,2286,2337,2336,0
2286,2287,2338,2337,0
2287,2288,2339,2338,0
2288,2289,2340,2339,0
2289,2290,2341,2340,0
2290,2291,2342,2341,0
2291,2292,2343,2342,0
2292,2293,2344,2343,0
2293,2294,2345,2344,0
2294,2295,2346,2345,0
2296,2297,2348,2347,0
2297,2298,2349,2348,0
2298,2299,2350,2349,0
2299,2300,2351,2350,0
2300,2301,2352,2351,0
2301,2302,2353,2352,0
2302,2303,2354,2353,0
2303,2304,2355,2354,0
2304,2305,2356,2355,0
2305,2306,2357,2356,0
2306,2307,2358,2357,0
2307,2308,2359,2358,0
2308,2309,2360,2359,0
2309,2310,2361,2360,0
2310,2311,2362,2361,0
2311,2312,2363,2362,0
2312,2313,2364,2363,0
2313,2314,2365,2364,0
2314,2315,2366,2365,0
2315,2316,2367,2366,0
2316,2317,2368,2367,0
2317,2318,2369,2368,0
2318,2319,2370,2369,0
2319,2320,2371,2370,0
2320,2321,2372,2371,0
2321,2322,2373,2372,0
2322,2323,2374,2373,0
2323,2324,2375,2374,0
2324,2325,2376,2375,0
2325,2326,2377,2376,0
2326,2327,2378,2377,0
2327,2328,2379,2378,0
2328,2329,2380,2379,0
2329,2330,2381,2380,0
2330,2331,2382,2381,0
2331,2332,2383,2382,0
2332,2333,2384,2383,0
2333,2334,2385,2384,0
2334,2335,2386,2385,0
2335,2336,2387,2386,0
2336,2337,2388,2387,0
2337,2338,2389,2388,0
2338,2339,2390,2389,0
2339,2340,2391,2390,0
2340,2341,2392,2391,0
2341,2342,2393,2392,0
2342,2343,2394,2393,0
2343,2344,2395,2394,0
2344,2345,2396,2395,0
2345,2346,2397,2396,0
2347,2348,2399,2398,0
2348,2349,2400,2399,0
2349,2350,2401,2400,0
2350,2351,2402,2401,0
2351,2352,2403,2402,0
2352,2353,2404,2403,0
2353,2354,2405,2404,0
2354,2355,2406,2405,0
2355,2356,2407,2406,0
2356,2357,2408,2407,0
2357,2358,2409,2408,0
2358,2359,2410,2409,0
2359,2360,2411,2410,0
2360,2361,2412,2411,0
2361,2362,2413,2412,0
2362,2363,2414,2413,0
2363,2364,2415,2414,0
2364,2365,2416,2415,0
2365,2366,2417,2416,0
2368,2369,2420,2419,0
2369,2370,2421,2420,0
2370,2371,2422,2421,0
2371,2372,2423,2422,0
2372,2373,2424,2423,0
2373,2374,2425,2424,0
2374,2375,2426,2425,0
2375,2376,2427,2426,0
2376,2377,2428,2427,0
2377,2378,2429,2428,0
2378,2379,2430,2429,0
2379,2380,2431,2430,0
2380,2381,2432,2431,0
2381,2382,2433,2432,0
2382,2383,2434,2433,0
2383,2384,2435,2434,0
2384,2385,2436,2435,0
2385,2386,2437,2436,0
2386,2387,2438,2437,0
2387,2388,2439,2438,0
2388,2389,2440,2439,0
2389,2390,2441,2440,0
2390,2391,2442,2441,0
2391,2392,2443,2442,0
2392,2393,2444,2443,0
2393,2394,2445,2444,0
2394,2395,2446,2445,0
2395,2396,2447,2446,0
2396,2397,2448,2447,0
2398,2399,2450,2449,0
2399,2400,2451,2450,0
2400,2401,2452,2451,0
2401,2402,2453,2452,0
2402,2403,2454,2453,0
2403,2404,2455,2454,0
2404,2405,2456,2455,0
2405,2406,2457,2456,0
2406,2407,2458,2457,0
2407,2408,2459,2458,0
2408,2409,2460,2459,0
2409,2410,2461,2460,0
2410,2411,2462,2461,0
2411,2412,2463,2462,0
2412,2413,2464,2463,0
2413,2414,2465,2464,0
2414,2415,2466,2465,0
2415,2416,2467,2466,0
2416,2417,2468,2467,0
2417,2418,2469,2468,0
2418,2419,2470,2469,0
2419,2420,2471,2470,0
2420,2421,2472,2471,0
2421,2422,2473,2472,0
2422,2423,2474,2473,0
2423,2424,2475,2474,0
2424,2425,2476,2475,0
2425,2426,2477,2476,0
2426,2427,2478,2477,0
2427,2428,2479,2478,0
2428,2429,2480,2479,0
2429,2430,2481,2480,0
2430,2431,2482,2481,0
2431,2432,2483,2482,0
2432,2433,2484,2483,0
2433,2434,2485,2484,0
2434,2435,2486,2485,0
2435,2436,2487,2486,0
2436,2437,2488,2487,0
2437,2438,2489,2488,0
2438,2439,2490,2489,0
2439,2440,2491,2490,0
2440,2441,2492,2491,0
2441,2442,2493,2492,0
2442,2443,2494,2493,0
2443,2444,2495,2494,0
2444,2445,2496,2495,0
2445,2446,2497,2496,0
2446,2447,2498,2497,0
2447,2448,2499,2498,0
2449,2450,2501,2500,0
2450,2451,2502,2501,0
2451,2452,2503,2502,0
2452,2453,2504,2503,0
2453,2454,2505,2504,0
2454,2455,2506,2505,0
2455,2456,2507,2506,0
2456,2457,2508,2507,0
2457,2458,2509,2508,0
2458,2459,2510,2509,0
2459,2460,2511,2510,0
2460,2461,2512,2511,0
2461,2462,2513,2512,0
2462,2463,2514,2513,0
2463,2464,2515,2514,0
2464,2465,2516,2515,0
2465,2466,2517,2516,0
2466,2467,2518,2517,0
2467,2468,2519,2518,0
2468,2469,2520,2519,0
2469,2470,2521,2520,0
2470,2471,2522,2521,0
2471,2472,2523,2522,0
2472,2473,2524,2523,0
2473,2474,2525,2524,0
2474,2475,2526,2525,0
2475,2476,2527,2526,0
2476,2477,2528,2527,0
2477,2478,2529,2528,0
2478,2479,2530,2529,0
2479,2480,2531,2530,0
2480,2481,2532,2531,0
2481,2482,2533,2532,0
2482,2483,2534,2533,0
2483,2484,2535,2534,0
2484,2485,2536,2535,0
2485,2486,2537,2536,0
2486,2487,2538,2537,0
2487,2488,2539,2538,0
2488,2489,2540,2539,0
2489,2490,2541,2540,0
2490,2491,2542,2541,0
2491,2492,2543,2542,0
2492,2493,2544,2543,0
2493,2494,2545,2544,0
2494,2495,2546,2545,0
2495,2496,2547,2546,0
2500,2501,2552,2551,0
2501,2502,2553,2552,0
2502,2503,2554,2553,0
2503,2504,2555,2554,0
2504,2505,2556,2555,0
2505,2506,2557,2556,0
2506,2507,2558,2557,0
2507,2508,2559,2558,0
2508,2509,2560,2559,0
2509,2510,2561,2560,0
2510,2511,2562,2561,0
2511,2512,2563,2562,0
2512,2513,2564,2563,0
2513,2514,2565,2564,0
2514,2515,2566,2565,0
2515,2516,2567,2566,0
2516,2517,2568,2567,0
2517,2518,2569,2568,0
2518,2519,2570,2569,0
2519,2520,2571,2570,0
2520,2521,2572,2571,0
2521,2522,2573,2572,0
2522,2523,2574,2573,0
2523,2524,2575,2574,0
2524,2525,2576,2575,0
2525,2526,2577,2576,0
2526,2527,2578,2577,0
2527,2528,2579,2578,0
2528,2529,2580,2579,0
2529,2530,2581,2580,0
2530,2531,2582,2581,0
2531,2532,2583,2582,0
2532,2533,2584,2583,0
2533,2534,2585,2584,0
2534,2535,2586,2585,0
2535,2536,2587,2586,0
2536,2537,2588,2587,0
2537,2538,2589,2588,0
2538,2539,2590,2589,0
2539,2540,2591,2590,0
2540,2541,2592,2591,0
2541,2542,2593,2592,0
2542,2543,2594,2593,0
2543,2544,2595,2594,0
2544,2545,2596,2595,0
2545,2546,2597,2596,0
2546,2547,2598,2597,0Here is the "nlist1.dat"
2,2,2552
3,3,2553
4,4,2554
5,5,2555
6,6,2556
7,7,2557
8,8,2558
9,9,2559
10,10,2560
11,11,2561
12,12,2562
13,13,2563
14,14,2564
15,15,2565
16,16,2566
17,17,2567
18,18,2568
19,19,2569
20,20,2570
21,21,2571
22,22,2572
23,23,2573
24,24,2574
25,25,2575
26,26,2576
27,27,2577
28,28,2578
29,29,2579
30,30,2580
31,31,2581
32,32,2582
33,33,2583
34,34,2584
35,35,2585
36,36,2586
37,37,2587
38,38,2588
39,39,2589
40,40,2590
41,41,2591
42,42,2592
43,43,2593
44,44,2594
45,45,2595
46,46,2596
47,47,2597
48,48,2598
49,49,2599
50,50,2600
51,51,2601
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
7592
4440
2953
1427
1322
