Newton’s method warnings
    • abbas
      Hello every one,
      I generated an RGP table and during the process, I received the following warning.
      How or where can I change the Newton iteration underrelaxation factor.
       | Temperature : "Constitutive Relation Under Relaxation"             |
       | Pressure    : "Newton Pressure Under Relaxation"
      Best regards
      Abbas
    • DrAmine
      Does the situation persist?
    • abbas
      Yes, the situation persists. Therefore I am looking to reduce the relaxation factor.
      Could you please let me know, how can I do that?
      Thanks
    • DrAmine
       Copy paste here the CCL of your binary mixture (right click on it and edit in command editor then copy).
    • abbas
      LIBRARY:
      &replace MATERIAL: CO2
      Binary Material1 = CO2V
      Binary Material2 = CO2L
      Material Description = Carbon Dioxide CO2
      Material Group = User
      Object Origin = User
      Option = Homogeneous Binary Mixture
      SATURATION PROPERTIES:
      Component Name = CO2L
      Option = Table
      Table Format = TASCflow RGP
      Table Name = Dcfx/CO2-high.rgp
      END
      END
      END
    • DrAmine
      Add following lines under the line containing Option =Homogeneous Binary Mixture:
       Newton Pressure Criterion = 1[Pa] (Default)
       Newton Pressure Iteration Limit = 150 (Default)
       Newton Pressure Under Relaxation = your value (1 is  Default)
      This would add the under-relaxation of NR-P. If you do not understand what is the meaning of Newton Raphson and why is it required then check some references. In general, one has to ensure that every single line in the setup is correct before starting under relaxation this numerical scheme.
      I hope this helps. I leave feedback questions for other community members.
Viewing 5 reply threads
