NIST Database error
    • jeevan
      We currently researching on supercritical co2 in heat exchangers.
      once we import the "co2.fld" file and try to start the itteration we get a error saying
      Error at Node 0: REFPROP_error (203) from function: tprho (density)
      [TPRHO error 203] vapor iteration has not converged for T = 299.70 K, P = 7.2750 MPa, rho (last guess) = 7.1299 mol/L, x (mol frac) = 1.00000
      can anyone help ?
      Thank you
    • DrAmine
      Can you please add more information about release operating and boundary conditions?
    • alilozoro1
      I have the same issue when use the NIST database for r134a, but i solve this problem by limit the minimum temperature to 273.15 k.
      i hope that help you.
      best regards,
