April 23, 2019 at 5:49 am
vvkeugene
SubscriberI want to find the impact analysis of an fsae car by 1D Simulation of Chassis. Procedure: ANSYS Workbench 18 -> Static Structural -> Engg Data added -> Geometry added -> SpaceClaim The file was inputed in 2 formats IGES and STEP 214 [ to GEOMETRY of Static Structural ]. It happens that both of these didn't show the geometry and an error stating " No B-Rep data in input file " was displayed. Could you please Help me with this issue so that the geometry is displayed. Thank you in advance. P.S: The geometry was designed in SOLIDWORKS (3D Sketch & haven't added weldments) -
April 23, 2019 at 3:25 pm
Wenlong
Ansys EmployeeHi vvkeugene,
I had the same issue for me this morning. I wrote my IGES file from APDL and then import it to SpaceClaim.
I figured out that my IGES only has mesh data but no surface or volume data, and that is because my APDL file has only mesh info. You may open your IGES file and check if it has the geometry information or if it only has mesh info. If it has geometry, you may see something like "surface" or "B-spline" (like shown below) depending on your geometry type.
Just FYI: You may also check the SpaceClaim settings: Go to File-> SpaceClaim Options -> File options, and there are some import settings you can play with.
July 21, 2023 at 6:55 pm
Asha Karthikeyan
Subscriberhow to solve this issue? can anyone explain it by step by step?
- Attaching 2 Objects + moment of inertia with/without point mass
- Honeycomb DOE using parametrization in SpaceClaim
- ” No B-Rep data in input file “
- Surface Definition
- Spaceclaim equations: How to insert the log functions
- SpaceClaim Teaching/Curriculum Materials
- time history analysis
- Recording spline line in script editor
- How can I change center coordinates of the part?
- Set Spaceclaim API version when running script
7742
4502
2963
1449
1322
