June 2, 2020 at 4:45 pm
OGomez
Subscriberhelp please. I can not run setup in fluent. i only get errors.
June 2, 2020 at 4:50 pm
OGomez
I only get a frozen window with a partially loaded page (see image), with the following message in console area:
Unable to connect to external socket: Error during socket creation
Opening output file:"SolutionResult.xml"
Welcome to ANSYS Fluent 2020 R1
Copyright 1987-2020 ANSYS, Inc. All Rights Reserved.
Unauthorized use, distribution or duplication is prohibited.
This product is subject to U.S. laws governing export and re-export.
For full Legal Notice, see documentation.
Build Time: Dec 2 2019 14:16:01 EST Build Id: 10114
2020/06/02 10:49:07 INFO Demo license file C:PROGRA~1ANSYSI~1ANSYSS~1Shared FilesLicensingstudent.lic exists.
Warning: Unexpected error checking license expiry date.
This is an academic version of ANSYS FLUENT. Usage of this product
license is limited to the terms and conditions specified in your ANSYS
license form, additional terms section.
Host spawning Node 0 on machine "MySatallite" (win64).
WARNING: No cached password or password provided.
use '-pass' or '-cache' to provide password
Through workbench I get the “The Fluent application failed to start” message.
June 2, 2020 at 8:35 pm
tsiriaks
Ansys EmployeeYou have issue with MPI. Either security software blocking it or there is something messing with your local networking.
For local networking issue, try this:
In Fluent Launcher page, click Show More Options -> Parallel Settings , then set
MPI Type = MSMPI
Check box for 'Select IP Interface' and select the 127.0.0.1 IP address.
For security issue, you will have to try narrow it down which of your security causes this MPI issue. I recommend to try turning everything off at first and work your way back to narrow down the cause.
- License Error
- Workbench error
- Workbench not opening
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
3744
2573
1803
1236
594
