September 3, 2023 at 2:53 pm
rajatkumar.sinha
Subscriberi have uploaded the effective refractive index file given by interconnect https://optics.ansys.com/hc/en-us/articles/360036618293-Optical-Modulator-Measured-OM-INTERCONNECT-Element i have even tried to change the values in effective index.txt but there is no change in phase . i would like to know how can i bring change in phase in a optical modulator using dc voltage.
September 7, 2023 at 9:50 pm
Guilin Sun
Ansys Employeechange in phase in a optical modulator using dc voltage should be first simulated in CHARGE, and then import the carrier density as np density attribute. Please refer to this example: https://optics.ansys.com/hc/en-us/articles/360042456054-Electro-absorption-modulator
or
https://optics.ansys.com/hc/en-us/articles/360042328774-Traveling-Wave-Mach-Zehnder-Modulator
https://optics.ansys.com/hc/en-us/articles/360034901753-np-Density-and-Temperature-Index-Perturbation-Simulation-objectÂ
The data should be effective index vs voltage for INTERCONNECT use.
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7742
4490
2957
1449
1322
