July 27, 2023 at 10:04 pm
James Trudgett
SubscriberI am modeling a projectile travelling through a gelatin block but when checking the velocity probe I have attached to the projectile it does not change as it passes throught the gelatin block. why is this?
July 28, 2023 at 8:28 am
Ansys EmployeeWhich solver are you using? How is motion defined?
July 28, 2023 at 9:16 am
July 28, 2023 at 2:33 pm
Mike Rife
Ansys EmployeeHi James
You've defined a constant velocity for the projectile. Instead of that what are the defined initial conditions (if any)? The projectile should have a initial velocity defined instead.
July 28, 2023 at 3:17 pm
James Trudgett
SubscriberHi Mike,
Thank you for your help. I have tried to apply the velocty (under the initial conditions section on explicit dynamics) however, when I highlight my projectile (so I can add the velocity to it) it won't let me. Do you know why this may be happening. I've attached a photo to show the issue as well as the other inital conditions I have applied.
July 28, 2023 at 4:04 pm
July 28, 2023 at 6:38 pm
James Trudgett
SubscriberHi Mike,
Thank you for your help. The velocity is now changing as it passes through the block
- License Error
- Workbench not opening
- Workbench error
- how to open DesignModeler
- FlexNet Licensing – Not running
7626
4456
2955
1427
1322
