June 24, 2023 at 6:21 am
June 27, 2023 at 5:19 am
Nanda Veralla
Ansys EmployeeHello Hakim,
Can you check the "Objective and response constraint capability map" provided in the link below:
Apply Design Objectives and Constraints (ansys.com)
The document says that, compliance is not supported for Non-linear static structural system, when using Lattice method, Level set method or Topography method. For more details on using structural optimization, kindly refer to this link:
Optimization Analysis Overview (ansys.com)
Nanda.
July 6, 2023 at 12:05 pm
Hakim Dina Anjum
SubscriberThankyou. I had kept large delfection turned on, which triggered a non linear solution perhaps, turning it off solved the issue.
4468
2957
1427
1322
