November 13, 2018 at 5:07 pm
mkronig
SubscriberHi
I'd like to run a simulation for the magnetic field of a coil like in the Picture.
In order to generate a conduction path I created a surface body which lies in the cross section of a winding.
Nothing happens when I try to generate the conduction path. Here is another detailed Picture of the Connection between the coil and the shortening wire. How can I fix this? Thanks in Advance.
November 15, 2018 at 8:50 am
fbocquet
Ansys Employeehi,
1/ what is the material of the coil setup in Maxwell?
2/ there are several possibilties to correct this geometry in SpaceClaim or in Maxwell modeller,. for instance, in both tool, you can try to cut one object using the other and erase the part you don't need.
rgds,
- Maxwell, HFSS or Q3D?
- Error
2564
2080
1299
1106
459
