No ‘Imprint Faces’ Operation option when creating a Sphere in Design Modeler
    • YonathanZ
      I've imported geometry into Mechanical (from SolidWorks).
      In Design Modeler, I've clicked Create > Primitives > Sphere. For Operation, I need to select 'Imprint Faces' but the option does not appear (see attached screenshot). Is this a limitation of important geometry from a file instead of creating it within Design Modeler?
      Thanks.
    • Aniket
      imprint faces would only work if there are bodies that are not added as frozen. In other words, you would need to import the CAD model using "Add Material".
      -Aniket
    • YonathanZ
      So, alternatively, I could've modeled it as one body instead of two?
