March 27, 2023 at 10:10 am
joe jackson
I seem to be having issue with the no merge options. If I use the face of a shape as a sketch plane, the no merge option doesnt work and my new shape automatically gets merged to the original shape? Any insight is helpful. I need to be able to build multiple objects to be pulled apart for separate 3D printing needs.
March 27, 2023 at 12:31 pm
Atharv Joshi
Forum ModeratorHi joe jackson
Let me check and get back to you,
Thanks and Regards
March 27, 2023 at 1:01 pm
Atharv Joshi
Forum ModeratorHi joe jackson ,
If you are creating a sketch and then pull with "no merge" active it will still create a merged solid. You have to create a surface by using fill tool while in sketch mode and then use pull with "No merge".
I have prepared a small video for you. Let me know if this solves your problem.
Thanks and Regards
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions-
March 27, 2023 at 1:10 pm
joe jackson
Atharv Joshi Awesome. Thanks! I like your layout colors and the pop up with your cursor. Much easier on the eyes.
March 27, 2023 at 1:23 pm
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3153
1688
1478
