February 12, 2023 at 9:40 pm
tomas.monopoli
SubscriberHello all,
I am running an analysis of a 3D setup with multiple incident wave sources.
Does anyone know why I don't have the multi-frequencies and broadband options in the analysis setup?
I have an HFSS terminal driven design.
Here is my desktop configuration:
If, for example, I add a lumped port, I am again allowed to use multi-frequiences in the setup.
I don't understand why this option is disabled if I just have incident wave sources.
Thank you!
Tomas
- Maxwell, HFSS or Q3D?
- Error
3930
2649
1861
1272
610
