No plastic Strain deformation when I use displacement controlled loading.
    • mdhiz97
      Hi all,
      I am confused about the results that I am getting from my simulation. If I did a displacement controlled loading. I dint get the expected result that I want.
    • 1shan
      In continuation to your last post https://forum.ansys.com/discussion/28616/transparent-face-after-meshing-multizone#latest. Could you try my suggestion and see if you still get missing elements. In the central region of your geometry there are small steps which you have created. Since mesh defeaturing is off, some hex elements have been 'quashed' and are behaving like 2d quads. This might be one reason why you are seeing strange results.
      Regards Ishan.
