No result computation in post-processing
    • Vaishnavi
      I have successfully modeled a wave flume and obtained pressure values (of wave over a structure) via function calculator.
      I am now trying to assign porus medium and run the same calculation, but I do not get any results in function calculator any more.
      Error says- "No data types for variables'". The solution also isnt converging completely (veocity doesnt converge) even though the meshing properties from my previous trials are unchanged.
      I tried running with the previous parameters where there was no porus medium (I had reset all the systems) still neither the solution converges completely nor a result value is obtained.
      pls help
    • DrAmine
      Which Software are you using?
    • Vaishnavi
      Hi, this issue was with Ansys fluent. I had to discard the run,. Reinstall ansys, now it works. But still the issue is in results section, sometimes it shows result (in function calculator} sometimes it doesn't
      Hard to tell without any images. Please can you post screen shots of the Workbench session, and Fluent results.
Viewing 3 reply threads
