August 22, 2018 at 12:15 pm
Jasmina92
SubscriberHello,
I want to model a high viscous flow through a conical die with Polyflow. But after a short calculation there was no result available. Has anyone ever experienced that no result file was written after a calculation?
After the complete set up I updated the solver-button (in the workbench project) and the calculation started to run. after a few minutes (maybe 2 – 3) the calculation stops without any message and a green check mark appears at all buttons.
But when I open the results there is not a single result. Also the res-file is empty.
Why doesn’t polyflow calculate anything? In other projects in the same workbench I am not having this problem.
Is there may be a setting that I can check to fix this?
Many thanks!
Jasmina -
August 22, 2018 at 3:04 pm
Karthik R
AdministratorHello,
Could you please share a screenshot of your workbench page as well as your PolyFlow set-up?
If you haven't already seen these, I strongly encourage you to visit Ansys HowToVideos page on YouTube for video tutorials on PolyFlow. I have attached a link which contains the entire playlist.
I hope this is useful.
Please add the screenshots.
Thank you.
Best Regards,
Karthik
August 29, 2018 at 9:17 am
2616
2098
1323
1108
461
