January 15, 2021 at 4:06 am
MACO_Benjarong
SubscriberI'm facing this issue multiple times now as that after the simulation completed in Refine stage, the results are not displayed, And I tried to save and re-open the file, the they still do not displayed. I tried to reduce number of applied conditions, it still doesn't work. Does anyone has the same problems? please provide support. Support is much appreciated. -
January 15, 2021 at 7:42 am
Naresh Patre
Ansys EmployeeHello Benjarong Charoensub
I don't recall seeing this issue before. What happens if you click other display options like Contours?
Can you try updating the Graphics card drivers from Nvidia website, and check again?
Also, a new version of Discovery has been released yesterday. Can you try installing it and see if that works fine for you?
January 15, 2021 at 9:29 am
MACO_Benjarong
SubscriberI tried clicked on other display, nothing happened. I have had this problem for quite sometimes now, but it doesn't occurred regularly.
I will try updating graphics driver and also updating the discovery.
thank you for your reply.
February 4, 2021 at 3:51 pm
luca.maggiori
SubscriberBenjarong Charoensub Hi, did you solve by updating the graphics driver? I'm having the same issue in Refine stage with Discovery 2021 R1.2 and Quadro K620 GPU.
3850
2609
1853
1246
600
