March 10, 2021 at 1:44 pm
Raj007
SubscriberMarch 11, 2021 at 1:58 pmKarthik R
AdministratorHi,nIs this a steady-state or transient run? What are your initial conditions in your model?nAlso, what are your boundary conditions, especially the heat transfer ones?nKarthiknMarch 11, 2021 at 3:28 pmRaj007
SubscriberHey,nI am running it in the steady-state condition as it is less velocity and high-density model, which defines as the laminar model. nThere is an inner and outer layer. The heated source (Body considered as a wall) is present in between the interface of layers. I have specified the temperature for the source and heat flux for the rest of the walls.nPlease let me know if there are any other details necessary.nThank younRajnMarch 11, 2021 at 5:49 pmRob
Ansys EmployeePlease post some contours of temperature to help explain what's going on. nMarch 17, 2021 at 8:06 pmRaj007
SubscriberI cannot post it in public as it is a bit confidential. Can I do it in other ways?nMarch 18, 2021 at 12:04 pmKarthik R
AdministratorHello,nWhat conditions are you applying in your model? I think what is trying to ask is: why is your average temperature at 0 K. Are you seeing any temperature results at all? nIt seems like you are solving the energy equation, but you have 0 heat flux as input into the model?nAlso, what are your initial conditions? Shouldn't you at least see this value in your average if your temperatures in the model are not changing?nKarthiknViewing 5 reply threads- You must be logged in to reply to this topic.
2726
2146
1357
1150
462
