January 28, 2021 at 3:47 am
Qiuyuhao
SubscriberHello,
I am currently using ANSYS 19.2 for secondary development. Although ANSYS has good support for secondary development, I still encountered some problems.
I found that there are no functions related to Section and Material in the Binlib library .That's weird, because they are defined in RstRd.F.
I will be very grateful if anyone can give me some suggestions.
(I used dumpbin commond to figure out the composer of binlib.lib, and found that it dose't have those funcitons)
February 3, 2021 at 8:51 amQiuyuhao
SubscriberCan anyone help menFebruary 3, 2021 at 9:17 amAshish Khemka
Ansys EmployeeHi @Qiuyuhao, ,nnYou already have post open on the same topic:nnHello, I am currently using ANSYS 19.2 for secondary development. Although ANSYS has good support for secondary development, I still encountered some problems. I found that there are no functions related to Section and Material in the Binlib library .That's weird, because they are defined in RstRd.F. I will be very grateful if anyone can give me some suggestions.(I used dumpbin commond to figure out the composer of binlib.lib, and found that it dose't have those funcitons)https://us.v-cdn.net/6032193/uploads/UVSJ6O8PTA8E/20210125164156.pnghttps://us.v-cdn.net/6032193/uploads/RLPXAYV47EN1/20210125164220.pnghttps://forum.ansys.com/discussion/23908/no-section-material-related-function-found-in-binlib-lib
nI will mark this one as resolved.nnRegards,nAshish KhemkannViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- Solver Pivot Warning in Beam Element Model
5290
3311
2471
