January 27, 2021 at 3:13 am
Qiuyuhao
SubscriberHello,
I am currently using ANSYS 19.2 for secondary development. Although ANSYS has good support for secondary development, I still encountered some problems.
I found that there are no functions related to Section and Material in the Binlib library .That's weird, because they are defined in RstRd.F.
I will be very grateful if anyone can give me some suggestions.
(I used dumpbin commond to figure out the composer of binlib.lib, and found that it dose't have those funcitons)
January 27, 2021 at 8:35 amQiuyuhao
SubscriberResRdSectMatBegin / ResRdSectMatEnd / ResRdSectBegin / ResRdSect / ResRdSectEnd / ResRdMatBegin / ResRdMat / ResRdMatEnd . These funcitons/subroutines are not used in ResRdDemo.F. I think that's strangenFebruary 9, 2021 at 5:21 pmSheldon Imaoka
Ansys EmployeeHi Qiuyuhao,nThe ResRdDemo.F is just a demonstration program and not a complete/thorough result file reader. It is just intended to demonstrate use of some of the routines.nSee Section 2.3. Results File Access Routines in the Help documentation for information on ResRdSect, ResRdMat, etc.nRegards,nSheldoViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- License Error
- Workbench not opening
- Workbench error
- how to open DesignModeler
- FlexNet Licensing – Not running
7742
4502
2963
1449
1322
