No SI unit setting in Solver Unit System option
    • helen.durand
      Under Analysis Settings in Transient Thermal, how do I specify SI units for the Solver Unit System? It defaults to the mks system, and the SI unit system does not seem to be available as an option when I select try to manually select a unit system.
    • Ashish Khemka
      Hi,nnFor temperature you choose between the unit system degree Celcius or Kelvin:nnnnRegards,nAshish Khemkan
