No smooth transition method present in the outline view compared to workflow view in fluent
    • atulsingh92
      After computing the volume region of a geometry, when I do want to scope the boundary layer at the walls, I cannot find the smooth transition option (v19R2) (this is in the outline view of the model tree).
      Why the absence of this feature here?
      I ask this becuase I have found that my boundary layers works for smooth transition of the "workflow" model tree, but not in any other 3 offset types. And I want to manually build a TUI script for the meshing which would be similar as that obtained via workflow. But it seems the two are different. Is that correct?
      thanks,
      Yes and no. The Workflow uses scripts to simplify the meshing process. If you're using the TUI you're using the full Fluent Meshing functionality: all commands are available but you'll need to find them.
