March 17, 2021 at 3:38 am
nuramuaz1
SubscriberWhat could be possible reasons for having a sharp progressing profile at the inlet side but non smooth profile at the outlet side? The profile is for turbulent case pls. n -
March 17, 2021 at 3:51 am
Keyur Kanade
Ansys EmployeeThis all depends how your flow is developing. Mostly it depends on how your geometry changing from inlet to outlet. Also it depends on the models you are using. Some models need particular mesh to be created. So you may also need to check your mesh. Check mesh quality as well. nPlease search this forum and you will find a lot of information. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn -
March 17, 2021 at 6:19 am
nuramuaz1
SubscriberThanks Mr Keyur for your quick and valuable response.nMy mesh has a good quality with skewness of 0.12 and orthogonal quality of 0.89. I'm using a wavy channel with k-e model. the cfd post of local htc shows a fully developed profile. nThank once moren -
March 17, 2021 at 4:26 pm
Ansys EmployeeSome pictures would help. n -
March 22, 2021 at 7:54 am
March 22, 2021 at 5:09 pm
Ansys EmployeeOdd, what is the mesh resolution like? Faceting in profiles can be a result of the mesh. Remember, y+ helps find the near wall cell height, you also need to resolve the rest of the boundary layer and core flow. n -
March 23, 2021 at 2:24 am
nuramuaz1
SubscriberHi Rob. nThanks for the comment. My mesh is around a million elements with y+ of 1. the max skewness and ortho quality are 0.36 and 0.89 respectively. The mesh is hex dominant. nRegardsn -
March 23, 2021 at 5:03 am
Keyur Kanade
Ansys EmployeeAre you using hex dominant method in meshing?nPlease use tet + inflation and check. n -
March 23, 2021 at 9:59 am
Ansys EmployeeTo clarify, hex dominant method gives an awful mesh, having mostly hex cells is good! The cell quality looks OK, but (big but) you also need to look at the bulk resolution and growth rate. n
Viewing 8 reply threads
Trending discussions
Top Contributors
2610
2088
1319
1108
459
Top Rated Tags
