June 7, 2023 at 9:48 am
Ammar Ahmed
SubscriberHello everyone, I am trying to simulate flow through injector using VOF model with K-E RNG (swirl dominated flow) on FLUENT 2022 R2. I have distriburted my simulation on 3 PCs(Dell Precision Tower 7910) using distrubted memory option in FLUENT. Specifications of PC's are as following: PC1: MEMORY=64GB, GEFORCE RTX 3090 (24GB) 28 cores PC2: MEMORY=64GB, GEFORCE RTX 3090 (24GB) 28 cores PC2: MEMORY=32GB, GEFORCE RTX 1660 (6GB) 16 cores Fluent is showing that the GPUs are being enabled but during simulation the GPU is not being utilized but only the CPU and Memory. I have also installed CUDA Version 12 for proper intgration but no success so far. If anyone has any idea on how to resolve this issue, kindly let me know. I am also trying to introduce a new environment variable for proper utilization of GPUs on each device. Kindly tell if its the right approach. The mesh element number is 14million.
June 7, 2023 at 10:22 am
Kishan Konannavar
Ansys EmployeeHello Ammar
Are you trying to employ the native GPU-solver?
June 7, 2023 at 11:58 am
June 7, 2023 at 12:04 pm
Ammar Ahmed
SubscriberMy simulations run completely on CPU and memory. The GPUs are not utalized not even a bit. Do we have to make an enviornment variable in system variable and assign it a value of 1 so that Cuda 12 forces GPU to be utilized?
Â
7742
4502
2961
1449
1322
