No workflow window when opening fluent meshing is it not available
    • Ak0703
      I am using fluent 18 and there is No workflow window when opening fluent meshing
      is it not available in fluent 18 version or is there anything i should do to enable it from my side
      If you mean Fluent Meshing in Workbench, it may not be available in R18. The workflow options within Fluent Meshing were added to WB more recently as they initially conflicted with the overall workflow. Given R18 is 5 releases old now I'd advise a software update.
