Tagged: ansys-workbench, mechanical-apdl, static-structrural
February 28, 2022 at 1:09 pm
mv_cae
SubscriberI have done calculation in Ansys APDL. In order to use FKM tool, I imported the model in Wrokbench as *.cbd external model. In Workbench I read the results as .rst file . After evaluting the results in both platforms (APDL, Workbench), I coulde see that, the von Mises stress (Unavraged)in Workbench is identical to Element solution in APDL.
due to my Project I need to validate the Nodal stress in both Platform (APDL, Workbench). Does anybody know that, how can I read Nodal Solution in Workbench?
March 2, 2022 at 10:13 amAshish Khemka
Select the nodes and then evaluate the stress result for the nodes.
Regards Ashish Khemka
March 3, 2022 at 8:40 ammv_cae
Thanks for your respond. I knew this option but it is not what I meant. in workbench we can see also the Nodal Solution and Element Solution as well as APDL. For example the von Mises Stress Element Solution in APDL is similar to von Mises Stress (unaveraged) in WB. For Nodal Solution we need to averaged result.
The difference between APDL and WB is, in Nodal Solution in APDL when the PowerGraph is On or Off. Then you will have different value in result and this is due to singularity in model. if you have fine mesh all this values must be roughly same.
To understand the result we need to first understand the difference between Nodal and Element Solution.
March 4, 2022 at 7:57 amAshish Khemka
Please see if the following links help:
Average and Unaverage stress ÔÇö Ansys Learning Forum
How to Change the Averaging on Contour Results | SimuTech Group
October 13, 2022 at 6:52 pmZakary Adam
SubscriberGreetings,
Our engineering specifically covered this topic in a support article titled, Ansys Workbench Mechanical: Averaged vs. Unaveraged Contour Results.
Viewing 4 reply threads- You must be logged in to reply to this topic.
2706
2142
1355
1144
462
