Node number in the Solution Information does not exist
    • mert.dedebeyoglu
      I am getting the following error in Static Structural analysis. When i search for the node "541889", nothing appears. The node does not exist.
      Do you have any suggestions?
      "The value of UX at node 541889 is 2.692029639E+14.  It is greater than
       the current limit of 1000000 (which can be reset on the NCNV command).
        This generally indicates rigid body motion as a result of an
       unconstrained model.  Verify that your model is properly constrained.   "
    • Erik Kostson
      It could be a node that is generated say for a remote point etc and that is not part of the mesh (generate mesh inside mech.). Get the model into apdl and see where that is or search the ds.dat file and find where it is being used.
    • mert.dedebeyoglu
      I checked the ds.dat file, and from the node I detected a missing contact.
      Thanks for the help.
