Tagged: cfd-udf-fleunt, define_adjust, define-source, udf
January 24, 2023 at 3:38 am
kds_ansys
SubscriberHello,
I am new to both UDF and Ansys and am currently using the following UDF code for my simulation. While the code compiles without any errors, when I try to initialize the model, I encounter an error and the simulation closes automatically.
Node 6: process 13572: received signal sigsegv.
Node 7: process 110688: received signal sigsegv.
99999: mpt_accept: error : accept failed: No error
Bad termination of one of your application processes
Rank 0 PID 99524 Running at xxx
Exit status: -1 (ffffffff)
Here is my code
/*************************************************//*************************************************/#include "udf.h"#include "sg.h"real m_sum=0;real ar_sum=0;real m_max=0; /*mass flux at the corner of meniscus: used for thin film region*/real h_ar_int=0;real h_avg=0;DEFINE_ADJUST(Get_q_V, d){Thread *t; // thread pointerDomain *domain; // domain pointercell_t c,c0; // define cellface_t f,f2,f_face_l; //define faceThread *tf, *tf2;int n,n2; // define n and n2real S=0;int liquid_id=7; // the liquid zone's thread ID the domain ID/*real p, ps, Ts, hfg, M_bar, R_bar, M_air, p_l_sat;*///water propertiesreal ps=3167.739;real Ts= 298;real hfg= 2270e3;real M_bar=18.01;real R_bar=8314.47;real p_l_sat=0;real cp = 4181.3;int liquid_inter_id1=12; // the liquid interface at the liquid/vapor interfacereal count=0;real dr0[ND_ND]; // the vector that connects the centroid of cell c0 to the face centroidreal dr1[ND_ND]; // the vector that connects the centroid of cell c1 to the face centroidreal A[ND_ND]; // the area normal vectorreal es[ND_ND]; //the unit normal vector in the direction from cell c0 to c1real T; // define the temperaturereal temp2; // define the mass flow ratereal cent1[3],cent2[3]; // the centroid of cellreal ar; /* area of the face of the cell*/real q, temp;real q_conv;real qd=0;real ds, A_by_es; // the value A.A/A.esreal AA, B;m_sum=0;ar_sum=0;m_max=0;h_ar_int=0;domain = Get_Domain(7); // get the domain selected, put the liquid domain id insidetf= Lookup_Thread(domain, liquid_inter_id1); /* look up the face thread of the domainliquid_inter_id1 which is the liquid vapor interface */begin_f_loop (f, tf){c=F_C0(f,tf); // macros to identify adjacent facest=F_C0_THREAD(f,tf); // macros to identify adjacent faces threadT=F_T(f,tf); //get the temperature at the faceF_AREA(A,f,tf); // can be used to return the real face area vectorar=NV_MAG(A); // get the areap_l_sat=ps*exp((1/Ts-1/T)*hfg*M_bar/R_bar) ;temp2 = .03*sqrt(M_bar/(2*3.1415*R_bar))*(p_l_sat/sqrt(T) - ps/sqrt(Ts)); /*evap mass flux from the face */qd = temp2*ar*hfg;F_UDMI(f,tf,1)= temp2;S=qd/C_VOLUME(c,t); /*S is like energy source term*/if (S/hfg > m_max){m_max=S/hfg; /*highest mass source term for any cell*/}C_UDMI(c, t, 0) = S; // store or access the value of mass sourceC_UDMI(c, t, 1) = qd/(hfg*ar);F_UDMI(f,tf,2) = temp2*hfg/(T-298);C_UDMI(c,t,2) = temp2*hfg/(T-298);h_ar_int = h_ar_int + F_UDMI(f,tf,2)*ar;m_sum=m_sum+qd/hfg; /*total mass evaporated in Kg/s*/ar_sum=ar_sum+ar;count=count+1;}end_f_loop(f,tf)h_avg = h_ar_int/ar_sum;Message ("Total area of interface: %g\n", ar_sum);Message ("Total mass evaporated (kg/s): %g\n", m_sum);Message ("h integral on interface: %g\n", h_ar_int);Message ("h Average on interface: %g\n", h_avg);Message ("Total faces on the interface: %g\n", count);Message("Highest mass source term for any cell: %g\n", m_max); }DEFINE_SOURCE(Mass_liquid, c, t, dS, eqn){Thread *c_thread;face_t f;Thread *tf;int n;real S=0;//methanolreal hfg=2270e3;//water// real hfg = 2270e3;real ar;int liquid_id=7; /*liquid zone 's thread ID*/int liquid_inter_id1=12; // the interface of the domain/ liquid vapor interfacec_face_loop(c, t, n){f = C_FACE(c,t,n); // the face of the liquidtf = C_FACE_THREAD(c,t,n); // the face thread of the liquid/* looping through the face */if(THREAD_ID(tf)==liquid_inter_id1 ){S=-1*C_UDMI(c,t,0)/hfg; // store or access the value of mass source}}return S;}DEFINE_PROFILE(h_interface, thread, position){face_t f;real T_room=298;real T; /*wall temperature*/real dT;/*dT=T-T_room*/real k=0.68;real Nu,h;real hfg=2270e3;begin_f_loop (f, thread){T=F_T(f,thread);dT=fabs(T-T_room);h = F_UDMI(f, thread, 1)*hfg/dT;F_PROFILE(f,thread,position)=h;}end_f_loop (f, thread)Message("dT: %g\n",dT);Message("T :%g\n", T);Message("h :%g\n", h);} -
January 24, 2023 at 12:03 pm
Ansys EmployeeI'm not going to debug the code, but common issues include data being used that's not available and insufficient UDMs being assigned in Fluent (you do this manually).
As a more general comment, use indents to make blocks easier to read and be careful when assigning number types:
real whatever = 0 ;
isn't great,
real whatever = 0.0 ;
is more appropriate.
January 25, 2023 at 2:27 pm
kds_ansys
SubscriberThank you Rob for the reply. I have assigned UDM manually in Fluent. To make sure I wouldn't assign a small UDM number, I assigned a big number (100). However, I am still seeing the same error.
January 25, 2023 at 3:50 pm
Ansys EmployeeOK. Break the code down. If you don't use the source & profile what happens? Note, some single/few letter variables can clash with Fluent's built in functions: it's always best to use more descriptive variables. 100 UDMs may be a little excessive, I don't think it'll cause a problem but may result in data files that are a lot bigger than they need to be.
January 26, 2023 at 1:39 am
kds_ansys
SubscriberThanks Rob. It is actually working now. I divided the file into two rather than one, and it worked.
2508
2064
1277
1088
456
