July 1, 2020 at 2:02 pm
hrish888
SubscriberSo i wanted to increase the number of nodes and the elements in 2d heat conduction experiment.As i was able to increase the number of elements but the nodes where visible only on the corners of each element and not on the sides of each element so as to make it 3 variable polynomial equation. I am getting 45 nodes as suppose to 121 elements. How can i add the elements on the sides also.
Thank You
July 2, 2020 at 5:17 am
Keyur Kanade
Ansys EmployeePlease use edge sizing. Please check help for more info about edge sizing.
Also please check following.
Keyur
July 2, 2020 at 10:33 am
hrish888
Subscriberthis doesnt help i want to create more nodes within a single element.I am just getting nodes on the corners n i need it on the sides also thats the issue and the object in 2d.
July 3, 2020 at 4:07 am
Keyur Kanade
Ansys Employeedo you mean mid side nodes?
if so then you will need to use mechanical as physics preference.
i thought it is for fluids. somebody from mechanical expert please comment here.
Keyur
July 3, 2020 at 8:04 pm
SubscriberUnder Mesh, change the Element Order from Linear (or Program Controlled) to Quadratic. That will cause midside nodes to be created on the elements.
- check element type
- Meshing Error
- How to resolve Mesh Failure
- Error in meshing
3850
2613
1853
1246
600
